Gallery, Projects and General => Project Logs => Topic started by: dvbydt on August 10, 2011, 04:00:14 PM
When I ordered an MT3 ER32 collet chuck from CTC I also got a 20mm plain shank one like this :-
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/ColletChuck.jpg)
The shank was removed with a cut off disk in an angle grinder, leaving this :-
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/Body.jpg)
Next the outer body was turned and drilled. Originally I intended to shrink fit it to the chuck, but it seemed a shame to
ruin the finish, so I uused JB Weld and two grub screws.
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/Components.jpg)
The cut off shank was mounted in the 4 jaw and trued up. Using a 20mm collet in the assembly, it was faced
and bored out to 16mm.
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/Facing.jpg)
One of these :-
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/BlankEndMT2.jpg)
was turned into a 16mm spigot for the rotary table.
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/SpigotMT2.jpg)
So, I can now mount chuck on the table,
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/TableMounted.jpg)
or on the rotary table.
(http://i757.photobucket.com/albums/xx213/dvbydt/Engineering/Collet%20Chuck/RotabMounted.jpg)
That will hold from 2mm to 20mm dia.
Thats all my modding for Today's post!
Ian
Very nice Modding Ian. :thumbup:
That's cute, Ian! :thumbup:
A handy little weapon. Well done! :clap: :clap:
Now thats a neat idea far better than my method of doing the same thing.
Thanks for showing.
That is a really smart idea!
Nice job Ian. I like te dividing-head centering stub.
Nice job, :beer:
Just a suggestion
If you open it up to 20mm all the way through, the maximum size for the ER32(20mm) stock could go right to the bottom. It would mean making a new 20mm spigot though.
Thanks for your interest guys.
Dave, yes I did go through that idea but the soft end arbor was not big enough where I needed it. So, I decided that I would just use a table mounted 3 or 4 jaw chuck when necessary.
The concentricity errors build up so that it is about 0.10mm (0.004") TIR, but this can be reduced to 0.03mm (0.001") with a tap from a soft hammer.
Ian
If you ever have a need to use the full depth, you could shrink fit a larger piece into you arbour.
Nice work with what you have done though. :beer:
Yes Dave, I may do that. It has the advantage of being able to finish machine the spigot diameter on the mill, so getting it more concentric.
Ian
