Author Topic: Seven Cylinder, Radial Engine.........  (Read 9224 times)
« on: November 11, 2014, 03:34:59 AM »
Thought you all, might like to see this.......
Re: Seven Cylinder, Radial Engine.........
« Reply #1 on: November 11, 2014, 05:32:58 AM »
Absolutely brilliant  :clap:
I'm surprised that it didn't blow itself away on that frame
Offline rockknocker
« Reply #2 on: November 12, 2014, 03:58:56 PM »
That is a beautiful engine!
Its almost large enough to power a small aircraft, do you have any such plans?
Anything is possible when you forget what's impossible.
Offline MetalMagus
« Reply #3 on: November 13, 2014, 07:11:48 AM »
That is really cool.
Offline steampunkpete
« Reply #4 on: November 16, 2014, 02:17:44 PM »
How absolutely fabulous! I wish I had even a tiny fraction of that skill.
I can just see this in a steampunk motorcycle, but I can't make up my mind if the crankshaft would be in-line with the frame or across it.
« Reply #5 on: November 16, 2014, 03:40:38 PM »
Pete,
In line.
If it was across then the gyro effect would be deadly.
Believe me on this, I once owned a V twin Moto Guzzi. I don't remember if it was left or right hand bends,  but if you opened up the throttle on the wrong one it would lift the front wheel off the ground and try to rotate the bike around the engine.
Hairy.
Offline Noitoen
  • Country: pt
« Reply #6 on: November 18, 2014, 03:36:32 AM »
It's been done before. http://www.southbayriders.com/forums/threads/62848/ they do look good.
Offline AussieJimG
« Reply #7 on: November 18, 2014, 04:16:13 AM »
There was a much more modest machine called the Redrup in the distant past:
http://www.savory.de/sammy_redrup_radial_three.jpg
