The Shop => Tools => Topic started by: Pete. on January 08, 2012, 10:28:12 AM
Been working on this all day yesterday. I had the pulleys and belt with this in mind but never got round to it. After my motor blew I decided to get it under way. Hopefully, I'll have it working today.
Photo is with the belt covers removed, I have to modify those to allow for the extra pulleys. What I've done is removed the step-pulleys and mounted them onto the bottom of the variable-speed pulley which itself is on a bearing shaft I have mounted on an extension plate bolted to the motor mount. The variable pulley distance is fixed but the whole assembly movs in and out on the original belt tensioning system to allow for the step-pulley belt to be adjusted.
All that's left to do is fit up a control system for the cone pulleys.
Neat :)
Is one of them sprung or are you going to couple the pair with a lever?
On the scooter one I fitted to my drill/mill, (http://wktodd.webspace.virginmedia.com/drillmill/page3.html) I had to swap the spring onto the driven pulley so the control was easier. I used a hollow intermediate shaft with a simple threaded wheel to squeeze the non-sprung pulley.
One is sprung - I can fit them either way round as the hubs interchange.
What is it that makes changing the speed easier with the sprung cone on the motor Bill?
My pulleys would only really fit well if the drive pulley (originally the one with the centrifugal weights) was fitted to the motor, and the originally sprung pulley on the intermediate shaft.
I couldn't see a way to control the spacings of the motor pulley - I looked at various lever mechanisms. So instead, I swapped the spring onto the motor pulley and used a pull rod, down inside the centre of the intermediate shaft, to control the spacing of the driven sheaves.
BTW Since the website pictures were taken, I have increased the tension of the spring and fixed the motor adjusting plate rigidly, to reduce vibration (you may find those rubber motor mount will also cause vibration/ resonance). The six screws that hold the extended motor shaft allow me to dial it in, to run as true as possible on my worn motor shaft. The nut on the extended shaft is a LHT to stop it undoing under load.
Aah I see now, a matter of covenient fit rather than a problem it the operation. I just tried to swap mine and they are ever so slightly different - one slides nicely but the other binds, so I'll carry on as I am fror now and see how it goes.
My mounts are plastic - just spacers really, and I'm fitting a bar across the pulley tops to stop things bending under load.
Ah.
The bar's a good idea; I was going to fit one to mine... - it would also help to reduce vibration :)
The force required to close the sheaves isn't great (I'm using a standard deep groove bearing on the top of my pull rod) , so as long as your motor can stand a reasonable thrust, all you need to do is arrange something to push on the top sheave via a thrust bearing ...
and belt-swapping will be rare event :nrocks:
Got it working now. I used an old cast iron flywheel I had kicking around for a speed adjuster. I can now get infinately variable speeds from 220-2550rpm.
Got to cut the guard about to accomodate the new variable drive then get it fitted up so I don't get caught up in the doings:
:nrocks:
Terrific job Pete :)
What sort of variable range do you get ?
Nice job pete but me being a thicky :loco:, I don`t know how that speed adjuster works!! Can you explain?
Nicely done Pete :clap: :clap: :clap: :clap:
Can i ask what the cone pulleys are off or were the can be bought ? as i may go down that route on my CNC build :dremel:
:nrocks:
Thanks Bill. On the top step pulley I get 220-1300rpm at the spindle, on the bottom (fastest) pulley I get 400-2550 spindle RPM. Middle is somewhere in between. It'd probably go a bit faster when it's warmed up fully. Swapping the belt is a very quick job on this mill because it has a nifty tensioner that jacks the motor back. I deliberately suspended all of the variable speed drive off the motor mount plate so I could still use that. Takes just a minute to adjust the belt.
Chris it works by using cone shaped pulleys and a wide belt. The pulley on the right is adjusted by turning the handwheel on top, which pulls the lever at the bottom upwards closing the pulley and making the belt move to the outside. The pulley on the left is sprung-loaded and adjusts itself according to how you set the right one. You can see the diaphragm spring in both positions in the pics. The adjuster screw is actually a chopped up G-clamp from Wickes :)
Rob the cone pulleys are simplabelt pulleys, these ones came off a Denford viceroy lather, Either a 280VS or 280 Synchro. They are also fitted to some wadkin stuff. Easier to find would be the pulleys Bill uses on his mill which is the cariable speed drive off a scooter. There are millions of those on the road right now.
Thanks Pete
Now you come to mention it , i thought it looked the same as the set up on a spindle moulding machine i use to run as a lad :palm:
I will have a look into the scooter ones :thumbup:
The disadvantage of the scooter one is they will probably only give, like mine, a range of about 3:1 to 4:1 at best (it's all that is required for a small scooter transmission)
Pete's lathe set gives nearly 6:1 range, which is much more useful.
Thanks Bill
Saves me wasting time looking for a scooter unit :med: ,,,,,probably just have to make one :dremel:
If you replace the adjusting handle with a wiper motor, you have push-button speed control :thumbup:
I had thought about that, but decided to stick with the manual adjuster. On my lathe the speed is controlled with a lever which is really handy for facing and parting as you can bump up the speed in a moment, but I see no reason to have that feature on the mill.
One thing I do intend to do is mount a RPM readout. I have a tachometer but I don't want to keep getting it out of the box each time to check the speed.
After seeing these i had to google a bit.. Variable speed - pulleys.. that was a knew one for me. =)
Wouldnt that belt wear down faster due to the fact that the pulleys change size?!
Think 'Daf'cars
It's one version of a CVT known as a Reeves drive, I believe:
http://en.wikipedia.org/wiki/Continuously_variable_transmission
It's available commercially on some machinery. I've had trouble with one on a Startrite bandsaw, and on Enco knee mills they tend to eat belts. I always assumed that the tension was too high on the Enco's, but it was just hours of use on the saw. It ended up being a single speed saw.
Think 'Daf'cars
I remember them...The DAF 44 with variomatic speed..... :D
Actually, many of the earliest motor cycles had variable speed pulleys as opposed to gear boxes.
That was in the days when there was no kick start and they had running boards and one held the valve lifter up until the whole lot eventually fired up-----------and by then you were too tired to jump on.
hello all.
How about this: http://www.gokartsupply.com/comet.htm :wave:
Have a nice day
CS
I finally got around to making a better video of my scooter one:
http://www.youtube.com/watch?v=7y7pPm5vPys
Hi Bill :clap:
I am really impressed with you M/D mods :bow: :bow: :bow: :bow: i think i may do like wise to mine :dremel:
Hi Bill :clap:
Thanks Rob :)
Do the spindle brake mod first - you will not regret it
Hi Bill
What are you using as a brake lining ? :proj:
A short length of the old V-belt:
Nice Bill.
Your sounds a lot smoother than mine.
