Author Topic: Rebuiding a RC HiLux 4x4  (Read 6434 times)
Offline modeldozer
  • Country: es
  • Valencia, Spain
    • AJ´s Truckmodeling
« on: January 12, 2015, 09:03:56 AM »
Hi fellow modders,
While my milling machine is still out of commission I thought to make a start on a long outstanding project.  Around 30 years ago I bought and built a Tamiya HiLux 4x4 RC model, but other things got in the way and it has been standing on a shelf since.
Have decided to rebuild it completely, cleaning, re-lubricating and repainting.  Also opted to replace all the brass bushes in the drive train with ball bearings.
Axles striped down and cleaned.
Bearings fitted.
Reassembled.
And refitted to the chassis.
Abraham
Re: Rebuiding a RC HiLux 4x4
« Reply #1 on: January 12, 2015, 10:43:38 AM »
Wow, that's pretty cool -- I've only been in the airplane side of the hobby. Didn't realize the metal and detail of the truck side of things.  :thumbup: :clap:
Offline modeldozer
  • Country: es
  • Valencia, Spain
« Reply #2 on: January 12, 2015, 11:02:24 AM »
Hi Steve,
These can get quite detailed and complicated.  Found this old promotional video for this model.
Abraham
Offline Phill05
« Reply #3 on: January 12, 2015, 03:11:13 PM »
Good to see you working on RC models I used to do some modding on them for Rock crawling, are you going into the gearbox to change the bearing? somewhere I have some images inside the box.
I also made a transfer box for an 8 wheeler.
Phill
Offline modeldozer
  • Country: es
  • Valencia, Spain
« Reply #4 on: January 13, 2015, 07:57:06 AM »
Hi Phill,
Thanks.  Found a rebuild manual for the gearbox on the internet and will go for bearing convertion.
Abraham
Offline modeldozer
  • Country: es
  • Valencia, Spain
« Reply #5 on: January 13, 2015, 03:23:48 PM »
Hi all.
One of the shafts in the gearbox had to be pressed apart.  After fitting the bearings the pinion was cross drilled and pined to the shaft.
All ready for assembly.
And assembled.
The shock absorbers were also rebuilt with new seals and oil.
All mounted back on the chassis.
Till later.
Abraham
Offline modeldozer
  • Country: es
  • Valencia, Spain
« Reply #6 on: January 20, 2015, 03:05:01 PM »
Managed to get a bit more done.
Some of the servo mounts were broken so new ones were made from square MS bar.
The original speed controller was giving problems and was replaced with a modern electronic one.
Made some caps to blank off the unused servo pivot hole.
Also made a support for the new switch, which is quite a bit smaller than the original.
Servos, ESC and receiver fitted.
Abraham
Offline Phill05
« Reply #7 on: January 20, 2015, 03:59:10 PM »
Looking good
« Reply #8 on: January 20, 2015, 08:54:33 PM »
 :coffee: :coffee:
