Recent Posts
Pages: 1 ... 7 8 [9] 10
81
Announcements & Issues / Re: Security Warning
« Last post by vtsteam on May 26, 2026, 12:15:19 PM »
Just means Eric needs to renew the site's security certificate since it has apparently expired. It does not mean the site has been compromised, despite the browser Chicken Little warning.
82
New from Old / Re: Rebirth of a 6 Foot Flail Mower
« Last post by awemawson on May 26, 2026, 09:34:16 AM »
Small update: the self aligning 1-1/4" bearing sits on a 'Grass Guard' designed to stop grass entering the bearing.
Despite the fact that frankly it doesn't work I thought that I'd better make a new one, as the previous one suffered at the hands of the angle grinder while the seized 1-1/4" insert was cut off. Made from 1/8" mild steel the only bit that I had was horribly rusty and had a matrix of small holes drilled into it.
Well beggars can't be choosers so I pressed on though I had great fun getting a decent earth for the CNC Plasma Cutter, that I woke from a long and deep sleep not having been used in ages.
Came out acceptably for what it's for.;
83
« Last post by awemawson on May 26, 2026, 06:01:17 AM »
Well it's been working for a long time, but the flail mower has failed :bang:
Young lady driving it for me says the the rear roller isn't rolling. Well no it isn't as the right hand stub axle has parted from the roller - ten year of fatigue on the weld I expect. Much bending and distortion  - all a bit of a mess
It's possible that the spool that forms the stub axle is reusable if not bent - and the tube certainly is but both will need major clean ups before re-welding
I removed the right and left hand trailing skids to make access easier then tried removing the right hand bearing - no chance - firmly stuck - heat - hydraulic pullers - big hammers - no avail - need it on the bench to introduce it to an angle grinder.
In the end it only took one 4.5" disk - surprising as it's very hard steel:
This leaves the skid that got bent in the original failure and even more when I tried removing the bearing from the shaft !
Bent skid introduced to 60 ton press a few times in judicially placed places and it's somewhat better (but not perfect) - but after all they ARE self aligning bearings  :clap:
Putting the stub axle between centres on the lathe it seems to have survived without bending so I will re-use it
Replacement two mounting hole (130 mm spacing) RHP self aligning bearing housing with 1-1/4 insert ordered from Bearing Boys (?80 !) so update when it arrives.
84
OKMO R02 Denny Improved Ericsson Stirling Engine with Modifications
I made a new wooden plinth for this engine, made a larger copper cooling water tank and redid the piping for the new tank.
Greatly extended the run time with the larger cooling tank.
85
« Last post by tom osselton on May 25, 2026, 06:08:30 PM »
This is what I got for the last few days
86
« Last post by mcostello on May 25, 2026, 03:08:49 PM »
Just about every web board I frequent is having relog in warnings about security. Something is going on.
87
« Last post by ozzie46 on May 25, 2026, 06:54:20 AM »
yes i am getting it also.
Ron
88
« Last post by pycoed on May 25, 2026, 03:49:53 AM »
Is anyone else getting the Security warning issues again? Last few days it's popping up again for me (Ubuntu22/Brave 1.90.124)
89
Member Videos / Retrol SE-03 Steam Engine Plant & GF-01 Miniature Workshop
« Last post by Jim Dobson on May 21, 2026, 10:44:34 PM »
Retrol SE-03 Steam Engine Plant & GF-01 Miniature Workshop working under live steam and drilling some wood.
90
CNC / Re: It's new to me
« Last post by ddmckee54 on May 20, 2026, 01:18:57 AM »
Well...
Progress on this thread was slow enough already, but starting tomorrow it'll get even slower.  Tomorrow work on my new garage starts, or at least the demolition of the deck where the new garage will be located starts tomorrow.  It's going to be a busy summer.
