The Craftmans Shop => New from Old => Topic started by: awemawson on August 16, 2020, 06:45:34 AM
Title: Fitting Vee Guides to the Fanuc Tapecut Model M Wire EDM
Post by: awemawson on August 16, 2020, 06:45:34 AM
A few days ago I was glancing through old  threads and re-read my series on rebuilding my Fanuc Tapecut Model M Wire EDM machine. Now apart from playing about, frankly that machine has hardly been used - why? Well threading the wire is an ABSOLUTE PAIN  :bugeye:
The wire has to be passed through upper and lower guides that are hole in rubies - wire 0.25 mm hole in ruby 0.255 AND you had to thread from the underneath only being able to see the hole in a mirror. So perhaps you see why it has only had infrequent use !
Original thread HERE:
https://madmodder.net/index.php/topic,10085.msg113699.html#msg113699
Now while I was rebuilding the machine I'd had the opportunity to rob a Model L as it was being scrapped - a very similar machine but this particular one was equipped with 'Vee Guides' - no holes, just a sharp Vee shape into which the wire falls held by tension - a slightly less accurate method but VASTLY easier to thread !
Why did I never fit them :scratch: Well both machines had been heavily modified over the years and the method of fitting the guides was qite different between them, and the Vee guides were missing all the plumbing for the ionised water electrolyte. Perhaps I should explain, not only does the guide assembly (upper and lower incidentally) have to hold the wire in a precise location, it has  to convey the cutting current to the wire, and direct a jet of water along the wire to stop it melting and flush out cutting debris.
Now the current is applied to the wire by it sliding over a polished tungsten carbide stationary roller - relatively easy to engineer. The water is slightly more complicated as the water guide has to be able to open and close to admit the wire when threading. The original (missing) parts are complicated mouldings - but HEY - I HAVE A 3D PRINTER !
Now having had this thought I then could not find where the heck I'd put the Vee guides - I searched high and low, and it wasn't until someone wanted a TG100 collet from me that I went searching in my container and found a mystery ammunition box - and guess what was inside  :ddb:
So, over the next few weeks I plan to try and come up with a design that allows me to relatively easily swap between the two type of guide, and hopefully get it working.
I made a start today with a 'Psychological Clean Up' - a good hoovering to get the dead flies and dust off, then a sponge down with phosphoric acid to remove dried on bits that I been cutting, followed by a good rinse. Always better to work on a clean machine!
Workshop time is severely limited at the moment as Abi(gail) our new Viszla puppy joined us yesterday and needs constant attention - we are 'time sharing' hour on - hour off !
Title: Re: Fitting Vee Guides to the Fanuc Tapecut Model M Wire EDM
Post by: awemawson on August 16, 2020, 12:43:13 PM
Well the good news is that it seems that the mechanical mounting for the Upper Vee Guide is identical to the existing Ruby guide.  So it looks like just a bit of re-jigging of the water and electrical connections will sort that when I've 3D printed the rest of the jet.
For the Lower Vee Guide it's a bit more complicated, but I've found one small bit of stainless that forms half of the water jet for the lower head. If you read the rebuild thread you may recall I had to totally re-make the mounting as the original had largely dissolved away in the de-ionised water over the years. Now the good news is that I reused the blue insulating machinable ceramic spacer that it all sits on so hopefully mounting holes will be the same - with a bit of luck I can once more re-make this mount ensuring that it is compatible with the Vee mount, and much of the objective will have been achieved. It will still need the rest of its water system 3D printed but it should be possible.
(amazing what you can do in short gaps between puppy sitting  :clap: )
Post by: AdeV on August 17, 2020, 12:59:06 PM
Would it not be possible to lathe up a simple cone, which fit onto the underside of the lower guide, which would aim the cut piece of wire into the ruby? Or would that have been too easy?  :palm:
PS: Manual arrived safe & sound last week, thanks; I forgot to mention it! Or maybe it was the week before - time seems to be flying by right now! I blame the baby...
Post by: awemawson on August 17, 2020, 01:29:32 PM
Glad arrived Ade  :thumbup:
The problem is access - there is very little room under the lower ruby (actually I think I may be wrong, they may be artificial sapphires).
Post by: awemawson on November 07, 2025, 05:34:17 AM
Another 'blast from the past' - steaming up the
wire EDM machine the other day and realising what a pain wire threading is using the ruby hole guides (0.25 mm wire to be threaded through 0.255 mm hole upside down in an invisible place) I decided to knuckle down and sort out the fitting for these guides.
As far as I can tell the bits I have are mechanically complete but are missing the removable half of the de-ionised water fittings. They probably stayed on the scrap machine when these used Vee guides were obtained. So the task is to 3D print them.
So far I think I've got the lower guide sorted and a 99% fill version is printing as I type - I've been using 13% fill ones for prototypes getting the shape right.
A few hurdles along the way: Not used Fusion 360 for several years so it insisted on being updated - still not an intuitive program (for me at least). Eventually got what I thought was right, exported it to the Cetus 3D printer and in the process of trying to get is sat on the right plane to avoid printing loads of scaffolding ended up printing a mirror image  :bang: Still as I say final version now printing in Pet-G.
Will start modelling the upper nozzle surround over the weekend hopefully.
Post by: awemawson on November 08, 2025, 09:33:16 AM
So this morning I 3D-Modelled the Upper Nozzle assembly and printed a 13 percent density version to test fit. A bit of tweaking to the model which fitted fine but I had to extend one face 1.5 mm for cosmetic reasons to line up with other features.
This one was slightly more complicated as I've had to incorporate blind holes to lead the de-ionised water from the right to the left to allow the existing plumbing to (hopefully) fit.
99 percent version now printing with an hour to go. I hope that there's enough filament on the reel.
Post by: awemawson on November 09, 2025, 10:15:10 AM
So today's job was (theoretically) unbolt the original diamond guides and bolt on the Vee guides in their place. But as we all know there is always at least one GOTCHA in the way.
Firstly not having previously stripped out the mounting plate for the lower guide, as it's mounting 'looked' the same I had ASSUMED that it was - wrong - different hole spacing. Also to gain the full advantage of the Vee guide over the hole type it needs to project out into free space rather than be mounted on a plate with a hole (or you still have to thread the wire though an (admittedly much bigger) hole. Time for a re-design. Initially I'd thought order up some stainless and start machining but then sense prevailed and I've drawn it up in Fusion 360 with a prototype printing as I speak.
Post by: awemawson on November 09, 2025, 10:22:42 AM
Removing the upper guide assembly was just a case of removing four bolts along with the water feed and electrical connections. It is surrounded by two stainless steel splash guards that keep the upper 'U&V' servo drives dry - they were FILTHY !
Mounted on this assembly is the redundant 'wire cutter'. When made this machine had automatic threading of the wire (sheer luxury) but it was so unreliable it was removed apart from the cutter.
Had enough today - back tomorrow for more fun.
Post by: awemawson on November 11, 2025, 10:40:54 AM
Today I hot pressed the M4 screw sockets into the 99% solid PetG 3D printed guide mount using a soldering iron, and then went ahead and mounted up the new Vee guide assemblies.
Doing a trial threading of the wire it was very obvious that the wire was not vertical - heart sinking moment  :bang: But  then I thought - hang on the upper mount can be controlled to set the wire to the angle you want - is in the range of movement - yes very easily. I set it vertical to my eye with very minimal movement of the U and V slides (X & Y axis for the top of the wire). So one of my measurements of the lower mounting block is obviously slightly out, but it looks like not worth re-printing as it can be adjusted out.
So once I'd wired up the contact blocks  (upper and lower) and made a couple of plumbing connectors for the de-ionised water I gave it a 'powered up' run and nothing went bang  :ddb:
Now I need to read up on using the verticallity jig to re-set the wire dead nuts on (theoretically simple - the jig has upper and lower neons that light up when the wire touches them - I've done it before but its a good ten years ago.
Meanwhile a distraction arrived. All this 3D printing reminded me that although my Cetus 3D printer has given (and is still giving) sterling service I'd always intended to upgrade to a totally enclosed machine to keep out the workshop draughts and dust. So I've bought a Bambu Labs P1S Combo - half of which arrived this morning - but I'm being very good and not touching it until I've finished the Fanuc Tapcut Wire EDM.
Post by: AdeV on November 12, 2025, 06:16:25 AM
I know nothing about the Cetus (except it's a bed-slinger, IIRC, not a core-XY), so the Bambu is going to prove to be a world apart from it. In a good way.
IIRC, the "Combo" is shipped with the AMS unit inside the printer, so it's probably all arrived, not just half of it...
I struggled to justify the price of a Bambu (plus they'd just recently announced that they were going closed-shop with their software, and that if you wanted to use all the features of the printer you had to use their online services), so I went for a Qidi Plus 4 instead. Superb machine, and now I have their equivalent of an AMS, I can do most things a Bambu can do - also slightly bigger, although the Qidi experience isn't as polished as the Bambu one...
(https://uk.qidi3d.com/cdn/shop/files/1751251677_0.png?v=1761556100&width=400)
It replaced an Ender 3, and it's just so much better I actually threw the Ender away!
Post by: awemawson on November 12, 2025, 08:03:07 AM
Two more big boxes have just arrived but they are staying as is until the EDM is fully sorted.
Post by: RussellT on November 13, 2025, 04:21:01 AM
Well I Have an Ender 2 - I'd have come to Liverpool to collect it.
Post by: awemawson on November 13, 2025, 06:52:03 AM
Well Fanuc Wire EDM machine back in comission (*) as of this morning having satisfactorily cut some bits using the new Vee guides. I even gave the polycarbonate water screens a good clean up with Windowlene and the tinwork a clean up with Flash - it fairly well sparkles now  :ddb:
So no excuses - unbox the P1S combo from it's three boxes. Just spent a while watching set up videos !
* About time too - I started this Vee guide business over five years ago  :beer:
Post by: AdeV on November 13, 2025, 07:17:49 AM
You're welcome to have it if you want it! I've got an original Ender 3, and an Ender 3 v2, both are destined to be parted out - I just haven't got A Round Tuit yet. Both have glass beds & I have one of the original textured beds too.
Post by: RussellT on November 13, 2025, 04:01:23 PM
PM sent.
Post by: BillTodd on November 14, 2025, 01:23:07 PM
Interesting, it doesn't cut immersed?  Just in a jet?
Post by: awemawson on November 15, 2025, 05:34:20 AM
There are water jets both on the lower and upper guides forming a 'straw' of the de-ionised water round the brass wire
