Gallery, Projects and General => How do I?? => Topic started by: powderhorn01 on October 19, 2013, 12:02:00 AM
I have a broken 6/32 tap, about 1/2" deep in a thru hole, material is O1 tool steel. I understand that if it were a bronze, or similar, I could toss it in Alum and eat it out. Any ideas for getting it out, poormans homebrew edm, acid, or ??? It is a part for a model steam locomotive, Stevenson valve link. I would really like to save it, as I have a lot of time in it already.
:bang:
Any thoughts, or help, would be appreciated.
carbon steel or HSS tap
if HSS you are in deep do do ddm is possible
if its carbon steel tap heat the part to red heat and let it cool ( if you have a BBQ light it up and toss in the part leave it online till next day ( i.e. cool very slowly in the ashes ) and you may be lucky and it will have softened enough t drill out with a carbide drill
for lightly loaded threads try using less thread depth ( bigger drill by about 0.1 mm bigger
btw how big is a 6/32 tap anyway
Stuart
6/32 is around 1/4 inch in English money...
6/32 is around 1/8 inch in English money...
i used to be able to borrow these sorts of things from work
http://www.waltontools.com/products/remvtap.htm (http://www.waltontools.com/products/remvtap.htm)
sometimes worked, sometimes ended up with the tool busted in there!!! :doh:
John I am more confused now before I asked the question :Doh:
Stuart
I'm not conversant in American thread specs. Is that 6/32 32 threads per inch on a 6 guage ?
Andrew
http://www.zytrax.com/tech/mech/threads.htm
6 32 ~ 3.5mm
Gentlemen
:doh: :doh: According to the Machinist Handbook, 11th edition, published 1942, page 1266.
6-32 is 0.1380 inches Major diameter and 0.0974 inches Minor diameter. The pitch diameter is 0.1177 inches
This was known as the United States Standard but since 1935 has been known as American Standard Screw - Course-thread Series. :D :D
Cheers :beer:
I bet it's the coarse thread series unless it's perhaps a training course :lol:
Yeah, and "guage" is a small town in Kentucky.
The numbered screw formula is:
MD = 0.060 + 0.013 * N
where:
MD = major diameter in inches
N = screw number (0,1,2,3,4,5,6,8,10 ... 12 and 14 found in some very antique equipment).
Thank you gents the fog has lifted somewhat
anyway to the OP have you got that pesky tap out down the small hole
Stuart
One of last year's winter projects was a small EDM (tap buster) for just this situation.
http://homebuiltedmmachines.com/index.php?page=home
Works well but I want to re-do the electrolyte pump.
Were you closer I would give you access to the machine.
I have a Rocklinizer that deposits tungsten carbide to tool steel, at one time they made an attachment for a small EDM. The main unit is a power supply, the depositor is a vibrating handle, figure you change the electrode and reverse polarity? But before I try that would like to know more info! there is one on ebay way to high price! http://www.ebay.com/itm/Rocklinizer-500-Electric-Charge-Generator-with-EDM-Router-Model-9750A-/330660662115?pt=US_Heavy_Equipment&hash=item4cfce94b63
My Rocklinizer is a 600 a larger unit. A long time ago HSM or PIM did a series on a diy EDM (looks like I'm type alphabet soup!) About what year was that??
Just break whats left of the tap in the hole, works every time.
Jonny,
Will you explain the break whats left of the tap (without damaging the part) procedure? And the tools used?
Thank you.
oldgoaly,
I have had severe asthma all my adult life. The price of the Rocklinizer put me into a acute attack.
Unc,
that price is 500+ bucks off the original asking price! :bugeye:
I broke a tap off and have join the hunt for a tap zapper or making one of these work.
Rocklin the EDM looks like part of a portable drill press for the stand, the working mechanism is like a tattoo machine.
I also have a 314 I'll attach a couple of pics so you can break it down electronically. I replaced one cap on it metalized
polyester type.
Last broken tap I had, I lucked out. hit it a few times with a punch and then rotated a super magnet over it -- that unscrewed a few bits, and it was then clear. It was in an aluminum casting however, and the broken tap was close to the surface.
I saw a broken stud removed in a HSM article by laying a nut over the hole and welding through the nut hole a plug weld to the stud. Then the nut became the bolt head and the stud was unscrewed -- the heat and cooling from the weld supposedly also helped loosen the stud.
6-32 is way too small for that method, I guess.
It may be a bit small for the job, but I have to second the idea of smashing it to bits in the hole. I have had luck with a cold chisel and another tap ground to a point. Take your time and smash little bits at a time off. You may find if through hole that at some point you can force it through. It may damage the hole a bit but it can usually be chased later and still hold a fastener.
