The Shop => Tools => Topic started by: Rob.Wilson on February 10, 2013, 12:59:17 PM
Afternoon lads .
Well I found a wee project to mess about with , something that has bugged me for the passed 20 years :lol: , the jaws in my #5 Record bench vice .
There fooking crap for holding finished parts , great for destroying the look of a freshly made part . :lol:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060121.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060122.jpg)
So you end up fitting soft jaws ,
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060123.jpg)
AND there just as crap ,they fall off if you fart in there direction ,you cant grip thin work on the very edges .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060127.jpg)
The rap around type are just as bad , and the magnetic ones ,well all they do is attract the fillings :palm: , and the real problem with soft jaws is there soft , fillings get embedded in the soft material and scratch the job :(
So my plan is make a set of hardened and ground jaws .
Work so far today .
A set with vertical vee's
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060137.jpg)
A set with HZ step and vee's of different sizes
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060139.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060140.jpg)
A plane faced set with pin holes in top face
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060138.jpg)
and because undoing screws every time in need to change the jaws is too much like hard work , I am making them quick change .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060141.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060142.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060143.jpg)
Edit : above still need hardening
Evening Rob.
Another masterful RW production! :thumbup: :bow: :clap:
:drool: :drool:
Love the Quick change idea Rob simple really, Why the chrome plating though lol.
Now...... That's cute, Rob! :bugeye:
Blummin good thinking, all the way through. :clap: :clap:
Well done! :thumbup:
Nice very nice :thumbup: :thumbup: :bow: :bow:
You are not joking about the jaw protectors falling off at the slightest chance :lol: :lol: :lol:
Afternoon lads .
They just drop in place over tophat or you have a cunning plan to tighten them?
Thanks Lads :beer:
Spot on Pekka :thumbup: they will just drop in place over top hat screws ,,,,,,,,,,, nice and simple :med:
I have just surface ground the grip hatch pattern off mine, now hard and smooth and just give a quick clean up lick every now and again.
I just wish i could machine something that the vice would mark
:bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye:
Sticky Dots :thumbup:
Shove 'em in the recesses where the c/s screws are.
They fail after a couple of months so just stuff some more in.
Fartproof .. or I assume they are. I was brought up to be polite and I go out of the shop when I need to yield a rasper.
Geordies may well have different practices ... :palm:
Dave BC
Really nice idea Rob :thumbup:
Looking at the set, something tells me that it might be useful to put a thread in some of the holes in the "Swiss cheese jaws". Something like 6 to 8 mm (1/4" to 5/16"). Would act as the fourth hand that always is missing ...
BR
/Peter
I thought about doing just that John ,,,,,,,but thought sod it why not make the vice a bit more user friendly :med:
:lol: :lol: :lol: :lol: Dave ,,,,,,,, Geordies have different practices ,something to do with the beer :Doh:
Hi Peter
There will be hardened pins going into those holes :dremel:
:bow:
Just got myself an old Record No.3 yesterday... your jaws look great. On the list of things to do!
:bow:
I still use the same Record No 3 that I bought with my first weeks wages in 1967 !!!!!!
Bloody brill those Rob, Bloody brill, :bow: :bow: :bow: :bow: :bow: :bow: The only very small point i would question is the hardened pins !!! I have visions of a tad too tight and half a pin flying of into the great unknown leaving the bottom of the workpiece very scratched on the remains of the half left in the jaw. Based on previous encounters with broken pins.
Cheers Dek.
P.S. The broken bit would also be a pig to remove. Still a bloody brill idea, i will even hold back work on the clock to make some. :ddb: :ddb: :ddb:
Top marks Rob , a simple but cunning idea :) as usual all done to top standard :bow: :bow: :drool: :drool: ...............looks like another thing for the to do list :palm: , probably one of the most worthwhile as the vice is always in use :thumbup:
Cheers for posting Mick. :beer:
Oh great! Now I have another project to add to my to do list. :doh:
Hi Rob,
Almost up to your usual standard. :beer:
I sent you a email on 03-Feb-2013 did you receive it...................... :offtopic:
Kindest Regards
Beagles
very nice rob good idea.once you have the mill set up its just as easy to make 4 or 5 sets of each,say for me,jhon,mick,and bob. :wave:
Cheers Lads :)
Hi Dek ,,,,,,, I did ponder that very problem (sheared off pin ), I think I may have it covered in my pin design :smart:
The pins are a light push fit in the holes and I also wanted to add some flexibility into the pins , guaranteed they will be too long /too short for the job in hand , so I am making them adjustable :med:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060144.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060147.jpg)
From 1 mm
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060149.jpg)
to 6mm
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060148.jpg)
being threaded to a depth of 1 mm from the top if i shear one I can screw a screw in from the top and extract it :dremel:
:Doh: dont stop the clock build :poke:
You could always take the holes all the way through at a smaller diameter, Rob. Then sheared pins could be pushed out from below. Too late if the jaws have already been hardened.
