The Shop => Tools => Topic started by: RossJarvis on May 22, 2014, 05:41:40 AM
Title: Harrison M300 Starty Stoppy Handle
Post by: RossJarvis on May 22, 2014, 05:41:40 AM
Just wondering if anyone knows of Harrison M300 lathes wired up so that the "start stop" motor lever is pushed down to start in normal (chuck rolls toward you) mode.  The ones I've used before have always been pull up for forward and down for reverse.  However I've just been to a military training facility where it's down for forward and up for reverse.  Are there standard conventions?
Title: Re: Harrison M300 Starty Stoppy Handle
Post by: John Stevenson on May 22, 2014, 07:23:37 AM
No idea about standards but all my apron start machine are all down for forward because I'm used to that.
Post by: RossJarvis on May 22, 2014, 07:58:55 AM
I'm used to the other way round, The Scottish Instructor I was with thought it was some kind of English Eccentricity, as he was used to "up" for forward too.  It gave me a right bit of confusion whilst I was cutting a thread!! :bugeye:
Post by: lordedmond on May 22, 2014, 09:12:00 AM
All the ones I have installed when I was in work went the way the lever was pushed
Chuck goes down on the side that is near to you so did the handle
Stuart
Post by: RossJarvis on May 22, 2014, 09:25:36 AM
Stuart
I started thinking about that, it seems to make a lot of sense.  Though, bearing in mind it didn't stop when put into the stop position from reverse, it did make me wonder about the capabilities of who-ever wired it up :zap:
Post by: DavidA on May 22, 2014, 09:45:45 AM
At work,  our Elliot, the Colchester Triumph 2000 and our Harrison all use down for normal (forward) running.
Post by: Manxmodder on May 22, 2014, 09:57:32 AM
 The chuck direction following the handle direction seems logical and safe to me.
 I can't imagine why the other way round would ever be considered.....OZ.
Post by: Arbalist on May 26, 2014, 01:54:55 PM
We had several M300's where I used to work and it was "up" for conventional turning. There is of course another logic to this some of you may not have considered. "Up" is toward the operator and the chuck rotates towards you in the conventional manner, lever pushed down (away) and the chuck rotates away from you. You could of course argue that your it's only the top of the chuck that is moving towards or away from the operator but I believe most would concede that in conventional operation the chuck is moving toward you. Just my observation. Surprised that it can vary on a Lathe like a Harrison, maybe it's easily changed to suit the buyer/operator?
Post by: BaronJ on May 26, 2014, 05:36:34 PM
It probably depends upon which direction the motor is wired for.
However in the USA light switches are upside down compared to the UK !
Post by: vtsteam on May 26, 2014, 10:28:42 PM
I always imagined that switches used down for off in case something or someone fell against one, or in a mechanical emergency it was easier to manage a down throw. But I don't know if that's really why it became a convention.
Post by: Arbalist on May 27, 2014, 05:20:32 AM
Here in the UK it's easy to turn a lightswitch round the right way. Normally down to turn the lights on.
Post by: DavidA on May 27, 2014, 08:11:00 AM
Got to correct my post above.
The Elliott UniTool 48/4000 refered to does in fact start by lifting the handle.
Sorry about that.
Post by: BaronJ on May 27, 2014, 08:44:02 AM
Yes !  That is what I was told as well.  You can see the logic behind that convention.
Post by: BaronJ on May 27, 2014, 08:52:48 AM
Hi Guys,
I mentioned this about handle direction this morning to the foreman at an engineering works that I visit from time to time.  He laughed and said that they had machines in there that had handles the started machines running by moving them from left to right as well as up and down.  He did say that on occasion it caught you out when pushing a lever on a stationary machine and it didn't move in the direction you expected.
He also mentioned that some machine have gearboxes where the levers go in the opposite direction to others when selecting speed ranges.
Post by: lordedmond on May 27, 2014, 09:55:44 AM
Thats why in the distribution side of things and for rerouting of supplies
we always said and wrote "Close to ON and Open to OFF " that way any up or down right to left are eliminated  most HV breakers are rotary switches anyway
Back to the Topic in question I do not think there is any standard for the direction its usually down to the companies own style
All I can say all the lathes that I have installed from the toolroom lathe to the biggish ones were installed as per my previous post ( 48 " by 15 feet ) thats how the machine shop forman wanted them so thats what he got  :D
Stuart
Post by: Jonny on May 27, 2014, 03:31:03 PM
We had several M300's where I used to work    Surprised that it can vary on a Lathe like a Harrison, maybe it's easily changed to suit the buyer/operator?
Could well be mines an ex GKN and runs the correct way :thumbup:
Theres two switches which could either be swapped over complete with wiring or change wiring to each switch.
Not the same but along same lines the switches are like this
(http://images.maplinmedia.co.uk/low-cost-standard-microswitch-with-lever.jpg?w=283&h=283&r=4&o=ph$NViAQfdEppcdwGzXk6UJNSUAj&V=HYhH)
On earlier Harrisons with the clutch its left to right start, right to left brake and clutch release far better.
Post by: vtsteam on May 27, 2014, 11:14:30 PM
Just to confuse things further, seems like in old time monster movies, like Frankenstein, the oversized knife switches were thrown down to close.  :zap:
Post by: mattinker on May 28, 2014, 05:56:07 AM
Old time Frankinstein were using European regs!
Post by: Arbalist on May 28, 2014, 10:21:31 AM
Up to close on these.
(https://c2.staticflickr.com/2/1212/535048895_2bda885a04.jpg)
And of course on circuit breakers.
(http://img.directindustry.com/images_di/photo-g/miniature-circuit-breakers-55636-2476421.jpg)
Post by: vtsteam on May 28, 2014, 10:57:32 AM
Just too confusing!
Well thank goodness we all drive on the same side of the road at least.......or.......hmmmmm. :scratch:
Post by: Arbalist on May 28, 2014, 11:08:13 AM
No logic at all that I can see. We had a lot of MEM branded isolation switches where I used to work many years ago. The large high current ones had a lever swung upwards for On and the smaller ones a flick switch pushed down for On!
Post by: vtsteam on May 28, 2014, 11:24:08 AM
I think the switch designers really hit their iconoclastic stride when it came time to design automotive light switches. I can still remember the nearly universal foot switched headlight dimmer.
Now I usually end up turning on windshield wipers, etc. in a loaner vehicle hunting for the dimmer switch position and method on whatever stalk is closest to hand.
