The Shop => Tools => Topic started by: RotarySMP on November 24, 2012, 02:28:15 PM
Title: Boley 4LV
Post by: RotarySMP on November 24, 2012, 02:28:15 PM
Bought a Boley 4L lathe today.
Beautiful piece of quality engineering. Considering it only cost the same a new 320lb Chinese 9x20, it was a steal. It is a 9x18 and weighs 780kg. It is on the optional heavier gL37,2 cast stand. The bed ways are easily as wide as the center height, and the saddle length is about 50% the bed length.  The spindle speed range is 71-1800 rpm in 12 steps, and I will probably run it off a VFD which will increase the range further. The headstock looks identical to the 5LZ which went to 3550rpm standard. The spindle runs smooth as silk.
There is one decent chip out of the bed (about where the cable is lying in the photo) , but otherwise the general condition seems really good.  Paint is original, and there is only very light rust on a few surfaces.  The test cuts I did gave the impression that the thing could turn a tenth off krytonite.
There is no obvious thinning/wear of the saddle or cross slide leadscrew threads, and little backlash. Everything was a bit dry, but I cleaned up the bed and put some lube on it and it runs like silk. I'll order some proper way and spindle oil off ebay for it.
Both crank and lever tail stocks, and the fixed and traveling steadies are with it. No other chucks or collets. It supposedly has a weird M39x3.5- 55° threaded nose. I'll have to get a 4 jaw, and will probably cast a face plate and ER32 collet chuck. But I'll also be keeping an eye out for W23 358E collets on Ebay.
This model doesn't have a thread cutting gearbox. It is designed with the leadscrew protected from swarf under the bed under the bed.  Feeding and threading are both with change wheels. Only the two change wheels currently fitted (50/55) are with it. However it does have the optional fine feed gearbox. The rest of the change wheels are lost. I will probably CNC it, as that will be cheaper and easier than tracking down a set of change wheels, and I have had lots of fun with my CNC's 7x12.
Don't take possession of the house for another few weeks, so the seller kindly agreed to store it for me through into January.
Title: Re: Boley 4L
Post by: PekkaNF on November 24, 2012, 02:54:44 PM
Congratulations! Really beautiful machine :clap:
Is it your only lathe?
Title: Re: Boley 4L
Post by: RotarySMP on November 24, 2012, 03:39:31 PM
"Is it your only lathe?"
Depends if you consider this a lathe... many don't!
(http://i1124.photobucket.com/albums/l579/rotarysmp/L1011186.jpg)
Some more photos from the Boley...
Title: Re: Boley 4L
Post by: Rob.Wilson on November 24, 2012, 03:47:56 PM
 :bow: :bow: :bow: :bow: very nice lathe you have got yourself there  :thumbup:
Title: Re: Boley 4L
Post by: RotarySMP on November 24, 2012, 04:08:46 PM
I was surprised that it didn't sell sooner. Small machines are normally sought after here, as no one has space. It was advertised for about 8 weeks in the local version of Craiglist. Since we closed on a house last week, I can finally get a real lathe.
Shame I have to wait till next year to play with it.
Title: Re: Boley 4L
Post by: Rob.Wilson on November 24, 2012, 04:14:34 PM
good solid machine , and you got  the steady s   :dremel:
Title: Re: Boley 4L
Post by: BillTodd on November 24, 2012, 04:26:37 PM
There's a chap (Harold Mulder)  on the PM forum looking for a Boley 4L changewheel  plate  (or diagram & list ). Does this machine have such a thing ?
Nice machine BTW
When you said "cnc it"  I trust you meant only the threading operation ?
Bill  (lathe protection squad hit-men on standby)
Title: Re: Boley 4L
Post by: PekkaNF on November 25, 2012, 04:02:45 AM
Looks like a lathe to me. And it looks greatly improved to the original.
I have pretty similar, least when it comes to top slide and toolpost! Mine does not have steppers and invertter - yet.
I'm not considering CNC without ballscrews, ballslides and central lube, but electronic feed would be very high on my list. l am not yet very conviced on ELS, I'm having hard time "getting it" how it actually could make an accurate thread with one pulse per spindle revolution and without servo.
Title: Re: Boley 4L
Post by: RotarySMP on November 25, 2012, 05:37:30 AM
Thanks for your comments guys. I am in contact with Harald.
If I CNC the 4L, it will be a  reversable change (as it is on the 7x12). I am not sure if that is the path I take with the 4L though. I just talked to my dad and he has a spare set of change gears he was given a few years ago. No idea what machine they are off, but if the size is near enough, and bores are small enough to be bored out, then I might end up adapting that set (if he brings them over from NZ in summer).
The 4L is a very simple machine. This makes it ideal for CNC, as all the wonderful mechanically tricky features which make something like a 5LZ or 1EE so cool, becomme redundant once a computor spins the wheels.
Remove the 4L lead screw, and install a ball screw mounted on bearing blocks and a nut carrier which pick up the existing mount holes.
Same for the the cross slide.
Top slide is replaced by a tool riser block.
Two inductive sensor, one the spindle cog for rpm, and another on a 1/rev feature for indexing.
The T-Slot for sliding stops on the bed will be excellent for mounting limit and home switches.
The motor is a standard, industrial, flanged motor. It is only .75/.9k. I am not sure if the place I bought has 3ph in the cellar. If not I will probably need a 240 3PH motor, and will run it off a 1PH -> 3PH VFD like I have my current lathe.
Pekka, 1/rev indexing worked fine under T-CNC. Since I swapped to LinuxCNC (EMC2) I only have the index signal set up to provide RPM indication and havent done any threading.
On a CNC lathe, you can cut the thread with dozens  of light cuts, and at much higher spindle speeds than you would comfortably do manually, so the spindle doesn't really load up or slow down enough to make a significant effect on thread accuracy (obvious it depends on the desired accuracy). I have cut two M40x1.5 (er32 collet nut) threads on 7x12. It was just on the wrong side of the machines capacity, and turned out ugly on one, and worked on the other.
I think you only need a Px oiling system if you use the mchine for hours each day. I just squirt oil on the ways and screws regularly (like every time I use it). Given the cost of 7x replacement parts, it is probably easier just to replacing things if they start getting worn.
Title: Re: Boley 4L
Post by: PekkaNF on November 26, 2012, 02:49:01 AM
Looks like you have sorted it out :clap:
I was considering this method for semiautomatic machining (sort of ELS) with a bunch of other guys who were whole lot more electronically versed, but when we "clocked" the spindle, leacrews etc, we noticed that:
* normal capacitor run AC motor is absolutely out of questions if only one pulse per spindle revolution is used. 3phase AC, more "flywheel" and stiff belt drive was an improvement.
* Takes some time to stabilize the speed, ELS needs delays to wait until spindle is "at speed" and some preset distance to "build speed for leadscrew".
* Cutting does not generate constant force, forces seem to be cyclic
Therefore threading seem to be heading to direction of servodrive for a spindle and/or greater pulse count on spindle and more processing power. We did regognized that with tweaking it could be doable, but not as predictable as mechanical solution.
Would love to get some info on your workking system:
* AC-motor/inverter rating, spindle speed used for threading
* Threading dimenssions tested succesfully and failed ones (they are best to find linmits!)
* Inertia masses are hard, but rought chuck/belt wheel dimessions would help
* Lead screw pitch/ratio/stepper motor and current you run it would give great insight
PekkaNF
Title: Re: Boley 4L
Post by: RotarySMP on November 26, 2012, 12:44:34 PM
I have a 0.55 KW (3/4hp),  3phase,  240V 2 pole motor, driven from a 0.55 kw VFD at between 10 and 70 Hz. The reduction is a bit under 3:1 using THD 9mm belt.
The leadscrew is a 5/8 x .200" rolled ball screw, driven from a 1:2 belt reduction from a modern Keling NEMA 23 stepper.
I have not done much threading, and never to a standard in the sense of three wire measurement or gage. I just turn and try.
My lowest spindle speed is 240 rpm (10 hz). At this speed the motor has bugger all torque, so for the 40mm x 1.5 thread you are in an ugly corner between too little depth of cut causing rubbing, and too DOC causing stalling, and too much spindle speed causes excessive tool wear over the multiple passes required.
Basically any smaller diameters work fine, as you up the spindle rpm, providing increased torque.
I use a 3" three jaw, 4" four jaw and a home made ER32 collet chusk. The worst case was turning the collet chucks own thread, as there was bugger all mass. It is a pretty horrible excuse for a thread. I am suprised it fulfills its function at all. Unfortunately, I can't show you this thread right now, as the colet chuck has a job in it which I don't want to disturb.
The second one is on a mill spindle I have been working (on and off) on making. It has a pretty nice thread except for two nasty chips out of the it.
(http://i1124.photobucket.com/albums/l579/rotarysmp/_MG_2807.jpg)
This size thread is really beyond the capacity of this machine. It took a far bit of experimenting to get it done.
Smaller threads like the M8x0.75 for the Proxxon spindle nose work really well.
http://www.cnczone.com/forums/vertical_mill_lathe_project_log/103610-my_homebuilt_spindles.html
Title: Re: Boley 4L
Post by: philf on November 26, 2012, 01:52:05 PM
Hi RotarySMP,
Is there a good reason why the taper roller bearing is the way round it is?
It's more usual to be the other way round so that thermal expansion in the spindle reduces the preload on the bearings - I think that with your design the preload may increase thus putting up the temp and increasing the preload etc. etc.
I have struggled to understand how one pulse per rev can work with threading but reading that you need plenty of oomph so that the spindle doesn't slow under cutting conditions helps me to see how it works.
Cheers.
Title: Re: Boley 4L
Post by: RotarySMP on November 26, 2012, 04:29:44 PM
This spindle is based on a right angle reduction gearbox I picked up from the scrap dealer.
http://www.cnczone.com/forums/attachment.php?attachmentid=105471&d=1271620622
There are cover plates which bolt on both ends came with a bunch of nice shim. Doing the bearings this way seemed like I could use the shims to easily set preload.
Title: Re: Boley 4L
Post by: philf on November 26, 2012, 05:42:30 PM
Hi,
I've just had a look at your drawing and I can't see what fixes the spindle axially within the bearings. Or am I missing something obvious.
I'd still be nervous about any increase in temperature increasing the preload.
Title: Re: Boley 4L
Post by: RotarySMP on November 27, 2012, 01:26:28 AM
Correct, at that point I had not decided. I have since turned a thread onto the other end of the spindle, and made pair of nuts to fix the inner races.
Beacuse the housing block I am using has no shoulders, I can not reverse the bearings, as nothing would then restrain the outer races.
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 04:13:18 AM
About time I updated my thread.
The Boley is working nicely for me.
I managed to shear off the spindle lock pin, by trying to unscrew the chuck with a big Lever, without engaging the back gear.
The torque would have been around 750nm, and went straight on to that pin. The back gear would have reduced that by 3.5x.
I made a new pin, and fitted it.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 04:18:09 AM
I have also been collecting collets. Got a partial set of imperial collets from Ebay.co.uk, and a partial set of metrics from a guy here in Vienna, who also sold me a Spin indexer for the 358E / W23 / A12 size 4 collets Boleys use. There is a guy on Ebay Germany selling single collets, so I have ordered the main ones I am missing. I'm going to mix the imperial and metric collets up on a single collet board, as the 1/64" spacing gives 0.4mm steps, and I have all the small ones in imperial. 0.4, 0.8, 1.2mm... makes for a nice set. I'll post Pictures once I have finished the collet board.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 04:24:58 AM
There was a excessive play in the carriage drive, as in 180° of handle rotation. The drive handle has an idler to change rotation directions, and the roll pin to fix it to it's shaft was severed in three pieces. I doubt the roll pin was original. This lathe was what is referred to in German as a Fettopfer, a grease victim. It was designed for all these mechanisms to be regularly oiled.
Made a new pin for it which has cut the play dramatically. Once I have the backing plate for my Bison 125mm four jaw independant chuck, I will Mount that housing, bore out the slogged out shaft bore and bush it.
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 04:33:37 AM
As there was no change wheels with the lathe when I got it, I hae not been able to cut threads. I missed out on a set of Change wheels which failed to sell on Ebay.CO.UK. The seller had sold them cheap to an Artist who made an installation out of them  :doh:
Since I have already CNC'd one lathe, I decided to do an electronic leadscrew on the Boley for now. I am mostly enjoying having a Manual lathe again, so I am not sure if I will CNC it completly.
First thing needed is a spindle Encoder. Since I'll be using LinuxCNC, it need a 1/rev indexing puls, plus a more/rev encoder signal. There are lots of ways to acheive this, but I tend to choose the most complicated. In this case I have made a steel 40 count encoder disk, with one long slot and fitted it to the existing fine feed drive pulley.
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 04:51:12 AM
I have started making the Z Axis drive motor mount. A Nema 34 stepper will be mounted. I don't like irreversable modifications, so the mount will be the same as the existing Boley fine advance drive, which clamps onto a shaft feature concentric to the leadscrew.
Pretty painful process milling the 7mm recess for the motor on the Deckel G1L. I can only cut 0.5mm per pass.
I wonder what the Austrian Ö-Norm material number is for that shiny steel which Rob Wilson uses.
Since I haven't received the backing plate for my Bison yet, I had to mount the 100mm four jaw in the 115mm three jaw.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on December 01, 2015, 05:00:28 AM
Continued..
Title: Re: Boley 4L
Post by: RotarySMP on December 02, 2015, 06:06:20 AM
Yesterday  I stress relieved the weldment, and got started boring it out. My youngest told me to stop as it was resonating through the whole house and she couldn't sleep.
ER16 is not the ideal spindle taper for a boring bar. Not much rigidity there.  I put the NEMA 34 motor on there for scale.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on December 07, 2015, 10:32:05 AM
I finished boring, threading and slitting the motor mount. Went at it with a grinder to clean up my ugly weld practise also.
Title: Re: Boley 4L
Post by: RotarySMP on December 13, 2015, 04:11:24 PM
Since the original photobucket links have gone dead, here are some current photos showing the Boley 4L
Title: Re: Boley 4L
Post by: RotarySMP on December 14, 2015, 04:15:11 PM
Today I undercoated the motor mount.
Title: Re: Boley 4L
Post by: SteveT on December 14, 2015, 05:58:59 PM
Looks a good find  :beer:
Title: Re: Boley 4L
Post by: tom osselton on December 15, 2015, 01:15:06 AM
Nice job!
Title: Re: Boley 4L
Post by: RotarySMP on December 20, 2015, 04:08:38 AM
Thanks guys.
It is pretty well used, but still a fine tool.
Well, that first motor mount undercoating was crap, so I sanded it back and redid it.
Then I needed to make up an adaptor plate to mount my 4 jaw to my only chuck back plate. The slug of steel was a drop form Fixmetal. It is too thick, but I figured it would be waste to turn 70% into swarf, since I can reuse it for something else once I get the new backplates which are ordered.
The parts I order fro Mädler.de showed up (within two days of ordering - nice), so I bored out the timing belt cogs, and shaped a keyway in the one which goes on the leadscrew. Since my keyway cutter is 3mm I had to do it in two passes.
Regards,
Mark
Title: Re: Boley 4L
Post by: RotarySMP on December 24, 2015, 05:23:52 AM
Now the top coat has dried, and I could install it.
Title: Re: Boley 4L
Post by: RotarySMP on December 24, 2015, 05:45:03 AM
Although I am installing the ELS for threading, I am enjoying manual turning, so I would like to tighten up the excessive play in the saddle drive.
I bought some sintered bronze bushes from Maedler.de, figuring I just need to bore out and bush the handle casting on the apron. The Shaft is also worn 0.25mm, so I'll have to turn that back and sleeve it as well. When I looked at the shaft on the apron, with the pinion which meshes with the rack, it also has 04mm play, so I'll need to pull the apron, bush that hole, sleeve it's shaft, and the add a second busing into the handle casting.
I'll order 11mm and 14mm reamers for this job, and get on with something else in the mean time.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on February 21, 2016, 01:16:04 PM
Finally got around to making a holder for the Boley's collets.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on February 29, 2016, 08:01:00 AM
The spindle nipped up on the lathe. I think I'd better tear it down and check that it is not scoring the journal, and probably scrape the plain bearing back in before I use it any more. My lathe had been lubed with grease (except the headstock nose bearing)  when I got it, so I need to make sure that the rear bearings are also correctly lubed.
It is obvious from the hammer and punch marks on the nuts that someone has been here before, who didn't bother with the finer points of maintenance like using the correct tool for the job. Lucky I bought a set of C spanners a few months ago.
The tear down starts on the LH end. There is a fine thread on the spindle which mounts a split nut as a backstop for the thrust bearing preload nuts to act on. This nut has a conical surface.
On my lathe, their was also a conical washer, but that was located on the other side of the thrust adjuster. I guess that was incorrect assembly.
I need to release the nut on in the gearbox behind the nose bearing, but it has a sheet metal cover.
To get that cover out of the way, it looks like I need to remove the three screws on the bull gear, and shift it to the left. There is also a grub screw on the spacer which has to come out.
The thrust bearing house slid out with a nice tight sliding fit.
The bearings will have to come out, as they are full of grease. Boley specifies VG68 way oil for the rolling element bearings. Martin from the CNCEcke has offered me his dummy bearing so I have a shaft support to locate the spindle for the 100 time you need to install and remove the spindle during scraping.
http://www.cncecke.de/forum/showthread.php?41731-Restauration-Boley-4L-Drehbank&highlight=boley
I am glad that the back gears look in very good condition.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on March 06, 2016, 02:15:31 PM
I pulled the spindle. Turns out the grubscrew which acts as an anti-rotation stop for the collets, was loose. It had backed out a bit and machine a groove in the plain bearing. I estimate it is at least 1/10mm deep. I hope there is enough meat there to scrape the bearing back to full contact.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on March 13, 2016, 03:00:52 PM
I've now pulled the three rear bearings. Once the dummy rear bearing arrives, I can start scraping the front bearing back in. I'll have to grind the steel shim in the top of the bronze bearing which controls it's diameter. with the current shim, and the bearing nut tight, the spindle goes all the way into the bearing till it hits the shoulder.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on March 16, 2016, 03:39:55 AM
I pulled the steel spacer from the slot in the spindle bearing. This roughly sets the bearing bore diameter, then therefore roughly sets the bearing clearance. The fine adjustment is through spindle axial location. Someone has been there before, and broken one end off it. It is currently 2.20mm thick. I'll need to do a few tries with a stack of shims to get a feel for how much need to be grind off.
Title: Re: Boley 4L
Post by: RotarySMP on March 17, 2016, 03:43:31 PM
Today I was out at my mates doing a casting seasion, and he ground down that bearing shim on his surface grinder. Cool tools those.
Title: Re: Boley 4L
Post by: RotarySMP on March 31, 2016, 03:22:58 AM
Not sure if this is interesting for anyone...
A Gentleman from a German forum sent me his dummy bearing to support the LH end of the shaft, so I scraped in the main bearing over Easter.
I checked the run out of the spindle. There a couple of tiny defects (which I can't see) which kick the TIR to 0.0004" / 0.01mm at the collet taper.
 The Chuck alignment boss is "perfect" within the limits of my measuring equipment.
Just waiting for a new seal, and need to surface grind the new shim, and I can put it back together.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 04, 2016, 06:26:17 AM
Ground the new spacer shim yesterday, seal arrived, so I can reassemble that lathe this week. With the forward bearing spacer shim ground to 2.14mm, I have about 0.012mm play in the bearing. This needs to be about 0.02mm, so I'll have to add another 0.02mm shim to increase it.
On Saturday, I plopped the top slide on the surface table to have a look at it. As expected, it has worn a bit hollow, so I started scrapping it.
Mark
Title: Re: Boley 4L
Post by: smiffy on April 04, 2016, 03:48:09 PM
 Hi nice job you are making of getting your lathe into shape. I think it uses some of the same parts as my 5 LZ .
Do you have the collet chuck . I only have part of mine and would like to make the missing parts
       Mike
Title: Re: Boley 4L
Post by: RotarySMP on April 05, 2016, 04:05:30 AM
Hi Mike,
Thanks for the encouragement.
I don't have a collet chuck, or do you mean collet closer for the 358E / W23 / A12 collets?
Yesterday I didn't feel like reassembling the spindle, so finished stripping the compound down to piece parts. It is in pretty good condition, except the paint which is almost completely gone, and an extra M12 threaded hole in the top slide.
Mark
Title: Re: Boley 4L
Post by: smiffy on April 05, 2016, 09:07:26 AM
Sorry its the end cap of the collet closer that I am missing .My spindle is bored 4 MT and at the moment I use a er collet chuck in the spindle but it would be nice to get the proper collet up and running Mike
Title: Re: Boley 4L
Post by: RotarySMP on April 06, 2016, 03:11:36 AM
Hi Mike,
I have not been able to disassemble  the end of my collet closer. Martin Oliver has had his apart...
http://www.cncecke.de/forum/showthread.php?41731-Restauration-Boley-4L-Drehbank&p=824584&viewfull=1#post824584 He is very helpful and has done a lovely Job of restoring his 4L.
Interesting that the 5LZ spindle is native MT4. The 4L and 4LV are native 358E
Mark
Title: Re: Boley 4L
Post by: smiffy on April 06, 2016, 06:43:40 AM
 MY 5LZ was only available as 4 mt to special order according  to the  information in the manual .
Title: Re: Boley 4L
Post by: RotarySMP on April 06, 2016, 09:49:24 AM
How many chuck backing plates do you have? I only have one. Martin did a group order but the CNC shop he contracted to make us a batch let us down.
The 5LZ native backing plates have an locking collar to clamp to the spindle to stop the chuck unscrewing don't they?
Mark
Title: Re: Boley 4L
Post by: smiffy on April 06, 2016, 03:42:48 PM
 My spindle is din 3 and I can buy bison back plates from rotagrip .The lathe came with 3 and 4 jaw chuck and 1 spare back plate.
The 3 jaw chuck is a Forkardt F125 chuck and a fantastic piece of kit , When I have a bit of time I will photograph it .Its the only 3 jaw chuck that I have ever seen where the jaws are reversable  same as a 4 jaw chuck
Does anyone have the retractable tool holder for screwcutting as i would like to know how they work ?  Mike
Title: Re: Boley 4L
Post by: RotarySMP on April 07, 2016, 03:22:02 AM
That really was a special order spindle wasn't it. Din 3? Is it the short taper from Camlock, but clamped up with nuts on the rotating kidney slotted disc? I thought that was DIN 55021 Type B? Nice to have for sure. You really got lucky with this lathe.
Concerning the retracting tool holder, I would suggest you join the Boley subgroup in the CNCEcke.DE Forum, and ask there.
http://www.cncecke.de/forum/group.php?groupid=11
Mine came with the Boley 4 way tool post, but I use a Phase II AXA on it.
I have the original Klopfer 110mm three jaw, which is great with the outside jaws, but someone turned a step on the inside jaws. Good for thin parts, but hopeless of small diameter stuff now. I bought a replacement Klopfer 110mm marked "Weiler" hoping the jaws would be interchangeable, but they aren't, and the second chuck has more wear. Also picked up a low mileage Bison thin lightweight 125mm four jaw independent. Nice chuck. Unfortunately I currently only have one backing plate, so it is about time I get stuck in and make a dummy spindle nose gage with the M40x3.5 x 55° nose thread, and then make some more backing plates, face plate, catch plate etc.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 07, 2016, 03:24:52 AM
Made a little more progress on scraping in the compounds flat ways.
There was a hollow in there which has taken a fair bit of work to get done to.
Mark
Title: Re: Boley 4L
Post by: smiffy on April 07, 2016, 03:20:04 PM
Some pictures of head stock and chuck
The scroll only moves just under 1/3 turn and then the jaws can be withdrawn , There is a detent to hold each jaw is place for location purposes
The jaws can be fitted to different places in relation to each other .
Each jaw can be independently reversed
There is a small button on the front of the chuck that comes out to indicate when the scroll is fully withdrawn and the jaws can be withdrawn
Forkardt still make this chuck and when I have a few pennies  I will buy a new set of jaws as at the moment I only have soft jaws but at £365 a set it will have to wait
 The chuck is rated at 4000 rpm
A new chuck is eye wateringly expensive
Title: Re: Boley 4L
Post by: RotarySMP on April 08, 2016, 03:23:27 AM
Hi Mike. Tasty chuck!
I hate to think what that lathe would have sold for new. A standard 5LZ in 1970 had a list price of 70 000DM, which wasn't far of the price of an average house. Your special order spindle would have pushed that up a fair bit. does it have metric or imperial leadscrews? That would be a wonderful machine to restore.
Edit [Deleted the bit about the spindle]
Might be a good idea for posterity, and future 5LZ owners searching for info, to post all your photos on your 5LZ thread and I'll post the 4LV stuff in this one. There is not much info on either on the net, so it might be helpful to keep it sorted.
Yesterday I cleaned all the compound slide components. They are in very good condition with little wear. The lead screw and nut look as new. The castellated nuts haven't been mangled with a drift like all the other ones on this machine.  Photos are still in the camera sorry.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 08, 2016, 05:02:03 PM
I finished the flat ways of the compound. According to Conelly it should have 10-15 ppi, and I count 14, so I hope it's good enough.
The tool post mount surface is a bit sloped. I'll need to take 0.2-0.3mm off it to get rid of the impact marks.
The cross slide also has a bit of wear. I'll have to do scrape down carefully, as the compound mount boss is pretty good.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 11, 2016, 04:26:39 PM
Reassembled the spindle this weekend. It went smoothly, except I messed up on the back gear and had to pull it out and start again.
Once it was all back together I ran it for about an houe without any load, increaseing the speed along the way. Finally put the whole machine back together. I haven't finished scraping the topslide, as I still need to do the tapered surfaces, and clean up the top.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 11, 2016, 04:31:08 PM
In the sales Brochure for the 4LV, I read that the level tailstock has the Boley 358E collet nose. Never notice that before, I thought it was #2 Morse.
Looks like previous owners of this lathe, didn't have access to a tool for turning a tommy bar down to the correct diameter to fit the collet draw tube  :doh:
Mark
Title: Re: Boley 4L
Post by: JHovel on April 13, 2016, 11:05:44 AM
Just found this thread.
What a beautiful lathe! Great restoration work!
There are a couple of things that puzzle me:
I don't understand how the chuck works or how it is operated. Can you explain that to me please? It looks like it would be 'swarf proof' - am I right?
Secondly, I can work out how the tailstock works. It seems to have both lever and screw operation at the same time.... how is that done? Can you perhpas sketch the construction or show me a drawing?\
Both very interesting!
i have "built up" my lathe from an old special build (no maker's name) double ended connecting rod boring machine, using a Southbend tailstock and I would like to modify that to have more travel and maybe a handwheel (not lever), but I don't really want to loose option of the fine and forceful handwheel movement if required....
Thanks for showing us your work!
Alles Gute.
Title: Re: Boley 4L
Post by: RotarySMP on April 13, 2016, 04:04:40 PM
Hi Joe,
The chuck is just a regular 110mm Klopfer, with a backing plate to mate with the spindle screw thread.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 13, 2016, 04:11:12 PM
Hi Joe, Sorry it is not a fancy mechanism. It is two separate tailstocks. The lever operated one has a collet nose, and collet drawbar. The regular tailstock has a #2 Morse nose, and also has provision for set over.
Please start a thread and post pictures of your lathe. It sound like an interesting one.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 13, 2016, 04:15:24 PM
Along with the lever operated tailstock, and the lathe spindle, I also picked up an old shop made indexer which uses the same 358E W23 A12 collets. Very handy for making simple things like bolts with a hex or square to be milled. It can index 6, or 8 holes.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 13, 2016, 04:18:18 PM
Yesterday I turned up a plug for scrap cast iron, threaded it to M12, and JB welded it into the hole someone had bored in the compound (probably for a Multifix QCTP). Let it harden over night, and tonight I roughly milled it flat. Once I shape/grind or scrape the top flat, and get all the dings out, I hope it won't be too visible.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 18, 2016, 02:38:57 AM
Yesterday I was out at a friends place, and we cleaned up the compound on his Klopp shaper.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 27, 2016, 04:59:18 PM
I have three chucks, but only one back plate. My order of Meehanite arrived today. The plan is to make:
A 70mm back plate for the Bison 125mm Four jaw.
Another 110mm back plate for the second 110mm three jaw.
A 110mm catch plate to drive the dog when turn between centers
A spindle thread protector for when I am using collets.
Once the new furnace is finished, I also want to cast my face plate.
http://www.alloyavenue.com/vb/showthread.php?10501-Build-thread-Calcium-silicate-insulated-copy-of-Myfordboy-J-Vibert-furnace&p=188218#post188218
Before I can turn the female threads, I'll make a gauge. I turned up the three 2.38mm gauges required to measure the thread, and glued them to some wire to hold them in place.
Also got the blank for the gauge ready.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on April 29, 2016, 05:27:22 PM
Turns out that drawing I posted of the spindle nose is incorrect. It shows 41.54mm over 2.38mm thread wires. I made 2.42mm thread wires, and my spindle is only measures 40.90mm with them. Martin from the CNCecke also confirmed that drawing is incorrect with thread wire on his spindle as well.
Today I cut the thread in the spindle guage. First ground up a 55° bit with 5° of top rake on the Clarkson. Set the top slide to 27.5° and zeroed it, scratched off on the work with the cross slide and zeroed it as well. From then on all cuts were make with the top slide.
I turned with the slowest back gear. 73RPM.
I made quite a few mistakes, so I'll have to make another one, but at least it shows the Boley can cut it's own spindle thread in Meehanite.
The mistakes:
- I had the alignment boss spot on size, within a 0.0001" of the spindle's boss, and nicely polished with 600 grit sand paper. Thought I could improve the finish with 1000 and 2000 and went 0.0003" under. The alignment boss is 41mm h5 which only gives a tolerance of 0.0003" (11 micron). I need to get some metric micrometers. My 1-2" Starett also can't be trusted for absolute values, as zeroed on a 1" standard it's 0.0003" out on the 2" standard (or one of my standards is out). Still, it works fine for comparison measurements like this.
- Setting up, I slipped on the keyboard and did a G0 Z-41 instead of G0 Z-1, and put a thread into the alignment boss.
- In the middle I got impatient and tried a couple of cuts at 140rpm. I suspect that LinuxCNC accelerates at max rate for the axis when starting a G33 thread move, and then once at speed maintains sync. Speed variation during the threading are compensated for, but speed variation during acceleration aren't. Since the rotation angle travelled doubles during that acceleration with double the spindle speed, the thread then has a slightly different track. Need to pick a speed and stick to it for the whole thread.
- I started off doing 0.2mm infeed on the compound each cut. At about 0.8mm in, I had brain fade and infeed to 1.4 mm or so. Stalled out with a slipping spindle belt. Luckily it was early enough in the cut that most of the scars were cut out later.
- I dropped to 0.1mm infeed per cut at about 1mm, and to 0.05mm per cut at 2mm. Got impatient and tried 0.2mm when already at 2.2mm. Stalled again, but less harm down. Luckily did not lose sync, as LinuxCNC synced the Z stepper down to a stop following the spindle.
- Didn't stop to measure often enough. Went to 3.30mm infeed.  I cut the thread about 0.15mm too deep.
This one is a bit too small to be useful as a guage. A back plate cut to have a nice fit to this is probably still too tight for the real spindle.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on May 13, 2016, 04:43:25 PM
I made the first chuck adaptor, this one for the 125mm Bison four jaw.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on May 23, 2016, 07:59:00 AM
Made two more, one for the second three jaw, and a spare which I might use as a catch plate.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on November 04, 2017, 07:04:53 AM
Ade's thread got me lusting for a camlock spindle again.
http://madmodder.net/index.php/topic,12328.0.html
Last time I thought about making a D1-3 adapter for the Boley's threaded spindle nose, I thought I worked out that there is not enough meat in the D1-3 to fit over the threads.
