Gallery, Projects and General => How do I?? => Topic started by: Lykle on March 29, 2013, 07:04:35 AM
It seems that the more I make, the less I know.
Things that seem to be quite straight forward turn out to be not so easy in real life. Live and learn.
So, I made the body of the Trebuchet and it looks a bit messy. To clean up the look, I think I want to put a chamfer on the edge of the hole. I would like it to be an even 2mm all around.
Looking at it, I think I have concluded there is no way I can do this with clever tooling or such. The only way I think I can do it now is with the little deburring tool like this one:
(http://www.littlemachineshop.com/Products/Images/480/480.1671.jpg)
Or use a Dremel but then getting it an even 2 mm all around is going to be tricky.
Any better ideas?
This is a picture of the part as it is now. I know the surface is not what it needs to be yet, that will come.
Maybe something like this, since you have a small bearing-pilot hole inside....
EDIT: lower stop collar sets angle of cut, not depth.
Decent knife will do a better job than a deburer, quicker and more controllable too. I have to debur irregular shapes, tried many a thing two decades ago then found a knife some one made me and still used daily.
Nice sweeping flow or it will dig in.
Ha! Nice sketch!
That would vary the angle of the cut along the hole, but it would work. I will think about it.
Another tool to build, mama!
Using a knife? Never thought of that, I will have to try that on a scrap piece first.
Not sure what I am going to do yet. Wanted to leave it unchamfered, but I am afraid the edge will look a bit messy.
You need to vary the angle of the cut along the hole if you are to meet your original spec of an even 2 mm land all around. Hence the design. :dremel:
I would change two things on further consideration.
1.) The fixed arm shouldn't be tapped for the screw, but just make it a sliding fit, and fit a plunger (instead of a screw) to pass through the top of the arm and topped with a small knob. That way you can apply hand pressure instead of depending on the spring.
2.) Put a knob on top of the pilot shaft, as well. Could be just a second stop collar.
Hi,
I normally use a small half round or triangular scraper, made by Moore & Wright.
