Author Topic: Press brake for a 20 ton hydraulic press  (Read 15983 times)
  • Country: za
« on: August 20, 2014, 06:02:18 PM »
Hi,
I decided I wanted a press brake to bend the odd bit of metal. Looking around I came across this one http://www.swagoffroad.com/20-TON-Press-Brake-DIY-Builder-Kit_p_40.html
I quite liked this one so I based my design on the swagoffroad press brake - (loosely based on)  :)
Sorry guys this is a really good start I can't seem to find my folder with the photo's.
 :Doh:  :Doh:  :Doh:  :Doh:  :Doh:  :Doh:  :Doh:  :Doh:
Don't go away I'll find it.
  • Country: za
Re: Press brake for a 20 ton hydraulic press
« Reply #1 on: August 20, 2014, 06:45:11 PM »
The angle iron is 40mm x 6mm and the base plate is 150mm x 480mm x 12 mm thick
This is a drawing showing the bottom die my design on the right and the swagoffroad on the left ( I did say loosely based)
Having no way of bending 6mm thick steel I decided to weld two pieces of angle iron to a base plate to form the bottom die.
  • Country: za
« Reply #2 on: August 20, 2014, 07:10:51 PM »
Cleaned the angle iron and base plate ready for welding
As my welding is usually crap, I tacked it first and then welded a bit at a time so as not to cause too much distortion  :palm:
Finally all welded up, also cleaned up some of the welding to make it look a bit more presentable  :ddb:
So far so good  :lol:
« Reply #3 on: August 20, 2014, 11:35:50 PM »
Following along Dave  :coffee: :coffee:
Offline greenie
« Reply #4 on: August 21, 2014, 12:14:13 AM »
Here's a suggestion, with the base plate, drill a couple of holes in it, where the two bits of angle iron touch, so that you can get a weld onto those two inside edges. 20 ton and a couple of 6mm bits of angle iron will be a "no contest" and the angle iron will spread in the middle, without something holding it in place.
Just a suggestion only, use it wisely or not, choice is yours.
regards  greenie  :loco:
« Reply #5 on: August 21, 2014, 03:21:21 AM »
and, in a similar vein, not just as a 'liner' but also as an anti-spread mechanism ....
Take a third length of the angle and drop it into the V of the current two angles and you can weld along the top edges as the original design did with their M.
Also, if you plug-weld like greenie suggested, you could consider going deeper and maybe even reach the bottom of the new V
Offline GordonL
« Reply #6 on: August 21, 2014, 07:51:41 AM »
Too late now but the included angle in the bottom die should be less than 90° to compensate for spring back. With heavy duty press brakes they can get away with 90° because they are actually coining the part. When you are operating at near capacity of the brake you have to allow for spring back. I always bought 85° bottom dies when I owned my fabricating shop.
  • Country: za
« Reply #7 on: August 21, 2014, 08:17:26 AM »
Sorry guys, it is not clear from the photo's the two outer edges of the angle iron are welded all the way along to the base plate.
Thanks for your comments - keep them coming  :)
  • Country: za
« Reply #8 on: August 21, 2014, 08:42:11 AM »
Next was to make the guide posts and guide bushes.
The posts are 20mm dia the ends were stepped down to 16mm dia x 10mm long so that I had a shoulder to register on. Helps to keep it square, the guide posts were pressed into the base plate and welded on the underside.
The underside of the base plate with the weld cleaned up
  • Country: za
« Reply #9 on: August 21, 2014, 09:07:13 AM »
Next up the top die. This is a chunk of steel 20mm thick x 100mm high x 380mm long. This top die needs a 'pointy' bit along one of the long edges. I don't have a mill with a tilting head and I only have one vice that tilts. So in the end I just used the one vice I was a little apprehensive holding a 380mm long piece of steel in one vice but it worked out fine. May be because it was 20mm thick helped.  :scratch:
The 'pointy' bit being cut on the mill the angle of the V is 70deg. (included)
Finished
Just making sure it all fits
  • Country: za
« Reply #10 on: August 21, 2014, 10:49:16 AM »
Welded the top die to the guides, also notice a removable bottom die - just a piece of angle iron.
The welds have all been cleaned up to make them look respectable  :)
  • Country: za
« Reply #11 on: August 21, 2014, 11:01:00 AM »
Time for a quick paint job
Whot!!! ....................... I like yellow and it goes very nicely with the blue press  :lol:
A couple of things to notice I had to clean all the paint off the guide shafts - it didn't slide up and down very well with the paint.
The extra supports under the base of the press brake.
  • Country: za
« Reply #12 on: August 21, 2014, 02:08:11 PM »
I made a couple of locating 'lugs' helps to keep the brake press in the same place.
A 'cup' was made and fixed to the top die again to keep everything inline.
That's about it - finished. With removable bottom dies
Offline shipto
  • Redditch, UK
« Reply #13 on: August 21, 2014, 04:33:48 PM »
very nice I might make a smaller version for my fly press  :thumbup:
« Reply #14 on: August 21, 2014, 05:11:58 PM »
Dave,
Most importantly - does it work?
I know little about press brakes but the fillets in the removable dies look rather too generous to me.
« Reply #15 on: August 21, 2014, 05:38:08 PM »
Very nice looking brake! :clap:
It would be great to see something bent with it.
« Reply #16 on: August 21, 2014, 05:44:09 PM »
Hi Dave , You have made a nice job of the press brake  :drool: :drool:, you will have to do a few trial bends and show the results, how thick plate do you think it will bend ? What paint did you use to paint it yellow it seems to have covered really well , yellow is not good for coverage normally :palm:.
 Cheers Mick.
  • Country: za
« Reply #17 on: August 21, 2014, 06:08:39 PM »
Whot!!!! you want me to bend something  :Doh:
I post all these lovely pictures how I made it - that's after I lost the folder with all the pics  :palm: - Still haven't found it.
And you are still not satisfied and now I am expected to bend something. I didn't make this to bend bits of metal and scratch it all up.  :hammer:
I'm kidding guys  :lol:
I have a few bits I bent I'll post some pics.
  • Country: za
« Reply #18 on: August 21, 2014, 06:21:41 PM »
Hi Mick,
The paint was horrible - Rust-oleum 2X Ultra cover. Paint and primer in one can.
It is definitely twice the cover - if not 10 times  :lol:  It goes on really thick and I just wasn't use to it I suppose.  Normally with a rattle can I waft it with the paint and put 4 - 6 coats.
The press brake had two coats and it looks like it was dipped, sort of looks like it has a thick coat (which I don't care for much).
I think it is a different type of paint that just needs a different technique to use it.
  • Country: za
« Reply #19 on: August 21, 2014, 06:28:14 PM »
I can't do much about that - it how the angle iron comes  :thumbup:
Actually I can by stacking smaller angle sizes and if I finish with some aluminium angle 25 x 3 mm.
Also bending 5mm thick steel then those fillets are fine.  :thumbup:
  • Country: za
« Reply #20 on: August 21, 2014, 06:49:51 PM »
This was one of the first bends I did,  30mm x 5mm flat bar
Over cooked it a bit.
I have a few more bends I'll take a couple of photo's and post them.
« Reply #21 on: August 22, 2014, 12:38:06 PM »
Every thing looks great but couldn't you find a brighter shade of yellow? :Doh: :Doh:
Looks like you'll be able to build that better mouse trap now.  :lol: :lol: :lol:
Cheers :beer:
  • Country: za
« Reply #22 on: August 22, 2014, 04:34:50 PM »
Thanks Don,
That was the brightest shade of yellow I could find  :)
I've got fed up with greys and dark blues. I'm into the "brights"
Wait til you see the log splitter I'm building ...... Pink is looking good  :)
« Reply #23 on: August 22, 2014, 04:54:56 PM »
Hi Dave
With the price of every thing these days you can't be too particular any more.The main thing is that there is something to cover it up to save it from the rust for a while.
I'll be watching when you build the log splitter. It will remind me of the years when I wished I had one.  :D :D
Cheers :beer:
