The Shop => Tools => Topic started by: smiffy on April 03, 2016, 06:28:00 PM
Title: Boley 5LZ
Post by: smiffy on April 03, 2016, 06:28:00 PM
Had to make a new pin for a local farmers plough . 50mm dia and one end threaded 1-25 pitch on a reduced shank of 45mm. Material is EN24
So set my boley for semi auto screw cutting and this is a video of it working prior to cutting the thread.
The lathe  has 2 micro switches on the bed operated by stops on the apron . As the tool approaches the end of its cut the spindle is electro mechanically braked and reversed at 4x the cutting speed , when it has fully returned the spindle is reversed and cut put on and a the processes repeats itself  The lead screw is anti backlash and always engaged while screw cutting
There is no screw cutting gearbox but a large  selection of gears and it can cut Metric Imperial Modular and DP pitches https://youtu.be/yz0ZS8CtBju
Title: Re: Boley 5LZ
Post by: smiffy on April 03, 2016, 06:32:19 PM
https://youtu.be/yz0ZS8CtBju Maybe this link will work
Post by: smiffy on April 04, 2016, 03:23:19 AM
 Having problems with the link if this does not work i=I give up
https://www.youtube.com/watch?v=liXxW3MXmCY
Post by: RotarySMP on April 04, 2016, 05:29:25 AM
The third link works for me. Sweet lathe. Where did you end up getting it from?
Mark
Post by: Rick O Shea on April 04, 2016, 06:25:00 AM
Hi Mike
That is a glorious lathe, nice bit of work too.
best wishes
Mike
Post by: smiffy on April 08, 2016, 04:51:09 PM
According to the Boley book I have spindle is a 3 Din 55 022 bored 4 MT and was available on request
Post by: RotarySMP on April 08, 2016, 04:55:38 PM
Now I get it.  :doh:
Size 3. (same as Camlock D1-3). I wonder how many different flavours of the KK short taper nose the germans came up with?
Certainly a better spindle nose than the threaded one.
Mark
