Gallery, Projects and General => Project Logs => Topic started by: thecogwheel on August 07, 2017, 09:13:54 PM
Title: Quick Change Toolpost Build
Post by: thecogwheel on August 07, 2017, 09:13:54 PM
I completed my quick change tool post based on Metal Lathe Accessories' MLA-23 toolpost last week. It was scaled down for the 8" swing on the Schaublin 102. The original design might have been a bit large being designed for 9"-12" lathes, although it may have worked. I made a number of other changes as well.
(https://thecogwheel.files.wordpress.com/2017/08/toolpost_finished.jpg)
Bits and pieces:
(https://thecogwheel.files.wordpress.com/2017/08/toolpost_pieces.jpg)
Here is the build video of it (you may want to watch it in Youtube as it will give a bigger picture):
https://www.youtube.com/watch?v=8d7xY4UNGAg (https://www.youtube.com/watch?v=8d7xY4UNGAg)
Now onto the next build.   :proj:
Title: Re: Quick Change Toolpost Build
Post by: SwarfnStuff on August 08, 2017, 01:26:02 AM
Thanks for posting,
         Well worth a look and just maybe I will make one with a further mod to suit my 7X. At the moment I am using one that is the aluminium, piston type and ok for light cuts. I see this design should hold the tool holder more securely plus it brings the tool back inside the top slide base rather than the usual overhang.
Thanks again.
Post by: krv3000 on August 08, 2017, 04:43:06 PM
hi a job well dune
Post by: TURK122 on October 10, 2017, 02:19:26 PM
I'm in the process of making this out of 316l stainless steel
Sent from my SM-N910F using Tapatalk
