Gallery, Projects and General => Gallery => Topic started by: Pete49 on August 28, 2012, 08:52:46 AM
Today I was doing some work and needed to drill a piece of round rod and thought I should make it easier so decided to make a v-block and clamp. Took most of the day but hey its another tool for the box . I used a small piece of cast iron I had and heres the result. crappy pic (phone) but works like a charm. Just need to get a shorter bolt.
Hi Pete
Would luv to see your images but they're only 96 pixels.Usually 640x480 or 800x600 is ideal.Perhaps resize
yeh good idea I'll use the camera this time
OK heres a better pic of the v block :ddb: The little blow holes will be filled with JB weld.............once I find it :doh:
