Author Topic: Lee Breech lock reloading press mount  (Read 32344 times)
Offline PTsideshow
« on: October 19, 2014, 08:56:50 AM »
After reading and viewing a number of vid's on prepping 5.56/.223 cases and figuring out that a solid mount and one with a larger foot print would be needed to size the cases before trimming.
I also thought that a single stage O-press might be a good investment with a small base sizing die as a stand alone in addition to to the 550B. Considering I got carried away and bought about 14,000 5.56/.223 over the last 3 months. One of them deals I couldn't pass up.
This is the mount I came up with and made this morning.
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1667.jpgLee Breech lock reloading press mount
1/2" plate was the perfect size for this project
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1668.jpgLee Breech lock reloading press mount
Here is the press a cheap under $75.00 way to deprime / size the casings during the prep part of the reloading. I like to do a lot of casing in each step at once. I got carried away and bought 14,000 5.56/223 range pick ups. I can inspect etc. the brass befor it is run through my progressive press.
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1671.jpgLee Breech lock reloading press mount
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1674.jpgLee Breech lock reloading press mount
Laying out and taping, I went with 5/16-18 bolts since it would hold the press to the mount and the mount to the bench. With out any flex when in use. The military brass use a crimp and adhesive to keep the primer in place when used in full automatics.
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1063.jpgLee Breech lock reloading press mount
Here are some types of the crimps, which have to be removed before reloading.
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1675.jpgLee Breech lock reloading press mount
Cleaned and primed
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1676.jpgLee Breech lock reloading press mount
Top coat
http://i35.photobucket.com/albums/d200/ptsideshow/Shooting%20Reloading/IMG_1677.jpgLee Breech lock reloading press mount
Finished with the press mounted to the mount, before some room on the bench was cleared, and mounted.
will have to get a picture on the bench. :thumbup:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: Lee Breech lock reloading press mount
« Reply #1 on: October 19, 2014, 03:57:47 PM »
That looks purposeful, Glen!  :thumbup:
Takes me back to happier times.
In the loft with my Loadmaster. On the range, with my pistols........
All gone now.......  :(
« Reply #2 on: October 19, 2014, 06:56:20 PM »
Sturdy, red, what's not to like  :)
Get caught with one of those in the UK and you'd have some very fast talking to do...
Offline dawesy
« Reply #3 on: October 20, 2014, 02:08:35 PM »
Think you'd need to do some explaining if you had empty brass:/
Lovely bit of kit there ;)
Lee.
