The Craftmans Shop => New from Old => Topic started by: russ57 on August 08, 2020, 07:59:42 AM
Title: Not quite new, but rescued
Post by: russ57 on August 08, 2020, 07:59:42 AM
So, cleaning the carpet with a borrowed hoover carpet 'washer'. (desperately needed, my 24yo son just moved out and he wasn't big on cleaning his room...)
Anyway I tripped over the cord and everything stopped...
I had a feeling the cord had partly pulled out of its grommet, and peering through the air holes thought maybe I could see bare wires inside.
Easy I thought, just take the cover off....
So after removing basically every screw, I had a cleaner that looked like it had been through a crusher...
[emoji17]
(https://uploads.tapatalk-cdn.com/20200808/e0894bf43ec1141d3bffbfd5cfcb49e8.jpg)
And the offending cables...
(https://uploads.tapatalk-cdn.com/20200808/9614dab6747f53d39bfc2f34274e14f2.jpg)
It appears the insulation caps on the crimp connectors have parted company. Except for the earth, which had the wire pull out..
A bit of heatshrink and a couple of hours reassembly, and it's a goer. And only 2 screws left over...
I reckon I put about 20 in, no chassis whatsoever just plastic bits screwed together.
(https://uploads.tapatalk-cdn.com/20200808/8a674caaf59a7aa3771a4907b1f8ed48.jpg)
-russ
Title: Re: Not quite new, but rescued
Post by: Brass_Machine on August 14, 2020, 04:03:12 PM
Love it when we fix something in the "throw away" culture. Many friends just stare in disbelief when I fix something that was going to be thrown out...
Good job!