Isn't it great to enjoy a laugh? Seriously, there several ways to try( being the operative word) to do it.
One is to make a little dam with Plasticene or similar and put in nitric acid and stir the chemically changed bits out. It's long and tedious and-- you may not have a tiny drop of the stuff needed. Again, you can wedge a three fluted tool to fit the broken flutes- and chance your luck by twisting it loose. Again, you can use an arc welder or mig/mag and carefully weld an extension and go from there. Again, you can use a tiny carbon arc and destroy the core of the tap. Sheer bloody brute force is an added skill.
Again, you can throw the thing at the neighbours cat and make another one. Of course, you could regrind the next worn tap- which quixotically be blunter than the one which broke in the first place.
Regards
Norman
Since it is a through hole I would try to clrear the tap flutes from the un-threaded side using a har steel pin or wire and a small hammer. Fiddly work yes, but if the flutes are cleared it may even be possible to use a couple of steel wires to un-screw the tap afterwards.
BR
/Peter
BR
/Peter
That's effectively how a Walton tap remover works, but with the addition of supports (both internal and external) to minimise the chance of the pins shearing. Photos are of a 3-pin 5mm tap remover, hope you can see enough detail .....
(http://i789.photobucket.com/albums/yy177/DMIOM/Walton%20tap%20removal/Walton_1.jpg) (http://s789.photobucket.com/user/DMIOM/media/Walton%20tap%20removal/Walton_1.jpg.html)
(http://i789.photobucket.com/albums/yy177/DMIOM/Walton%20tap%20removal/Walton_2.jpg) (http://s789.photobucket.com/user/DMIOM/media/Walton%20tap%20removal/Walton_2.jpg.html)
With these, you :
- Clear the debris, then inject lube
- Slide the pins down into each flute
- Slide the central core pin down until it touches the core of the broken tap to keep the pins at the right radius
- Slide the body down until its on the workpiece to minimise the free length of the pins
- Jiggle to & fro with a tap wrench ...
The recommended tap drill size for a 6-32 thread is a #36. This is equal to 0.1065" or 2.71 mm. Small indeed for the welding, heating, bashing or wiggle, jiggle methods.
Can the hole location be moved? Can it be changed to a larger size? I have tried everything my limited brain power could come up with to solve similar situations. The two solutions that I have found that will work are EDM or making a new part.
The dull tap test is very effective, the dull one is the tap that just broke. Whenever I have tried the bashing method I have always had the same results. Both the 'basher' and the 'bashee' were damaged beyond use and a new part was needed. Perhaps flyingtractors has the proper cold chisel in his collection. Would that require a larger or smaller hammer? (OT, what is a flyingtractor?) The wiggle, jiggle tools belong in the same category as neck ties and high heel shoes. The hole size prevents the use of the left handed, self removing drills. A little online research will find some one time use EDM set ups that may help, such as the one that uses a door bell solenoid. Use this only when unwanted guests are expected. I have had no luck with chemicals as the errant tap is always of the wrong metal broken in the wrong metal. CH3CH2OH, in certain quantities, will help all of the mentioned processes.
I live in a rural area. There is a very rude black cat that travels my yard in the dark on occasion. He is not impressed with me even when threatened with extreme termination by use of explosive projectiles. The next time I break a tap I shall seek his assistance first.
The recommended tap drill size for a 6-32 thread is a #36. This is equal to 0.1065" or 2.71 mm. Small indeed for the welding, heating, bashing or wiggle, jiggle methods......
If by "wiggle, jiggle" you're referring to the proper Walton extractors, I must admit that I don't understand your "The wiggle, jiggle tools belong in the same category as neck ties and high heel shoes.". I've got a set as insurance when I've got a job I'm finishing against pressure - and they just work. I haven't had to use them often, but you just drop the tool in, loosen the tap by rotating a little in either direction & then just back the broken tap out; and in terms of sizes they go down to a US #4 (http://www.waltontools.com/products/extract-machsc-hand.htm)
Chances are that if the taps broke off in the hole its going to need as much if not more torque to unscrew. This rules out screwing them out.
Done loads over the years from 9BA to M16 usually HSS taps.
Bare in mind most of these busted taps were from a workmate in an irreplaceable part measured in 5 figures if had to replace.
Need something hard, now swings and roundabouts whether use softer than the HSS tap or not. Sods law if use something hard that breaks up without marking the busted tap. Use something soft it will bend up and deform, sharpen it up to a needle. Try and shear away one flute then another. Tap may break up in multiple layers in depth.
Just keep plugging away giving it some by whacking the tap with something.
It may damage the thread but what other alternative have you got, touch wood never scrapped a part yet even in softer aluminiums, various steels and titaniums.
Worst was a blind deep threaded hole ie 9BA 1/4" deep to the bottom, it can be done. 7BAx5/8" deep with 1.5mm meat surrounding to normal through tapped holes of a decent size. 3/16" and above its far easier and can see what your doing.
Might pay to keep changing direction if through hole and if can break one flute off it may unscrew from either direction.
If a standard tap extractor won't work, I've always had luck with Kroil, then jewelers pliers and patience.
There are needle nosed ring making jewelers pliers that will grip a 4-40 tap broke below the surface and let you turn it out. The pliers aren't cheap (being boxed jaw design and made from good grade of steel) but the last for years and ARE actually worth the cost.
Look online under "jewelery repair tools" and other such headings.
Have you got a Dremel or high speed micro air grinder? A very small abrasive point or diamond burr might do the trick - even if only to weaken the tap enough to break it.
Dmiom,
I was responding mostly to Mr. Omore's post based solely upon my own experience.
Jonny,
Thanks. It seems I have not tried the correct needle point tool.
I found myself in a similar situation and was able to make a crude spark erosion machine with very little effort. It lacks anything sophisticated, just being a rewound mains solenoid (if you have a 12v one use as is) and a car battery charger. I have only broken two taps, normally by using them when they are past the end of their life.
http://s917.photobucket.com/user/picclock/library/Spark%20erosion%20machine?sort=3&page=1
One end of the solenoid is connected to the battery charger, the other end of the charger to the work, the other end of the solenoid to the erosion tip. I used silver steel cos I had some lying around and paraffin for the liquid. See pictures. The reason it works and is simple is because the height of the electrode is self adjusting. As the electrode makes contact with the work a current flows in the winding which causes the solenoid to pull in. when the contact is broken the magnetic energy stored in the coil collapses, and that causes an arc to occur between the electrode and the work. After the field collapses gravity causes the electrode to fall and make contact repeating the cycle.
Its not very quick but you can leave it unattended - took about 2-3 hours. I chose an electrode size that would erode the core of the tap which it did without affecting the cut threads. Despite the 'design' it appeared to produce mimimal RF interferance, possibly because the spark is shielded by the work.
Hope this helps
best regards
picclock
I once broke a 2-56 tap in an aluminum head. Tried all of the usual extraction methods to no avail., including that dissolve it with alum, extractors, etc. Went down the street to the professional machinist and he put it in the Bridgeport and milled it out slightly oversize with a carbide mill. Then I put in an aluminum plug and drilled and threaded a new thread. Can barely see the plug. Problem solved low tech.
Mosey
That's pretty interesting! :thumbup:
Years back I had a commercial 'tap disintegrater' that was simple in the extreme. The electrode was carried in the end of the armature of a solenoid. When the weight of the armature brought the electrode into contact with the work, it completed the circuit and the solenoid pulled it back up. So it buzzed away merrily arcing away the tap. There was a little plastic tank with a tap to control the flow (just a steady dripping worked best) of tap water that washed away the debris and kept things cool. I used tungsten TIG electrodes.
aw, thats sounds really useful are they still available, that would be a cool project to build.
Joules
Sorry picclock, not had enough coffee and missed your post... :palm:
Not seen them for sale other than second hand, but it would be a trivial exercise building one.
Andrew, how many volts was that system supply? Was it battery powered or mains? Seems like for very occasional use, a battery powered version would be ideal, if possible.
Tempted to build one. I don't have a broken tap (uh, right now), but it just sounds like a fun project. And it would be nice to have it already made up when I need it rather than being an emergency project, or a wished for one.
Vsteam, I went down a similar road to Andrew and built a similar spark eroder to remove broken taps. I took the development a little bit further. The apparatus is descibed in detail here:
http://mikesworkshop.weebly.com/a-spark-erosion-apparatus.html
and here:
http://mikesworkshop.weebly.com/a-spark-erosion-apparatus-mk-3.html
Mike
It was 24v AC - just a simple transformer off the mains. It's working just like an ordinary bell, except instead of the contacts you have the work & electrode. But good enough to break up the bits of a tap - oh yes I've broken taps :bugeye:
Obviously pretty crude, and not a patch on a proper edm that controls the discharge and immerses everything in a dialectric fluid designed to hold off the discharge until the last microsecond. In a proper edm the dialectric expands and collapses explosively hundreds of thousands of times a second producing ultrasonic cavitation.
Powderhorn, Jonny,
Video of EDM tap removal using hardened punches.
[youtube]YbeKxFBZrF8[/youtube]
