The Craftmans Shop => New from Old => Topic started by: Canobi on June 30, 2018, 11:51:43 AM
Title: Dore Westbury Mk1 Mill Restoration, finishing and one or two mods.
Post by: Canobi on June 30, 2018, 11:51:43 AM
Hi folks :)
Taking my first steps into machine refurbishment as I have a Dore Westbury Mk1 milling machine in desperate need of some TLC.
For those that don't know, the Dore Westbury mill is a unique machine as it was sold in kit form and was designed such that it could be completed using a myford size lathe at home. This makes it a perfect candidate for first time referbishers as it's construction is very straightforward and simple enough for a newbie engineer/machinist such as myself to tinker with and fix.
Detailed info about the Dore Westbury can be found on lathes.co.uk here:
http://www.lathes.co.uk/dore-westbury/ (http://www.lathes.co.uk/dore-westbury/)
I will be deviating from the original build plans a little, as a result, I'll also be making a few tools along the way in order to perform the operations that don't appear in the build notes or technical drawings, so this could be quite the adventure.
I'm about halfway now and will keep updating this post as and when new material has been uploaded to my channel.
Pt1
Pt2
Update #1
Update #2
Pt3
Update #3
Pt4
Update #4
Pt5
Update #5
Pt6
Title: Re: Dore Westbury Mk1 Mill Restoration, finishing and one or two mods.
Post by: vtsteam on June 30, 2018, 12:46:20 PM
Much as I like videos, I always think Youtube videos should be an adjunct to a project thread on a forum, rather than the substance. Otherwise  forums will eventually just consist of links to people's personal Youtube channels.
In case anyone cares, I have unnecessary scripts turned off in my browser. So your YouTube embeddings appear as blank black spaces to me. I don't see what you're posting and generally won't follow the links or comment if it's only videos.
So....any chance of a build thread? Sounds like a great subject.....that would be awesome!  :coffee:  :beer:
Post by: awemawson on June 30, 2018, 01:46:20 PM
And I thought it was just me being a grumpy old fart!
I cringe when videos start with totally irrelevant 'effects' and more often than not stop watching at that point ! It's akin to every technical program on TV these days being 'a show' and appealing to the lowest denominator rather than being factual and informative as they should be.
<rant mode off>
Shame as the subject matter could be very interesting to many. There must be loads of Dore Westbury's 'out there' - I well remember drooling over the adverts for the part machined castings in Model Engineer when there was absolutely no chance of being able to afford to buy them
Post by: Canobi on June 30, 2018, 02:49:54 PM
Well, it's mostly been stripping, cleaning and painting so far (going with a black and brass colour scheme), though the last two videos show a new, simple and rather unique way to do brass plating at home with just a blow torch, drill and a brass wheel brush.
You are of course correct though and I will endeavour to post write ups and their accompanying pics as well as vids here from now on. Actually, small but significant progress suits written and pictured posting anyway so I hear ya and oblige ;)
Thursday and Friday afternoon were spent making a replacement spindle drive plug blank:
(https://i.loli.net/2018/07/01/5b37c9d17d509.jpg)
(https://i.loli.net/2018/07/01/5b37c9d04fd49.jpg)
The original plans call for a brass piece which is drilled and filed to include the keys that fit the slots either side of the spindle shaft. While the original design and method of the part's construction lends itself very well to even the most meagre of equipped home shops, I'm going to deviate and use actual key stock.
This part is actually quite involved and I'll need to finish making my keyway slotting attachment (made a start on the base and cut the radiused slot for the ram tube) and make transfer pins and screws to ensure the new holes line up with the pulley's geared drive tube in order to finish it.
My bearing grease arrived yesterday, so last night I installed the outer races of the new spindle bearings in preparation for full essembly (new ones are Timpkin tapered rollers, the last ones were single row deep groove and were well and truely trashed). However, I discovered that the replacements were undersize, so had to shim them for a press fit. I opted to put short lengths in three places per side as a wrap aroumd was proving somewhat troublesome for me:
(https://i.loli.net/2018/07/01/5b37d0bcb7989.jpg)
Today's small progress was making some .1/8" thick brass washers for the main column support casting bolts. In order to keep in with the colour scheme:
(https://i.loli.net/2018/07/01/5b37c0b86ac43.jpg)
(https://i.loli.net/2018/07/01/5b37c0b5c78fd.jpg)
My next move is to heat black the bolt heads for the column support casting with boiled linseed oil, which will be featured in the next video, along with some footage of the above parts being made.
Post by: awemawson on June 30, 2018, 03:45:40 PM
That looks to be a major discrepancy in the bearing size. It's rather important that the quill bearings are very rigidly supported.
There are commercially available press fit sleeves to fix this situation but my google foo is letting me down finding a link. They are basically a tightly corrugated sleeve that distorts evenly as the undersized bearing is pressed into it
Post by: awemawson on June 30, 2018, 03:50:27 PM
Here you are - found them:
https://www.mcmaster.com/#cadinlnord/null/=1dih959
Post by: vtsteam on June 30, 2018, 04:03:10 PM
Thank you Canobi!  :beer:
Post by: Canobi on June 30, 2018, 04:30:03 PM
Yeh, that's been playing on my mind too. I didn't know about the sleeves so thanks for bringing them to my attention, I shall look into them forth with :)
Post by: Canobi on June 30, 2018, 04:31:16 PM
Brilliant! Thank you again my good man  :beer:
Post by: Canobi on June 30, 2018, 04:47:27 PM
My pleasure, I prefer the forum format anyway really. I've been concentrating on developing my YouTube channel recently and used the restoration as a platform as there's very little on YouTube regarding Westbury mills and felt others might benefit.
I hadn't planned on posting the restoration on forums and as a result I haven't any WIP pics of previous progress but I have a few mods planned that you guys might get a kick out of, hence starting the thread.
Post by: awemawson on June 30, 2018, 05:08:47 PM
Also called 'tolerance sleeves' - sad how these things come back to you in dribs and drabs  :clap:
Post by: Canobi on June 30, 2018, 06:37:04 PM
I'll have to come up with a plan b for bearing shims as McMaster don't do them in the size I need. Largest imperial they have is 1.1/8" and my bearings are 2.24" OD.
Post by: vtsteam on June 30, 2018, 07:05:01 PM
Canobi, what is the difference in diameters that you have?
Seems to me if they are the right thickness, and uniform in thickness, that multiple shims are no less secure than a corrugated whatzit.
The main thing is that the bearing is central to the quill and aligned with its couterpart, that its face hits a proper register, that the outer ring won't spin, that it is supported enough not to distort from pressure of the rollers.
I don't see anything wrong with your multiple shim idea, except that I would suggest more of them so the gaps between them are minimal -- so the rollers won't distort the outer ring.
The face register should align the bearing (if proper itself), the shims if sized right and uniform thickness should prevent spinning and should keep the bearing centrally located.
Post by: Canobi on June 30, 2018, 07:44:42 PM
The OD of old bearings is 2.25", new ones are 2.24".
Post by: awemawson on July 01, 2018, 01:35:24 AM
If they are sold as 2.25" bearings and are in fact 10 thou under size they are faulty and should be replaced by your supplier
I'd assumed that it was the housing that was the problem. Bearing outer diameters should be within tenths of a thou of nominal
Post by: vtsteam on July 01, 2018, 06:40:39 AM
Yes I was asking what is the size of thfe bearing and the housing, not the other bearing, and in thousandths at leasr, not hundredths.
Post by: awemawson on July 01, 2018, 07:22:50 AM
Looking at the list of bearing sizes on the Simply Bearings site, 2.24 IS one standard as is 2.25 so I reckon you've been supplied with the wrong size
Post by: Canobi on July 01, 2018, 07:37:43 AM
The fault lies with me, they were indeed touted as 2.24" (from simply bearings in fact) and being a noob I just assumed they would be the same as the old ones.
Took a fair bit of searching last night and this morning but I finally found and acquired a pair of tolerance rings that were the correct size for my bearings, so I'll be carefully extracting the new races from the quill later.
