The Shop => Our Shop => Topic started by: doubleboost on January 12, 2013, 05:18:48 PM
Lads
I found a couple of pictures of my old shop
Talk about no room
(http://i261.photobucket.com/albums/ii63/john970s0/howtofitit001.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/HPFUELSYSTEM030.jpg)
The clathe is a ML4
Reminds me of my first 'workshop' - an 8x6 shed at the bottom of the garden. Barely room to do anything by the time I got a lathe in there. I had a hole in the wall to coincide with the headstock bore for longer stock! Now I've got 2000 foot plus :)
Bet you had some good times in there John :)
John.
The word is, cosy.... I think! :D
Hi John , you are spoilt now then :D I bet it was easier to keep warm in the cosy shed mind lol, I take the kart is the jet kart getting built :thumbup: That is one big turbo there :clap:
Cheers Mick.
Forget the shop, what about the cool Go Cart! Do I see the making of a jet motor? I would love to play around with one some day.
I would love to see some more pictures of the Go Cart if you have any.
Dale P.
Google is your best friend
http://www.youtube.com/watch?v=ZbE5G-Czbwc
Stuart
That's some fearsome beastie!!
:offtopic:
Some years ago, one of my hobbies (vices?!) was amateur radio. One of my activities within that hobby was to be antenna mast rigger for a group that took part in Field Days. You set up the station(s) at some field location starting on Saturday morning, start operating at 13:00 and work through until 13:00 on the Sunday. In the case of our group, the stations were powered from a single cylinder diesel generator.
Although the field location was away from home, there were usually residential houses nearby and the noise from the diesel was a problem in the stilly watches of the night when other background noise was low.
The low frequency noise from the diesel is difficult to screen or suppress and I often wondered if we should have tried to obtain a gas turbine-powered generator, for example an ex-aircraft APU, on the basis that the higher frequency noise would be easier to muffle.
I'm out of that hobby now but I'd be interested to hear members' comments and experiences.
yes used to do the same field days as you say diesel and the dead of the night are not good ,as is a lightning storm with a 60 foot mast up sitting in a tent at the base
as well as contests from the club shack
I am the same station dismantled
my calls were G8OSK ( b class ) and G4IJX ( a class )
the club call was G6CW and G3EKW
73's Stuart
QSL about the noise. Hay bails a plenty around the generator and a good set of headphones was the only answer for our club
Well seeing what you did with that small space makes me feel better! I like the wraparound L shaped bench, and I think I will do something like that to reduce the clutter in what I'm using now. It's unfortunately a storage shed for household items, with the lathe nearly buried in the center. I do have 2 stand alone benches (piled high with the machine tools I could rescue), but not a full wrap around like your shed had -- the big problem in winter is getting everything outside long enough to be able to build anything. Waiting very patiently for spring and snow melt! :med:
I wonder how many hams we have? I've been one since 1981 when I earned my novice ticket at 14. I'm now an extra class with the call, N5FPP.
Never a HAM, but a long time SWL with the usual fleet of AR80 / HRO and various Eddystone receivers over the years. Used to haunt Radio Rallies but I've kicked the habit <G>
Hi there, all,
I didn't mean to turn this into an amateur radio thread!! :doh:
I was more interested in the gas turbine aspect.
Where would I have gone to try to buy an APU! Where do drag racers and speed records projects buy their turbines?
I remember that there used to be a firm of aircraft dismantlers at Hounslow (UK) whose yard was 'paved' with turbine blades. They had a section of aircraft panel bearing the words 'Bristol Brabazon' over their office door.
Just curious. :scratch:
