Author Topic: Soldering oven, another daft idea?  (Read 13605 times)
« on: October 05, 2014, 06:33:36 PM »
There are a lot of parts in my atmospheric engine project that I need to assemble with a water tight seal.  All the parts are mild steel.
Due to the available facilities I am considering soft soldering and specifically oven soldering.  The idea is to 'tin' the mating surfaces, assemble the bits then heat in an oven so that the solder flows and I get a good seal.
Problem:  I dont have a suitable oven!
Maybe I can make an oven of bricks and mount a hot air gun to blow hot air in and heat everything,  gun claims 650C  and 2000W.  Is this another daft idea? :palm:
N.B.  I dont want to use a flame to heat as the combustion products foul the solder joins.
Offline AussieJimG
Re: Soldering oven, another daft idea?
« Reply #1 on: October 06, 2014, 01:21:57 AM »
That sounds like a rather clever idea John.
I am about to try my hand at one of Jan Ridders' Egg Cup Stirling engines for which he says the crankshaft should be soldered. I had been trying to figure out how to do this without pushing the pieces out of place with the soldering iron.
I am still a few weeks away from making the crankshaft but guess what I am going to try. http://madmodder.net/Smileys/default/happy0065.gif
Jim
Offline bp
« Reply #2 on: October 06, 2014, 02:44:35 AM »
I agree with Jim....a good idea, certainly worth pursuing!  My first thought was that it seems similar to a sort of low temperature "dip brazing" for use with al. alloy.
From memory soft solder melts at something around 450 degrees C, but solder for electronics is something less I believe.  No doubt the temperature range is governed by the makeup of the solder.
Certainly worth experimenting with.
Best of luck
cheers
Offline 75Plus
« Reply #3 on: October 06, 2014, 11:22:15 AM »
60/40 solder, as used on electronics, melts at around 370 degrees F which is well inside the range of kitchen ovens.
Joe
« Reply #4 on: October 06, 2014, 12:27:26 PM »
And failing that, using two oven elements (which can usually withstand 800°F for quite a while) mounted inside a refractory brick enclosure will often do the trick.  Wiring 220 VAC (assuming U.S. oven elements) requires attention to detail but is not too hard.  ???
Offline Swarfing
« Reply #5 on: October 06, 2014, 06:34:52 PM »
You could go for something like this on a smaller scale.
http://www.priority1signs.com/index.php?id=491
Once in hole stop digging.
« Reply #6 on: October 13, 2014, 10:47:45 AM »
Interesting John,  could you use a toasty oven ?  lot of the surface mount guys rework them for flow soldering.   My only concern with using the heat gun would be the need for a baffle, so nothing gets the full force of 650c