Right now I'm prepping for hot blacking/brassing some of the bolts and levers. I just knocked together a quick and dirty rig using a dead three jaw chuck that came with my lathe for holding them while I heat and coat them. The chuck spins freely on the bar so I can turn it as I work on the parts:
(https://i.loli.net/2018/07/01/5b38ba265db02.jpg)
Post by: Canobi on July 01, 2018, 12:59:43 PM
Hey guys  :wave:
I heat blacked the column support casting bolts today and my rig turned out to be very useful.
Wasn't too happy with the results of the first try though, was more dirty brown than solid black. I changed it for a fresh silver one and this time I brushed off a dirty white looking oxide layer that develops as it gets hot.
I also sunk more heat into it, this time I waited till the bolt head went from turning a dark straw to just touching the blue zone temps, then hit it with the oil cloth and then the torch to scorch dry the oil in an alternating pattern.
The black built up relatively quickly after that and I found the first sign of a good take is that as the oil dries, it develops a matt finish and dries really quick, then after a short while, dries to a nice gloss finish.
At this point the blacking is essentially done, but for a deep black and slightly more enduring coat, I added a further 15 wipe overs and then dropped it in the water to cool off.
They turned out exactly as I'd hoped, which is a fair achivement on a first try:
0(https://i.loli.net/2018/07/02/5b390284cc685.jpg)
(https://i.loli.net/2018/07/02/5b390284d1873.jpg)
Here's how they will look once the column is fully assembled:
(https://i.loli.net/2018/07/02/5b39028507da3.jpg)
Next step is to brass and black the levers, gotta feed the myself and the sprogs now, of there's time after dinner, I'll be back with more this evening  :thumbup:
Post by: beeshed on July 01, 2018, 01:10:54 PM
Is the brass finish on the cast iron electrically connected to the base or is it over an oxide layer?
Don't wish to carp about videos but please bear in mind that youtube doesn't  have a fast forward like a PVR so you need to do the fast forward through the boring repetitive bits for the viewer while making the original edit.  :ddb:
Post by: Joules on July 01, 2018, 05:25:41 PM
You can however drag the video time line to skip through, or go back, in YouTube videos.
Post by: vtsteam on July 01, 2018, 10:47:47 PM
Beeshed, it's applied by heating the iron casting with a torch and spinning a rotary brass wire brush held in a drill against it.
Folks should understand that differentially heating an iron casting with a torch can cause it to crack. Cast iron has poor tensile strength, and while heating it uniformly is usually not a problem, heating one section causes that area to expand while the cooler part does not. This cause tensile stress, and cast iron while high in compressive strength, is poor in  tensile strength.
In the video, Canobi is heating only bands on the casting with the torch. Luckily there is a slot running down the casting here, and so axial expansion is easily accommodated without building up a lot of stress.
How much differential heating can be accommodated by a casting will come down to the specifics of casting dimensions and the amount of heat, as above. But it is important to realize that cracking can happen. A better approach is to heat an iron casting more or less uniformly by playing a torch over more than just a small area. And letting the whole cool slowly -- a favorite approach I use when brazing, or welding is heating uniformly, and then to bury the part in wood ashes to cool. These insulate and slow the cooling rate. Castings seem to crack most often in the cool down stage.
Post by: Canobi on July 05, 2018, 07:41:57 AM
Thank you for the info regarding heating iron castings vtsteam, I didn't realise I'd dodged a bullet there. I don't think I'll be doing that to cast iron again, well maybe not until the cold season at least, where I have a ready supply of hot coal ash to bury the hot parts in.
Steel on the other hand is fair game any time and I got round to brassing the arms on a couple of the levers:
(https://i.loli.net/2018/07/05/5b3dfce3a633c.jpg)
I then experimented with a followup heat black session but it was a total fail, so fine sanded the terrible coating off and opted to paint the bolt half instead, which I did along with the aluminium motor mount brackets:
(https://i.loli.net/2018/07/05/5b3dfce361169.jpg)
The fail was due to a combination of things. Firstly, there's no way to mask off areas you want to leave untouched , unlike when painting a part. The second was an unknown factor, the steel just didn't want to take the black. I had to use a scotch bright to buff off a light amount of flash rusting before I started heating and coating it so my initial thought was that it was mild steel but could it be a form of stainless perhaps?
