The Shop => Tools => Topic started by: timeone on June 23, 2011, 05:58:02 PM
Title: Has anyone taken apart a Criterion rotary table
Post by: timeone on June 23, 2011, 05:58:02 PM
ive just picked up one cheap but feels a bit grindy due to sitting around so needs a good clean
ive managed to do the outside ok but would like advice on how it comes a part
also is the bung in the centre a std thing or should this be a hole for a taper??
(http://i103.photobucket.com/albums/m141/beekuk/miss/rt4.jpg)
(http://i103.photobucket.com/albums/m141/beekuk/miss/rt3.jpg)
what does this handle do ( knuring end )
(http://i103.photobucket.com/albums/m141/beekuk/miss/rt2.jpg)
Title: Re: Has anyone taken apart a Criterion rotary table
Post by: Trion on June 24, 2011, 03:09:50 AM
I have disassembled my Iberimex rotary table. I struggled for quite some time, but figured there was only one way to get it apart.
Things i did:
- Loosen the bottom locating flange of the round table, so that it should be able to be lifted out.
- Remove as many items as possible from the worm shaft
- Rotate the eccentric part of the worm shaft, to disengage the worm
- Remove the round table
- Pull out the shaft