I too have a Record no 5, and I think I'll follow your lead. I also have a 3" Record. I reversed the jaws on that one, with thin Ally pads to "absorb" the serrations. It's good for holding flat stuff without marking it.
Cheers Lads :)
From 1 mm
to 6mm
If you look real close you can see machine marks on the pictures
(look like they have been fly cut) :lol: :lol: :lol: :lol: :lol:
Hi Andy
Yes , I did consider doing that too :thumbup: I also have an unusual vice I picked up on Ebay for a couple of quid .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060151.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060150.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060154.jpg)
It has some nice features , anyway if i mount it directly to the bench it would be way to low for me , so i am going to make a plate to mount the vice in the larger vice .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060153.jpg)
which will bring it up to a better working high for me . Any of you lads recognize the vice ? no makers name on it .
Sweet solution to an old problem Rob :clap:
I was chatting to Dek today and he described the vice jaws. Very good idea. :thumbup:
I'm sure it'll be copied a great deal (shame about the lack of royalties! Watch some bugger rob the design like they did the ball turners! )
Oh, BTW... Fancy delaying Dek's work on the super clock! :wack: (don't know it's official title?)
The clock is nothing short of a work of genius :smart: Took me a good few min's to understand the inner workings :borg: As much as I want one, there is no way I'm going to attempt to build one, I ain't that good! or patient :)
Ralph.
The pins look good Rob, Like Peter says you may aswell do a batch next time :clap: , That little vice looks interesting and a handy bit of kit :drool: I bet there will be hundreds of your 'Patented' vice jaws about in a few weeks lol :lol: ................... you wont get no money................ but you might go to heaven :med: :med: :med:
Cheers Mick. :beer:
Rob,
You can't use those works of art on that poxy old vice, you will have to completely restore it and polish it all over.
Very nice work Rob!
Rob,
:lol: :lol: :lol: :lol: nope they will just get slapped into "that poxy old vice" when done David :lol: :lol: :lol: well I may slap some fresh paint on the vice .
Another brill idea with the pins Rob, but please dont come up with any more jobs to do. :wack: I allready have enough to keep me going for the next 10 years at least, (says he more in hope than expectation aged 72 with emphysema) :med:
Ralph you bloody creep ! wots orl dis genius baloney, all dem bits and you just go swearing about me. :beer:
Cheers Dek.
well dun rob
:lol:
You know I'm right :thumbup:
One of these days I'm gonna make something worth showing off about.... But it ain't gonna be a super clock! Far too advanced :loco: :lol:
When I get a few days I'm certainly gonna make up some vice jaws.... My aluminium ones are getting very tired.
Don't got none of that super chrome steel that they have up north, so they'll probably be made from old garage door bits :scratch:
Not too sure about hardened ones.... But the beauty of owning these machines.... you can always make more :dremel:
Ralph.
Well Rob, it's a bit pointless to design and build something like those jaws and not know for sure that it's an interchangeable parts fit. I just happen to own another 5" Record I bought before they closed up shop maybe 15? years ago. With some proper arm twisting and maybe a keg of the British finest shipped over, I just might be willing to test those new jaws on my vise for you. Honestly there's no real thanks nessisary. I'd just feel guilty if you tried. If they do fit? Well then you'll know it's a good accurate design and you can then build another set for your vise. :beer:
:lol: Cheers lads :beer:
I knocked up the shouldered screws this morning :dremel:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060157.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060160.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060163.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060167.jpg)
hopefully I will get time this weekend to hardened all the parts .
Looks like another one just about off the list. Excellent workmanship as usual. Thanks for sharing with us.