Just to make sure, I modelled it this time. Buggar, I was right. Since the cams only turn less than 180° from unlocked to locked, I guess I could still get in there and relieve the end of the CAMs leaving the retention lip only in the arc where it is actually needed.
Then again, once we start getting unrealistic, there is also the Hembrug on Richardo.ch for 950 buy it now...
Mark
Title: Re: Boley 4L
Post by: RotarySMP on November 09, 2017, 12:29:07 PM
I was curious how much lower my tailstock is than center height. I turned up a brass slug to within 0.005mm of the 27.98mm tailstock ram diameter, and put a clock on it.
It is about 0.18mm (~7 thou) low when retracted, and quite level at about 0.03mm different along the length when fully extended when loose. It raises up 0.02mm when the ram lock is applied. Given the wear on the bed, this is not as bad as I feared. Sooner or later I'll have to have a shot at scrapping the bed.
It is still a nice old german machine. I was a single 1/100 over my finish cut to size that slug of brass, and at least on this lovely free cutting metal with a sharp HSS tool, taking another  cut of 0.005mm on radius over a short distance cut cleanly, and left a perfect surface finish.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on November 15, 2017, 08:12:46 AM
I was showing my Boley fine feed adapter to a mate who also has a Boley 4L, and was embarassed how grimy it was. Time I gave it a thorough cleaning. It is in excellent condition, with no significant wear or damage.
Mark
Title: Re: Boley 4L
Post by: RotarySMP on March 05, 2019, 02:28:35 AM
When I turned my chuck adaptors, the test piece for the 40x3.5x55° spindle thread rotated in the chuck before reaching full depth.
Now that my MAHO 400E is running...
https://forum.linuxcnc.org/12-milling/33035-retrofitting-a-1986-maho-mh400e?start=810#127756
... I used it to thread mill it, and then finished it on the lathe as a thread protector for use with collets.
Mark
Title: Re: Boley 4L
Post by: Viktor_74 on March 12, 2019, 06:21:24 AM
Hi! Bitte entschuldigen Sie mich in Zukunft für mein Deutsch ... Auf der Seite Drehmaschinen.de habe ich bereits geschaut, bis ich irgendetwas an den Gängen gefunden habe. In der Ukraine gibt es nur wenige solcher Autos! Und Informationen über sie zu finden ist unmöglich. Ich bitte dich zu helfen.
Interessiert an Informationen zur Größe der Zahnräder auf der Antriebsspindel: Durchmesser, Dicke, Zahnmodul. Parameter des Spindelantriebs. Danke!
Title: Re: Boley 4L
Post by: philf on March 12, 2019, 01:34:57 PM
Viktor,
I have used Google Translate to convert to English:
Hi! Please excuse me in the future for my German ... On the page Drehmaschinen.de I have already looked, until I found something in the corridors. In Ukraine there are only a few such cars! And finding information about them is impossible. I ask you to help.
Interested in information on the size of the gears on the drive spindle: diameter, thickness, tooth module. Parameters of the spindle drive. Thank you!
Title: Re: Boley 4L
Post by: RotarySMP on March 13, 2019, 03:44:14 AM
Hello Viktor,
I also responded in german on CNCEcke.de.
Are you asking about the gear at the back end of the spindle to drive the change gears? I don't have this gear, as I have a pulley to drive the optional fine feed mechanism, which you can see above. The change gears are Modul 1.5.
If you are asking about the back gear mechansim under the cover in the head stock, I do not know what modul those gears are.
Mark
Title: Re: Boley 4LV
Post by: RotarySMP on January 03, 2020, 02:17:45 PM
I cast and machined a face plate for the Boley.
Here is a video of the machining of it.
Mark
Post by: PekkaNF on January 03, 2020, 04:16:48 PM
Wow! Iron casting. Thread milling. Wow!
Post by: tom osselton on January 03, 2020, 04:22:34 PM
Nice casting it’s too cold out here for casting!
Post by: RotarySMP on January 04, 2020, 06:55:43 AM
WIth iron csting, it gets warm pretty fast.
Post by: PekkaNF on January 04, 2020, 08:35:56 AM
How do you heat up the iron? Oil burner? What sort of crusible do you use?
Post by: RotarySMP on January 04, 2020, 04:39:42 PM
I did a foundry tour video last week, which answers those questions.
Mark
Post by: awemawson on January 05, 2020, 03:11:54 AM
Very nice Mark.
John Winter ( Johnwinter.co.uk ) for ferrosilicate
Post by: RotarySMP on January 05, 2020, 05:04:09 AM
Thanks for the link Andrew. The only suppliers I had found were chinese, and will sell it by the ton.
Mark
Post by: PekkaNF on January 05, 2020, 06:10:09 AM
Mark
Thank you, that was very interesting and information is really good.
Post by: RotarySMP on January 05, 2020, 06:54:27 AM
Thanks for the feedback
Mark
Post by: mattinker on January 23, 2020, 08:32:49 AM
Mark
Mark,
I just got a quote from John Winter, £3.50/kg, minimum 100kg  silicon at 75%. Shipping to France, £135
A bit beyond my budget! Cheers, Matthew
Post by: awemawson on January 23, 2020, 08:49:03 AM
I will mark your end of term report 'Must try harder searching for things '  :clap:
eBay :
https://www.ebay.co.uk/itm/FERRO-SILICON-Pieces-750g-Si-75-86-Fe-23-89-1-6mm-FREE-P-P/254387618810?hash=item3b3aaf03fa:g:yo4AAOSw5nJeJttt
(£14.50 free delivery from Nottingham - 750 grams)
https://www.ebay.co.uk/itm/FERRO-SILICON-Pieces-1500g-Si-75-86-Fe-23-89-10-50mm-FREE-P-P/372798633338?hash=item56cc87b57a:g:iAIAAOSwM~tacFaN
(£18.50 free delivery from Nottingham for 1500 grams)
Post by: mattinker on January 23, 2020, 10:01:43 AM
eBay :
Thanks Andrew, you'll have to do online courses in searching!
Post by: RotarySMP on January 23, 2020, 11:03:12 AM
I also contacted John Winter buy they did respond. Thanks for that link Andrew. The Dash in the name was the key. I'd dearched Ebay before, but only found US venders.
Mark
Post by: PekkaNF on January 23, 2020, 11:37:50 AM
How much of that you need? in proportion of the melt?
Post by: RotarySMP on January 24, 2020, 08:25:18 AM
No idea. Once I get some, I'll go through Luckygen1001 and Olfoundryman's Youtube channel as they have some stuff on FeSi.
Mark
Post by: mattinker on January 24, 2020, 10:03:22 AM
I contacted Luckygen, he uses .25% to 0.5%. This must be added at the end of the melt and poured within ten minutes!
Post by: mattinker on January 24, 2020, 10:09:26 AM
eBay :
Andrew,
I have another search problem, then I'll stop high jacking this thread! I'm looking for a graphite sleeve or bush, 80mmx 100mm long with a 60mm bore, so far I've drawn a blank , any ideas? Regards, Matthew
Post by: awemawson on January 24, 2020, 11:09:20 AM
Mathew, I may have some in my 'EDM Sinker' box of electodes - I'll have a look tomorrow morning
(The big maker / supplier of graphite as used for EDM electrodes is 'Poco' so meanwhile search on that  :thumbup: )
Post by: awemawson on January 25, 2020, 07:58:36 AM
Matthew,
My bigger bits of graphite are:
BAR:
50 diam X 85
155 diam x 65
37.5 diam x 225
SLAB
270 x 210 x 20
(All dimensions mm)
Post by: mattinker on January 25, 2020, 08:19:49 AM
Andrew,
Thank you for looking! I am looking for a cylinder, 80mmx100 with a bore of 55mm, so, a bit bigger than anything you have! I have found the POCO Graphite site and I'll do some telephoning on Monday. I have found a very interesting youtube video on making air bearings using graphite, my idea is to make an air-bearing tool holder for my Clarkson tool and cutter grinder!
Thanks again, regards Matthew
Post by: awemawson on January 25, 2020, 08:54:56 AM
So what advantage has the graphite over bronze, or mild steel even?
When the air is applied shaft and housing do not contact each other, so it is only if the air supply fails when the spindle is still driven that there is any issue, and a pressure switch and air reservoir should cope with that contingency  :scratch:
Post by: mattinker on January 25, 2020, 10:51:19 AM
The advantage over metals is that is porous so the compressed air doesn't depend upon drillings to to create the cushion of air and that it is possible to bore it accurately by hand. With a chrome plated rod there would be no risk of corrosion!
Post by: awemawson on January 25, 2020, 11:58:49 AM
Sintered bronze bushes are porous so don't rule them out if the graphite isn't forthcoming (need to flush the lube out first though)
Post by: mattinker on January 26, 2020, 08:31:23 AM
Andrew,
Thanks for the idea, I've found another solution, 4x100mm squares, 25mm  thick that I can stack to get the size I want. Off to order an off-cut of chromed bar!
Cheers, Matthew
Post by: RotarySMP on January 26, 2020, 10:33:33 AM
Thanks for posting the Ferosilicon ratio.
The threadjack doesn't bother me, but a project as cool as a home made air spindle for the Clarkson it worthy of it's own thread. I'll be watching out for that, as I have a Clarkson as well.
Mark
Post by: awemawson on January 26, 2020, 12:00:14 PM
Matthew, beware that a fair amount of graphite came on the market a few years back  from behind the old 'Iron Curtain'  that was suspected to have come from 'test reactors' and was significantly radio-active  :bugeye:
Post by: Joules on January 26, 2020, 12:26:37 PM
Whilst mild radiation probably isn’t a major concern for wrinklies, better to be safe around younger generations.   Worth having in the workshop, especially with questionable scrap metals for the same reason as Andrew mentioned.
https://www.banggood.com/Geekcreit-Assembled-DIY-Geiger-Counter-Kit-Module-Miller-Tube-GM-Tube-Nuclear-Radiation-Detector-Geekcreit-for-Arduino-products-that-work-with-official-Arduino-boards-p-1136883.html?rmmds=mywishlist&cur_warehouse=CN
Post by: mattinker on January 26, 2020, 01:01:56 PM
Thanks for the warning Andrew, I'll risk it!
Post by: mattinker on January 26, 2020, 01:07:00 PM
Mark
Mark,
I've only got as far as rough dimensions in my head, I've ordered the Graphite and a 70x190mm off-cut of chrome bar, it'll get clearer when the materials arrive!
Cheers, Matthew
Post by: mattinker on January 26, 2020, 01:09:40 PM
hmmmm, I think I'll risk it!!
Post by: RotarySMP on April 28, 2024, 12:14:23 PM
Just to close the loop on this ancient thread, I did a video review of it...
and put it up for sale.
