Gallery, Projects and General => The Design Shop => Topic started by: PekkaNF on March 03, 2019, 02:53:31 PM
Title: Mill/drill quil stop and postion measurement
Post by: PekkaNF on March 03, 2019, 02:53:31 PM
Got one of these popular drill/mill combo and quite like it.
(https://www.warco.co.uk/1950-large_default/major-milling-drilling-machine.jpg)
Installed DRO and that is definate improvement. However spindle stop is not tha great and spindle depth measurement is next to useless.
(http://uploads.tapatalk-cdn.com/20140613/hanuquja.jpg)
Saw this video, a little different mill, but very similar spindle construction.
https://youtu.be/4eY_8wCVGMg
Stop looks good and would be possible to make with only minimal changes. Good.
What about spindle postion measurement. I actually like the idea of local measurement display.
Any experience on this sort of scales:
https://www.machine-dro.co.uk/vertical-linear-digital-scale-150mm-6-inch.html
Or the type that has separate display.
I'm trying to find a model that has big and clear display.
Title: Re: Mill/drill quil stop and postion measurement
Post by: philf on March 03, 2019, 06:23:56 PM
Pekka,
ArcEuro have the scales with a separate display.
https://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display/Digital-Readout-Bars-with-Dedicated-Remote-Display (https://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display/Digital-Readout-Bars-with-Dedicated-Remote-Display)
I use one for the z-axis on my mill. The only problem I found is that the display turns off after a short time of inactivity - but it does retain the position when turned back on again.
Post by: Joules on March 04, 2019, 04:56:42 AM
Fit a backlight to the display, it only need be an LED to side light the display, but this makes a huge difference.
Post by: PekkaNF on March 04, 2019, 05:09:35 AM
Good info thank you.
That automatic power save sounds annoying. Luckily value does not zero on power up - like it does on one cheap caliper I have.
Post by: PekkaNF on April 27, 2019, 04:42:05 AM
Build "prototype" some time ago, hence only "busines ends" of the parts are finished and rest of them looks garden engineering.
And because the cover was off I added RPM-display, big red LED display, but reading update is slow and program appears to writen by 3 years old using Basic.
My approach is slighty different compared to Sefan's construction, the mechanical idea is very much similar and rod/stop is almost 1:1 same construction - even with epoxy and release wax.
Difrerence comes in that my mill is diferent and there was even less space at the front of the spindle, I needed to make parts smaller and snag off 2 mm from casting.
Instead of DTI I put cheap scale on the side, seems to work fine.