Cheers :beer:
Thanks Don :beer:
Well there not looking so good now :lol: hardened
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060169.jpg)
And I have a wee problem with two of them :Doh: , the buggers cracked ,BADLY :lol:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060172.jpg)
Those two I just left in the pickle over night that why the surface looks so ruff /corroded , I will dig out my crack test sprays and see if the others have any fine cracks I cant see with the old eyes . Either way I will be milling up a few new jaws :lol: :lol: :lol: :lol:
Rob,
That's very frustrating. The crack along the face looks odd as it doesn't seem to stem from anywhere in particular.
What material are they made from? Were you case hardening or through hardening?
Could you possibly stop-drill, tig weld a nice deep puddle, and regrind to hide the weld? :thumbup:
Rich
Hi Rich
Frustrating , sort of ,it happens , I am sure I will learn something form it :med:
Wish I new , did the usual scratch and sniff test (spark test) can up high carbon , did sample pieces with saw cuts/vee's machined in ,carried out a brine,water and oil quench all came out fine .Probably next time go for the softer quench ,oil instead of water .
went for through hardening.
Odd that just two cracked , the one with the crack on the face stems from the bottom of the pin holes :palm:
Rather just make a new set :dremel:
Nice work Rob (there really should be a dedicated "nice work Rob" smiley).
What about case hardening the jaws?
Hi Rob , sorry to see them cracks like that :palm: :palm: ..........the only silver lining ( if there is one ) is you will probably figure out what caused it and be able to avoid happening in future projects that you might have spent more time on. Oh if your making full new sets ...........dont go throwing anything in the bin ............ I know someone that might try practicing T.I.G welding on parts something like that :wave: :wave: :dremel: :thumbup: :lol:
:beer: Cheers Mick
A true craftsman to do work that well, and take it in stride when a step didn't turn out, and make it again, better even than before, And showing the problems so we can all learn.
:bow:
That's a bummer rob all that hard graft down the pan. Never mind rob I'm sure you will get it right next time :nrocks:
Hi Mayhem
Case hardening would be one option , BUT they would need to be pack hardened/box to get a good depth of case to allow for any distortion to be removed by surface grinding , I would have gone that rout if they hard fit in my case hardening box , 1/2 inch too long :palm:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060178.jpg)
:bow:
Hi Vtsteam ,,,,,,, Some days things dont go to plan ,would of if I new exactly what I was trying to harden :lol: , either way it has give me a chance to change a few things in the new jaws :med:
:beer: Cheers Mick
:lol: :lol: :lol: are you sure Mick ,,,,,, did a bit destructive testing , took a sledge hammer and an anvil to bust :lol: :lol: :lol: :lol: :lol:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060188.jpg)
Hi Peter ,,,, It happens :)
Well my plans went out the window, wile cracking on with making a new set of jaws,minding my own business I here the thud thud thud of an old motor cycle put up ,my mate on his Norton ,in he comes jibbering on about Stafford show ,centre circle and needing his Triton built in six weeks ,so I have now been roped into helping out :Doh: Then mentioned do I want a Beaver mill for nowt . went and had a look.
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_20130224_160444.jpg)
Just a tad too large for my needs :lol: :lol: so it ended up skipped , but I did whip the slotting head off, may come in handy :dremel:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060193.jpg)
and wile rummaging around the scrap I stumbled across a Elliot vice , bit rusty , but not drilled another one to add to my collection of vice's that need attention .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060194.jpg)
Back to the jaws ,I managed to get a set of blanks machined up .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060173.jpg)
Hardened the plain jaws , oil quenched this time .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060176.jpg)
and ground up.
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060180.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060183.jpg)
Dont no if its just me but they seam to have a better grip for less tightening of the vice .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060186.jpg)
And holding thin parts edge on at the tip of the jaw is a breeze , ruler is 0.4mm thick
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060191.jpg)
Cracking job as usuall
That mill would have been very canny for your "collection" :lol: :lol: :lol: :lol: :lol: :lol:
Great job Rob!
..... Hi Mayhem
Well come on Rob - this isn't like you :poke:
Would have expected you to immediately set to work and made a bigger & better one ! :proj:
Is pragmatism creeping in? are you coming down to our mortal level :coffee:
p.s. marvellous work as usual :clap: :clap: :clap:
cheers / Dave
Those jaws are fantastic -- holding that rule on edge like that. :clap: :clap: :clap:
I could do that in my vice.
But the edge would be serrated afterwards! :wack:
How about this (suitably scaled down, of course)?
(http://i01.i.aliimg.com/photo/v0/110161379/Bosny_CHROME_SPRAY_PAINT.jpg)
Seriously, nice work again there Rob. An next time you're throwing a beaver on the scrappies, give me a shout first, I'm always up for bagging impractically large machinery....
:lol: :lol: Cheers Lads :beer:
Hi John ,,,,,,, I could not be arsed to move it ,any way I need the space for more interesting machines :med:
:lol: :lol: :lol: Cheers Dave ,,,,,,,, yes it would of only took me lest time than it takes to have a smoke too stick a new box together ,BUT it would not fit into my oven as the box would need to be at least 1 1/2 longer :palm: , the box I have just fits , could do with a larger oven ,anyone got one kicking about ?
Dam now all I have to do is spray the job :lol: :lol:
Hi Ade ,,,,,,,,,,,,, there is a reason I could have it for nowt , the head and one of the power feed gearboxes are buggered ,spindle stuck in low (i think) , So probably more than you would want to take on . I will keep you in mined :thumbup:
Hi Rob , you have been busy , splendid job as usual :bow: :bow: :bow: , ............... I reckon the jaw you destruction tested would still weld up fine with a little patience :dremel: ...................... I dont have much patience though :lol:
Keep up the good work :thumbup:
Cheers Mick.
oooo Triton i all ways wonted one nothing in his work shop for me :drool: them jaws are brill i may be cheeky and get you to mack just a normel set for my vice its made in canider and record ones don't fit
Cheers Lads :beer:
Well that's the jaws finished :dremel:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060231.jpg)
I have only hardened the plain jaws for now ,as I may still add a few mods to the other jaws .
A few really griping shots of the jaws in action , just with crap I have on the bench.
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060225.jpg)
Holding work for threading .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060223.jpg)
Driving out roll pins .
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060227.jpg)
Odd shaped work
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060217.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060218.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060219.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060220.jpg)
Thin part
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060221.jpg)
Jaws can be mixed and matched
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060228.jpg)
It takes me 17 seconds ( I time it sad git) to change out all four sets of jaws ,,,,,,, it takes 7 seconds to just wind the vice open enough to get a screwdriver in to the original screws :med:
FREE TO GOOD HOME :lol:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060233.jpg)
'free to good home'......
I'll have 'em...... :D
Seriously, nice job Rob... I like it when a plan comes together ( as Hannibal sez.....)
It truly amazes me how innovative we can be and the skill and determination we have to produce such great works.....and as usual you have surpassed yourself... :bow:
Those are really nice Rob. One day I may attempt something like that!
Thanks Eric :beer:
Hi John , do you seriously want the old jaws ? will stick em in the post if you want them .
Cheers Rob ,,,,,,,,,,pondering what to make now :scratch:
Splendid, inspirational job Rob - no exotic materials, just design & honest craftsmanship & a well-told story.
perchance something CNC-related?
Dave :beer:
Thanks Dave :beer:
aaarh the CNC hoping to get back on with that at the end of the month , I really need a good sort out of both shops first so I have room to move , hoping to do it over the Easter weekend when I will have more time to drag everything out , bet it pisses down :bang:
I may make a couple of small instrument vice'''s to fill in time, or a rad tool for the myford ,,,mmmmmmmm maybe a brake for my hydraulic press
Rob , the indecisive one lol
Rob, those look like they might do rather well on a milling machine.... do you reckon they've got the accuracy to be repeatable? Or would you want a different way of fitting them to the vice?
hi rob is you vice a record one if so then them jwas will not fit mine
Hi Ade , the way the jaws mount to the bench vice would not be accurate enough for repeatable milling work ,there is a few thou play in them . I would go for a different approach to mounting and securing the jaws in position for a milling application. I have a couple of ideas rattling around in the old head .
Hi Bob ,,,,,,,yes it is a record vice , I will keep them to one side for you :thumbup:
Thanks Eric :beer:
Honestly Rob, no thank you very much..I'm sure there's someone that can make better use of them.
