Gallery, Projects and General => Gallery => Topic started by: Bangkok Mick on June 28, 2013, 07:52:35 AM
Title: Bloomers and cock ups learning to cut thread on the lathe
Post by: Bangkok Mick on June 28, 2013, 07:52:35 AM
Well as the title indicates I have been persevering and honing my skills on my new lathe and decided to try my hand at threading with a one point cutter tool instead of the tap & die method.
Yesterday I have produced a couple of prototypes but could not get them to screw together no matter what I tried. I checked the pitch to insure my threads were straight and compared the diameter of both male and female threads and everything appeared to be at least a good effort for a beginner but nothing worked, as soon as I tried to screw one into another they bound up and joined one another crocked and simply did not behave as expected so I gave up and decided to try again with a fresh start tomorrow.
Getting home from work today I tackled the problem again and realized that by turning the male and female threads using the lathe in the same orientation and direction on both cuts I was producing one right hand thread and one left hand thread that of course simply could not screw together.
Having resolved this problem I have since turned and threaded a hollow brass bar that can be screwed together and the action is very smooth and satisfying.
Cheers Mick
Title: Re: Bloomers and cock ups learning to cut thread on the lathe
Post by: awemawson on June 28, 2013, 08:28:34 AM
Well done - it's all a learning experience.
Post by: Jonny on June 28, 2013, 10:19:21 AM
Good practice Mick and true its gratifying.
Sounds like wrong hand tool on female thread?
Done it all, wrong tips for thread on finished product to wrong pitch but right tip. Spindle startup 800 rpm on a short thread glad of foot brake. Check and check again no ones fallible.
Dare say you have realised now that you can actually make your own matching male and female thread up, one reason I like metric. Gets a bit tricky say UNC with metric pitch.
Post by: Bangkok Mick on June 28, 2013, 11:07:36 AM
Thanks for the feed back guys, learning must be the best part.
Cheers Mick
Post by: awemawson on June 28, 2013, 11:12:14 AM
When you stop learning you must have either stopped doing or listening or both  :thumbup:
Post by: DavidA on June 28, 2013, 01:26:23 PM
Not sure what is going on here.
To cut a left hand thread  (never done it ) don't you have to apply the cut while moving away from the chuck ?
Both internal and external right hand threats are made towards the chuck.
Or am I having a senior moment here ?
Dave :scratch:
Post by: unc1esteve on June 28, 2013, 04:49:09 PM
You are correct.  The cross slide must also be re-positioned.
Post by: DavidA on June 28, 2013, 07:36:05 PM
Mick,
What exactly do you mean by ...
..Getting home from work today I tackled the problem again and realized that by turning the male and female threads using the lathe in the same orientation and direction on both cuts I was producing one right hand thread and one left hand thread that of course simply could not screw together.
Sorry for the question,  but I can't visualize what you did.
Post by: Bangkok Mick on June 29, 2013, 03:59:04 AM
I guess cutting a left hand thread away from the chuck is the correct way but I cut both internal and external threads towards the chuck and came up with opposing threads.
I had the lead screw engaged in revers so I could arrange the cutter on the far side of the internal thread so I would be able to see it cutting the thread as it proceeded. This also caused the thread to cut an opposing thread.
Post by: DavidA on June 29, 2013, 06:18:09 AM
Still don't see how this would give you a left hand thread;  unless you were running the lathe mandrel in reverse.  But I'll let it go at that.
Clearly I need stronger coffee to clear my old brain.
Cheers,
Dave. :scratch:
Post by: NeoTech on June 29, 2013, 06:53:07 AM
He prob cut one thread from right to left and the inside thread from left to right.
Post by: DavidA on June 29, 2013, 08:19:41 AM
Neotech,
That is what I am trying to work out. But he (apparently) says not.
If the tool in the picture is the right way up,  and the lathe is turning in the conventional direction, then it wouldn't cut. So the tool has to be upside down.
But he writes,
.. turning the male and female threads using the lathe in the same orientation and direction on both cuts I was producing one right hand thread and one left hand thread ..
This and,
...I had the lead screw engaged in revers so I could arrange the cutter on the far side of the internal thread ...
If this means driving the saddle back towards the tailstock it would need the chuck to be turning clockwise (backwards to normal)  viewed from the front. This could unscrew it.
Very confusing.
Post by: Bangkok Mick on June 29, 2013, 08:34:48 AM
Sorry, some clarification.
The chuck was turning backwards, “clockwise”  but I was also moving the tool towards the chuck with tool facing upwards, my first attempt so still learning the correct procedure.
Post by: DavidA on June 29, 2013, 08:47:12 AM
Mick,
Thanks.  That clears it all up.  I think 'unconventional' is the term.
Post by: Meldonmech on June 29, 2013, 09:07:51 AM
Hi Mick,
                 Well that is one lesson you will never forget, they say the best way to learn is by your mistakes.
                                       keep forging ahead ,         Cheers  David
Post by: NeoTech on June 29, 2013, 10:54:58 AM
Agreed, that would clear it up. But i imagine you learned your lesson from that. =)
Im a bit lazy when turning inside threads.. preventing tool crashes and such.. so i usually set it up so i cut from the bottom and out instead but reversing the chuck so it cuts the right hand thread in reverse (does that makes sense?). When i figured that one out i ended with having problems cutting internal threads where i couldnt see the bottom of the hole properly. =)
Post by: Jonny on June 30, 2013, 04:00:19 PM
Exactly what I thought Mick, need opposite hand tool.
For an external left hand thread can start at chuck end or mount tool on opposite side and spin up clockwise.
No need to adjust compound the pros don't.
Post by: Bangkok Mick on July 01, 2013, 02:31:13 AM
How can you bottom with no cross slide or compound adjustment for setting the depth of the cuts?
Post by: Bangkok Mick on July 01, 2013, 02:34:20 AM
Post by: NeoTech on July 01, 2013, 08:46:29 AM
Cuz i dont cut threads with the compound, just a straight plunge cut, i havent bothered about setting angles and such. It works just goes slower. But i guess its not the recommended solution.
Make a  little "slot" in the bottom to start the thread from and just figure out how deep you are taking the cut by setting a dial indicator on the cross slide. And figure out forehand how deep your gonna make the thread.
Post by: Jonny on July 01, 2013, 10:20:31 AM
Thats the conventional way of doing it Neo and how the pros do it for repetition work.
In fact its exactly how a high speed threading machine works, used an Elliot some years ago.
Post by: DavidA on July 01, 2013, 11:28:57 AM
Same way I did it at work.  Just reduce the amount cut each pass as the cut gets deeper.
Post by: unc1esteve on July 01, 2013, 04:21:18 PM
Not trying to start an argument.
There have been many instructions from our predecessors about cutting threads.
Many articles in published books.
I am a 'pro'.
I strive for accuracy and efficiency.
I cut threads using the compound.  The depth of cut can be easily controlled.
I am not lazy so I use the procedures I was taught and have read about.
I am not in a hurry so I try to make the best thread I can so I do not have to do it over.
I believe that learning how to cut a thread by using the cross slide and a single point tool set at the correct angle will be of benefit.
Post by: DavidA on July 01, 2013, 04:36:20 PM
I don't think anyone is arguing about anything.  Just discussing different ways of arriving at the same end.
All your points are valid.
Most of the time modellers tend to be cutting small pitch threads that don't seem to need the set-over method.
Post by: NeoTech on July 02, 2013, 03:03:18 AM
Yeah, and most of us are not pros and have figured out how to cut thread by ourselves not fully understanding most books in the subject.. *at least not me*
I found it to be a damn struggle the first couple of times. And now i have found a way that suits me.. =)
Post by: Stilldrillin on July 02, 2013, 03:54:18 AM
Is it Me?  :scratch:
I was taught to screwcut in the apprentice school, 1960. Then, spent a lifetime machining.
I have NEVER have seen an angled compound, for screwcutting purposes...... (http://www.freesmileys.org/smileys/smiley-confused013.gif) (http://www.freesmileys.org/smileys.php)
Post by: vtsteam on July 02, 2013, 09:39:52 AM
Debate about this has appeared in the model engineering press for a long time. Not really debate, I guess, maybe more like discussion.
Anyway, I'll hazard a guess about why. Small lightly built and homemade lathes, like my Gingery lathe in its original form have low bed, spindle, and carriage stiffness and mass. Avoiding chatter in machining operations becomes a priority by comparison with manufactured cast iron hobbyist lathes, not to mention commercial and industrial practice. It means taking very light cuts, and a long time to do some things, and any procedure that can increase that cut depth or reduce that time is a boon.
Straight plunge cuts to any depth with form tools are often out of the question. So, methods become popular that reduce the contact cutting surface in plunge cutting. I'm guessing that's why the compound set over method was developed. It wouldn't be so important for a heavier lathe, and I can understand why commercial screw cutting machines and industrial lathes just cut straight on.
Post by: unc1esteve on July 02, 2013, 10:43:21 AM
Perhaps I should have worded my post differently, not sounding as if I was criticizing.
I have seen incorrect, sometimes unsafe advice given on machining sites.  Usually to novices.  I think we would all be served if we encouraged each other to learn the traditional (I do not want to say 'proper') manual machining methods first.  Then, when one feels that he has learned and is comfortable, make whatever changes he chooses.  I believe Bangkok Mick would benefit from at least reading instructions on 'how to cut a thread on a lathe'.  I suppose I have a problem with 'been there done that' advice as it does not exchange knowledge.
I was taught and do the opposite of Stilldriling concerning cutting screw threads on a manual lathe.
One thing I do differently is to grind the cutting tool with a top and back rake.  It makes a much cleaner cut with a better finish.
Post by: DavidA on July 02, 2013, 01:06:21 PM
It does seem to come down to the way you were taught. Where I worked there were three other machinists.  Non of them had even heard to the idea of setting over the topslide.  I had never heard of it until I started with my own lathe and began reading the hobby journals.
I suppose it is a case of whatever works for you.  you use.
Post by: Bangkok Mick on July 02, 2013, 11:08:41 PM
Just for clarity I am also reading up on and researching the internet as I go and trying to apply each different method to see what works best including safety.
I have tried setting the compound at 60deg. And this was a successful exercise but as I am cutting soft material such as aluminum and brass a parallel compound is also working out, still it is good to practice each way for future reference.
Thanks for all the feed back to this thread.
Post by: unc1esteve on July 03, 2013, 11:01:16 AM
I just ordered this.
http://www.bookdepository.com/Screw-cutting-Lathe-Martin-Cleeve/9780852428382
Post by: Bangkok Mick on July 03, 2013, 10:49:06 PM
Thanks for the tip Steve, living in Thailand and with free shipping worldwide I just placed an order for the same with a couple more on mini lathes.
Cheers Mick
Post by: andyf on July 04, 2013, 12:49:55 AM
Well worth the money. An invaluable reference book, containing just about everything you might ever ask about single point threading. Being written in the UK when Myfords were the standard model engineering lathe, it leans a bit towards those and imperial leadsscrews, but if you want to know how to cut metric threads with those (and vice versa) it will tell you 101 ways of doing it without a 127T gear for an exact conversion.
PS Mick, if you want to practise threading, PVC pipe is cheap.
Post by: Jonny on July 04, 2013, 09:58:51 AM
Firstly theres no right or wrong way as long as it works.
Its pretty much was I was inferring Vtsteam and Stilldrillin. You have books written by model engineers often self taught and then writing books, whos right.
One thing for certain any production based practice would need quality work at quickest amount of time.
I buy full form replaceable tips with relief already in them, no need to change any change wheels around I just dial it in with four knobs any pitch metric or imperial and would never ever contemplate looking at another lathe that I couldn't do that.
Post by: vtsteam on July 04, 2013, 10:44:17 AM
I'm happy that commercial outfits have needs that can be fulfilled for their purposes, and share those techniques, and that self taught hobbyist engineers also share their experiences and methods, even writing books about those. Seems everybody can learn a few new tricks from someone in a different line of experience and equipment. There's nothing wrong with being self taught, nor apprenticing 40 years ago in a production facility. And nothing wrong with a treadle lathe using gravers, nor a CNC 5 axis machine or anything in between. Attitude is the important thing, I get tired of forums with people who start pounding home right and wrong according to their singular experience.
Post by: unc1esteve on July 18, 2013, 06:20:55 PM
BangkokMick,
I received my book 'Screwcutting In The Lathe' and have skimmed through it several times.  Lots of good, useful information, especially for cutting a thread to specifications.  I have several other books from this series that I find useful.  I am an old man and I like referring to the hard copies.  I have used 'Gears and Gear Cutting' many times.
It did not, however, have a description of the procedures of cutting threads with the straight in method or the top slide method.
Machine Shop Practice, volume 1, K E Moltrecht, has a step by step description of the two procedures.  How to books such as Machining Fundamentals, John R Walker, also explain the steps involved.  Books like Machine Shop Trade Secrets, James A. Harvey, add many useful tips.  Though I have not seen a reference to the way I sharpen my tool bit.
I have been thinking a lot about threading since I made my post.  It seems so easy for me to make a thread but Why is it easy?  I remember the first thread I cut.  1" x 8tpi.
I just followed step 1, step 2, etc., after doing research, (reading).   But again, why is it easy?
I think about Stilldrilling's comment about never seeing a set over top slide.
George H Thomas, The Model Engineers Workshop Manual, gave a good description of thread cutting and also a quick, retracting tool holder.
I have no references from the gentleman that called himself Tubal Cain.  I would like to start collecting his books.
I have come to no conclusions.
But I am going to make a rapid retracting lever for my lathe's cross slide.  I think this would be of benefit for more than cutting threads.
Post by: andyf on July 18, 2013, 07:23:50 PM
BangkokMick,
I received my book 'Screwcutting In The Lathe' ....   It did not, however, have a description of the procedures of cutting threads with the straight in method or the top slide method.
My copy does, Steve, though it doesn't take up much room - pages 136 to 140. A bit hard to notice after your brains have been boiled by the preceding pages of mathematics!
Andy.
Post by: Bangkok Mick on July 18, 2013, 09:51:31 PM
My copy was also waiting for me when I got home from work yesterday along with two other books on lathe works from the same series. I have only had time for a flip through each book last night but will look for the info on the straight in method on pages 136/140 when I get home today.
As I am using small diameter brass most of the time I guess this method will be a useful one to adopt but will also practice the 60 degree compound method for when I start cutting harder materials.
All in all from my cursory look through I see a lot of good tips and ideas in these books so will have some home reading to do over the next couple of weeks.
Cheers Mick
Post by: unc1esteve on July 18, 2013, 10:26:55 PM
andyf, Mick,
I did read section 8, but it was not the kind of step by step instruction I was looking for to refer to.  I find threading to be no more or less difficult than any other process on the lathe.  It is just a mater of manipulating this lever or dial in a certain order.  Metrics on my lathe is just a matter of changing one gear.
What I am trying to understand are statements like Neotech's about learning to cut threads to be a 'damn struggle' when I do not find it a struggle.  I enjoy cutting threads and am thinking about his struggle.  For instance depth of cut.  I use a chart that was printed in a popular magazine that shows a standard depth for a standard number of threads.  Set the dial to zero and then cut to depth.
I am pleased that Mick finds my suggestion about 'Screwcutting In The Lathe' to be of benefit.
Mick,
I was in Thailand when I was in the Army many lifetimes ago.  A beautiful country with more beautiful women.  I was in Bangkok in '69'.  I can not remember being that young.
Bookdepository has several volumes by Tom Walshaw, aka Tubal Cain.  He was refereed to in a post I made about lathes cutting a concave.
Post by: lordedmond on July 19, 2013, 03:09:25 AM
Set over screw cutting well evan with a big Colchester lathe its still done, if you are un clear how the taper was cut he has a hydraulic tracer unit fitted
take a look
he explains it and shows how sets up the machine evan down to the reason for the position of the cross slide handle , also note the dial gage to show the total in feed
I do not know if its in one of the above but he get on his high horse about back lash his cross slide has about 1/4 inch slop yet he can hold a part to better than a thou , its how you do it
Stuart
Ps he has 310 video's all show some interesting machining , I am not to enamoured with the use of a file but its his work not mine
Post by: DavidA on July 19, 2013, 08:43:04 AM
It is interesting how the set-over top slide  is being referred  to as the correct way to cut a thread.
At work we have two CNC lathes.  One is a Guildermeister (can't remember what the other is;  I don't use it) and this machine uses a straight in approach. It gradually reduces the depth of cut as it goes. Same goes for the other machine.
Can anyone recall a CNC thread cutting lathe that uses set-over ?
Not wishing to pour petrol on the fire here,  just curious.
Post by: Stilldrillin on July 19, 2013, 09:05:49 AM
Haas, Mazak(x5!), Mori Seiki, Tos.  :thumbup: .........  Nope!  :scratch:
Post by: mosey on July 19, 2013, 10:04:13 AM
Beginner here!
On page 77 of "How to run a lathe", South Bend Lathe Co., it says under "position of compound rest for cutting screw threads". "in manufacturing plants where maximum production is desired, it is customary to place the compound rest of the lathe at an angle of 29  degrees for cutting screw threads."
This is obviously relevant to 60 degree threads.
Is this what you mean when you say "setting the top-slide over"?
It works for me. Also, in questioning several professional machinists, they've never used a threading stop. Curious. I find that stops frequently slip, ruining the thread.
 :med:
Mosey
Post by: unc1esteve on August 02, 2013, 05:39:12 PM
Bangkok Mick,
I purchased the book by Tom Walshaw, Model Engineer's Handbook from The Book Depository.
Thought he might have a step by step description of screw cutting but he did not.
I liked it so I purchased five more of his books.
This is a good source and the free world wide shipping is very good.
Habits are difficult to change.  I built a Bonelle T&C Grinder to sharpen tools but
find I still sharpen by hand.  The T&CG sharpened tool makes a much more smooth
and accurate cut.  I am forcing myself to use the Bonelle first, even if only for a touch up.
Post by: Bangkok Mick on August 03, 2013, 09:06:35 AM
Hi Steve,
I also used the Book Depositary and living in Bangkok appreciated the free postage service.
Cheers Mick
Post by: JTisher on August 17, 2013, 09:14:50 PM
  Hi all, It's been a long time sense I've posted ,or been on the site but I have to comment. I learned single point threading from the internet, not easy when know one's around to show you how.
  One thing I did learn though is on the east side of the pond know one offsets the compound. On the west side everyone thinks your an idiot if you don't offset the compound.
  I'm glade I don't care what people think of me.  ;)
  The thing is, learning online I've done both and they both work equally well ,sometimes (don,t ask :() so... do whatever works and that your comfortable with
P.S. Be happy if you have a tight lathe and a threading dial
