The Shop => Tools => Topic started by: BK on June 17, 2010, 06:33:30 AM
David (Stilldrilling) recommended a 2" diamond wheel for sharpening tools, spot on!! :)
Mine arrived this week, but I didn't like the Dremal type arbour, it looked too flimsey, so I made a small face plate for it.
(http://i160.photobucket.com/albums/t184/oldcranker/100_3128.jpg)
(http://i160.photobucket.com/albums/t184/oldcranker/100_3130.jpg)
Cleaned up, and tapped a thread, works a treat, thanks mate. :clap:
(http://i160.photobucket.com/albums/t184/oldcranker/100_3131.jpg)
Yer welcome Bernie!
I usually run mine at 1100 rpm. Never tried it at higher revs........ ::)
Incidentally.........This has great potential. :thumbup:
(http://i110.photobucket.com/albums/n95/Dayjo/P3160027.jpg)
Not got around to sorting it, yet. ::)
(http://i110.photobucket.com/albums/n95/Dayjo/P3160025.jpg)
The red trail, is paint from a new carbide knifetool I roughed out, just to try it..... :thumbup:
(http://i110.photobucket.com/albums/n95/Dayjo/P3160016.jpg)
I had only jammed it onto a 22mm spigot. Will mount it sensibly, and try out properly....... Sometime!
1060 rpm, that's my max without swapping the belt
Looks a good idea! - how is the work clamped up and held/offered upto to the grinding wheel?
By hand..... Like any other offhand grinder! :thumbup:
Oh I see, I was thinking you were somehow going to offer it up by locking it up in an arrangement around the cross slide.
Ideal for sharpening tools.
Yer welcome Bernie!
(http://i160.photobucket.com/albums/t184/oldcranker/DCP_3307.jpg)
Umm, that might be handy in my homemade wire brush/grind anything!! It's got a chuck on one end to take all sorts of things.
Bernie,
Don`t know if they`re available around your side...... Here`s where I got mine. (Don`t think I paid that much though!) :scratch:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280389682139
I would have thought that using a diamond disk like that in the lathe would leave diamond dust on the bed , cross slide, bearings and every other place you can think of
diamond dust makes a VERY good lapping compound
just my 0.02 cents worth
Stuart
Stuart,
The diamond grit stays stuck to the disc...... Certainly, much less messy than the grit from emery cloth.
I usually cover the bed ways, for either operation...... :thumbup:
