The Shop => Tools => Topic started by: KB3RLJ on June 09, 2011, 01:30:42 PM
I have a very old Victor lathe. Works great and I love it. There is a set of gears behind the headstock on a pivot. The two gears will engage gears on the spindle. I use it to lock the spindle if I need it to stay stationary but it seems like it should do something else. I have a video of it I will try to post. Any ideas?
KB3RLJ,
I think a couple of photo's and the video will help.
Got to use pictures. Can't figure out how to load a video.
Hi KB3RLJ
More than likely Back gear :dremel: ,,,,,, reduces the spindle RPM's
I thought that too but the lathe won't run with it engaged. Its completely locked up. That's what I use it for but seems complicated for that purpose. Wonder what else I have to do to drive it if its a back gear?
It will lock up ,,,,,,,,,look for something that allows the pulleys to run free ,,,,,, small latch or key
there will be something that locks the bullwheel ,,,,,,,,,the gear at the nose end of the spindle too the pulleys
I found it! There is a square head screw that locks the chuck to the spindle. Once I loosened that the chuck spun free. Engaging that back gear now cuts the speed way down. Thanks guys. I've learned something new today! :nrocks:
we aim to please :lol: :thumbup:
Rob,
Well Mr. Willson I'll give you an A+ for that. :clap: :clap: :clap:
