The Shop => Tools => Topic started by: vtsteam on June 02, 2015, 01:07:50 PM
Title: Files Ordered
Post by: vtsteam on June 02, 2015, 01:07:50 PM
I've been using the same 2 larger files for a few years -- trying to preserve them by using a grinder or lesser files on rough castings first, where necessary to get below sand and scale. My best file is used last, the duller of the two gets first dibs. But zinc alloy and brass work lately have pointed out the fact that it's probably time to move on to a new one.
My two most often used files are both big 14" flat double-cut Nicholson bastards, and not easily replaced, at least locally. Online prices seem to put similar files in the 25+ dollar range, even on Ebay, not including shipping, which in several ads brought the total to $40.
However, I was able to find a Nicholson catalog online, and through that, get a part number for the file. A new lookup on Ebay with that number found them available from Zoro tools for $14, plus free shipping if I made up a $50 order. So I plunked down for two of them. Looking through the Zoro products available I found a few useful items so I added a tube of Dykem Hi-Spot engineer's blue (for scraping), a bottle of Loctite 860, and a commercial size pack of JBWeld epoxy, all totalling almost exactly $50.
I realize files aren't the most glamorous shop tools to report here on the forum, but I sure can take a lot of metal off easily with those big files, and when dealing with castings they really make life eaasier. They also work extremely well for quickly bringing a surface to flat before final filing, scraping or finishing. Or conversely for rounding square corners with a few strokes.
I do use a lot of other kinds of files, and finer ones, too. But these are real workhorses in my tiny shop, and surprisingly versatile. They have also outlasted many other tools, though you'd think they'd dull quickly, considering what they have been used on. I do try to treat them well. I file in one direction. They hang from the wall, I clean then if needed (seldom since they are coarse) with a card.
Both my old files have a very slight bow, but I use this to good effect where needed to take off different parts of a surface, and where I want a true flat, I reverse them every few strokes, check frequently and adjust as needed. A common beginner mistake is to assume that flat files are true flat and just file away to finish hoping to flatten a part. When checked, disappointment sets in. Happened to me early on until I realized how to compensate.
Anyway, I'm kinda excited to get these in the mail. I know they will make a difference.
Title: Re: Files Ordered
Post by: RobWilson on June 02, 2015, 01:41:50 PM
Nothing wrong with being in love with your files Steve  :dremel:
What you need is one of these mate  :D
(http://i1066.photobucket.com/albums/u410/RobWilson100/Musee%20des%20Arts%20et%20Metiers%202013/P1070005_zps383a9d3e.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/Musee%20des%20Arts%20et%20Metiers%202013/P1070005_zps383a9d3e.jpg.html)
(http://i1066.photobucket.com/albums/u410/RobWilson100/Musee%20des%20Arts%20et%20Metiers%202013/P1070006_zps9b8a815a.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/Musee%20des%20Arts%20et%20Metiers%202013/P1070006_zps9b8a815a.jpg.html)
And make your own files ,,,,,,,,,,,,,,,,,,,,I may have a bash at making one , I do fined the machine interesting ,not to mention its quality craftsmanship , probably forged ,chipped and filed .
Post by: Lew_Merrick_PE on June 02, 2015, 01:55:33 PM
So, (1) card your files well & regularly and (2) chalk or oil them when working.  Having served my apprenticeship under an old German Guild Master (he was always addressed as Herr-Meister), I have somewhere in the close neighborhood of 350 lbs of files (and about 200 lbs of scrapers) in my tool chests.  I have had some success in recovering worn files using the sulfuric acid dip approach -- just enough success to keep me trying it when one gets truly worn.  [If that fails, the result gets placed in the scraper-source material box.]
Excepting the bench files that "live" at strategic locations around my shop, my files store are a set of (1/4 inch) masonite boxes with dividers that allow each file to "live" in its own slot.  The boxes are sized such that they fit in larger (hinged lid) boxes so that all my (say) 10 inch files live in (several of) the larger (and identified) boxes.  The larger boxes in turn "live" in a wheeled cabinet such that each has a pigeon hole that allows visibility of the identification and "pull-out" access.
After all, they were known as German milling machines during my apprenticeship days...
Post by: awemawson on June 02, 2015, 02:31:01 PM
A cheap and cheerful 'recovery' for an old file is to let it rust (degrease first to get a uniform rusting) then de-rust it in citric acid solution. This has the advantage of avoiding the sulphuric or nitric acid compounds often recommended which aren't too well behaved anyway about a workshop.
Most of my files each have a short length of plastic plumbing pipe to live in, fixed vertically in a shallow tray fixed to the wall behind my bench to stop them damaging each other
Post by: Lew_Merrick_PE on June 02, 2015, 03:03:37 PM
I used such an approach for storage until I realized there was not enough hanging space in my shop!
About half of my files have safe edges ground on them for tasks such a filing to a shoulder or filing dovetail slots.
One thing I miss is that there used to be companies (such as Portland File) that made true cylindrical files to standard diameters.  I only have a few left anymore...
Post by: vtsteam on June 02, 2015, 03:28:57 PM
Rob, would you make your own  version or would it be somewhat period, like the machine in the photograph? Or a replica?
Lew, interesting to hear of your experiences with your own files.
Andrew, I have never tried to restore a file before, but have heard of that or similar methods. Maybe I'll try it on my dullest 14" since I'll shortly have 4 of them. I have wondered how much rust people meant, since it could vary from a paintcoat overnight, to a year in the garden with pitting.
I guess it would depend on how fine a file it was, too. Mine are very coarse. I suppose that the way it works is to remove the surface of the teeth all over, first by rust, then by removing the rust.
Ideally there would be a way of attacking the tooth from the sides faster than the tip, Removing the tip would tend to dull it. Some slight (not total) resist method on the tip of the teeth might be more helpful than the stock method.
A recently used but old file would probably tend to have active removal happening more at the exposed metal tips than in the patinated valleys, which is the opposite of what is wanted, I think. Cleaning, definitely important, as you say.
Post by: RobWilson on June 02, 2015, 04:26:26 PM
I really like the original Steve and have a  pipe dream  about making a faithful copy , down to using only hand tools to make it  :loco: .
Grimshaw  Shop Kinks 1911   ISBN 4' 3"  1/8
File -Sharpening .  A propos of files and their work , it is strange that an American invention ,the sand- blast , has been taken hold of so well in England  :wave:  and on the continent of Europe for file-sharpening , and seams to have been practically neglected on this side ,in the same connection . If you look at a new file you will find that there are on the ends of the teeth ,certain small-hooks , and these correspond to the wire edge  on a knife or a razor. Of course they are not desirable ; but there is no way of making file teeth with a chisel ,particularly if held by machine , without having these same hooks .
The sandblast cuts files without such wire edges ,and re-cuts old ones better than they can be done by hand; and many English  establishments have their new files given a little sand blasting before they are put into service ,the object being to give them a better cutting edge than the makers turn them out with .
May be worth a wee bit of experimentation .
Post by: Jonny on June 02, 2015, 05:31:33 PM
Quality files are extremely hard to come by the last 11 years, nothing cuts or lasts as long nowadays even from same producers.
Used to get through a 3 sq 12" bastard every 3 days that would have lasted shy of two weeks.
Had loads of specialist files even S shaped, even modified brand new ones for one purpose.
Very true you will never file flat with a flat file, most have a belly to them.
Considering the rate we went through files and cost of the best files obtainable worldwide we tried several exercises in having them recut. Actual recuts tend to last 1hr to 6hrs that brand new lasted 3 days and 1/3 cost of new file.
Acid refurbing had a scrap rate of around 60%, the 40% returned you had to sift through to find one that cuts even though physically looked good ok for a couple of hours at best. In the 40% returned many had not got the sharp peaks, some even lost the sharp undercut looking like a series of roundovers typical with acids. ie certain areas will go before other areas, fine if its the undercut but not on cutting edge.
Post by: Arbalist on June 02, 2015, 05:49:36 PM
I don't use files as much as I used to but these look interesting.
https://www.dictum.com/en/tools/woodworking-metalworking/rasps-files/files-for-metal-working/704405/glardon-vallorbe-valtitan-flat-file-cut-0?ffRefKey=16PYV9Z9c
Post by: Will_D on June 02, 2015, 06:28:56 PM
So ignoring all the specialality shape(round, half round etc) lets consider a flat file:
Hand or flat files have two identical faces, the edges may be safe, square, or rounded.
My Grandad told me to put a blob of yellow paint on one of the faces. This face is ONLY used for brass or bronze. Other side is used for ferrous materials.
This can also be applied to other shapes within reason.
Also (as mentioned above) use chalk to stop "pinning", file card does what it says on the tin (or card)
I have also heard about chrome plating files to increase cut-ability and wear resistance!
Post by: vtsteam on June 02, 2015, 10:12:44 PM
Rob, I sure would dig watching you put that machine together, as would a whole lot of other people I bet! :drool:
I figured that forge and tools had some long term purpose, not just making coathooks, nor twisty garden gates!  :lol:
Of course, I know you still want to snort some coke up yer cupola in the near future, too, else why all those molding tools!  :lol: I'm expecting a lot of hot iron in your vicinity.  :thumbup: :clap:
re. files -- no sandblaster here, and breaking the wire edge is a new tool problem, methinks. I think Jonny's telling the real story, and don't hold out much hope for an acid or rust re-sharpening trick. But it's always fun to do something new with tools and who knows, I might get lucky.
I might just try getting the thinnest possible resist on the cutting tips before an acid dip -- outta my usual curiosity :scratch:
Will, yellow paint on one file, but on both sides, and another unpainted for for ferrous would be better -- like I said, and Jonny too, files don't have identical sides because of the slight curve -- one side convex, one concave. At least most of my big ones don't. I use both sides at different times, and often alternate between them. Small files may be okay painted one side, and particularly if used for shaping instead of flattening.  :beer:
Arbalist -- looks like they are intent on producing high quality specialty stuff. Good to see.  :beer:
Post by: RobWilson on June 03, 2015, 05:15:08 PM
It sure would be a canny project Steve ,,,,bollocks to garden gates   :palm:    ,,,,,,,,,,,, I would need to nip back to Paris (not a bad thing lol) to take a few more photos  ,unless I have a drawing of it already .
And it would give me a lot of forging practice  :dremel: , so much   :proj:     , aye the old cupola needs to be  finishing,  I have a good 200 kgs of coke ready for the beast ,,,,,,,,,,,,,, I bet its easier for you to score some Columbian marching powder than get    some crispy black rock Steve ,,,,,,,,probably cheaper  :lol: :lol:
Post by: vtsteam on June 03, 2015, 09:19:58 PM
Already have a drawing of that file machine? Holy cow that would be a heck of a drawing! But I bet you'll be the first to draw it,
Hey if you do go back to take photos, also take a movie as you walk around, and zoom in and out a lot. I've found that really helpful in measuring and drawing things, besides the stills. Most movie player software can turn any frame into a jpeg, too. Though with less detail than a true photo. But you often get angles you forgot to photograph from, and you can see the 3D-ness (not a real word, I know) of pieces, and connections.
I think you have fancy CAD software and it probably does the same, but one feature of Sketchup I like is the ability to import a photo, scale it, and measure or trace over it, then hide it. I do that a lot.
Rob, did they harden the steel after they cut the file -- hard to imagine otherwise, but then how did they avoid burning the tips of the tiny teeth, and prevent scale? They must have had some highly experienced heat treatment guys on files, and probably some special tricks.
I have used soap to reduce scale when hardening -- I wonder if there are other tricks they used?
I'll take the black variety of cupola food, but you're right, probably no cheaper and harder to find!  :lol: :lol:
Still thinking on anthracite with some kind of heated blast -- that's the hard part.
Post by: S. Heslop on June 04, 2015, 06:14:49 AM
From a video I watched they heat treated rasps in a salt bath. Sharpened them with a sandblast after that.
I need some rasps and i've been considering trying to make them myself. It seems fairly staight-forwards aside from heat treating and sharpening. I need a sand blast cabinet in the near future and it's a good excuse to set one up.
Post by: Arbalist on June 04, 2015, 06:28:40 AM
You might find the video on this page interesting then.
http://www.hand-stitched-rasp-riffler.com
Post by: S. Heslop on June 04, 2015, 08:09:20 AM
"It takes 2 years to learn how to hand stitch." Yeah sure looks like a hell of a skill, whacking a chisel.
Post by: vtsteam on June 04, 2015, 08:24:39 AM
But did they do that in the period of the file machine Rob is interested in? From the looks of it I'm guessing nineteenth century. Or earlier? That's what I was curious about.
Post by: Arbalist on June 04, 2015, 08:50:26 AM
This French one is C 1700 apparently.
(http://www.maritima-et-mechanika.org/tools/catalogues/130424-72.jpg)
Post by: vtsteam on June 04, 2015, 09:57:50 AM
Wow, Arbalist, And it looks modern in comparison!
The first is an amzing example of blacksmith art. This one of engineering, at such an early period.
If someone turns up a sand blaster for files from the 1700s, then that would answer my question of how they heat treated and preserved sharpness. Just showing a big set of bellows isn't fair...was that actually how they did it? Or was there another way used..... :whip:
ps. I bet a lot of the above file making machine was shaped with files!
Post by: Arbalist on June 04, 2015, 10:30:17 AM
Perhaps it was, I wonder when the milling machine was invented?
Post by: vtsteam on June 04, 2015, 10:43:22 AM
I was wondering what that onion shaped ball at the left end of the leadscrew was. I now think it is a decorative captsan to take removable tommy bars, and it tightens the pointed pivot that serves as a bearing for the leadscrew. Most of the bearings thoughout the machine seem to be pointed pivots, with a locking lever screw (often brass and with curved hande).
I love the big thumbscrews and wingnut. A hundred times handier than the cheap stampings available today. And better looking, too.  :thumbup: :bow:
Post by: Arbalist on June 04, 2015, 11:47:41 AM
I'd love to see it in operation, if only on some soft steel.
Post by: RobWilson on June 04, 2015, 01:33:12 PM
Where did you fined that photos ?  dont think that machine is from the  1700 ,could be mistaken
Post by: RobWilson on June 04, 2015, 01:49:55 PM
Steve , the photo of the machine I have shown is from 1700 - 1800  is the best I can get from the museum site , it was added to their collection in 1849 .
Materials : Steel , Wood and Iron  ,,,,,,,,,,, weight 58Kg .
Looking through a Leonardo da Vinci book I have there is a drawing of a file cutting machine he designed in 1480 ,,,,
(http://i1066.photobucket.com/albums/u410/RobWilson100/P1080955_zpsgdirrhfg.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/P1080955_zpsgdirrhfg.jpg.html)
,,,,, and now  I remember seeing the actual LdV drawing in Venice a few years back .
I can see what I can find about the ye oldie file making process  :coffee:
Post by: vtsteam on June 04, 2015, 02:20:32 PM
Wow, Rob, that's going back some!
Leonardo was at times more of an armchair engineer than a buider, amazing though he was in all of his accomplishments.
That looks to be at leaast a 4 foot long file, by the scale of the other parts, The base weighed tons if stone, and I doubt it was solid wood, the rest is pretty rickety looking,
The weight, which acts like those on a clock to turn the spindle, looks way too small for lifting the hammer on the long lever arm it has, compared to the very small spindle -- I'm not sure he's got a good grasp of mechanical advantage here! Those sawhorse-like legs better be bolted down or the whole near end will lift up. That leadscrew is pretty massive for even a 4 foot long file -- a bit overbuilt compared to his stocks.
I'm thinking he'll probably need a plan B after trials  :lol: :lol: :lol: :lol: :lol: :lol:
(don'we all!  :lol:)
Post by: Arbalist on June 04, 2015, 04:51:10 PM
Well I didn't make it up Rob, it's on this page and it says "File cutting machine Pierre Fardoil, c. 1700"  :beer:
http://www.maritima-et-mechanika.org/tools/toolsmain.html
Post by: Will_D on June 04, 2015, 05:02:26 PM
...  then that would answer my question of how they heat treated and preserved sharpness.
Somewhere in the back of the grey mush that is my brain:
I seem to recall coating fine details with a ceramic protective paste. Used in gunsmithing to protect sharp pointy bits and for files "all the sharp pointy bits that are the teeth"
The coating protects the sharp ends from oxidative errosion.
This was the way it was before salt baths were invented.
Post by: vtsteam on June 04, 2015, 05:11:28 PM
Arbalist, what a fantastic site and machines!  :thumbup: :thumbup: :thumbup: :clap: :beer:
Post by: Arbalist on June 04, 2015, 06:48:00 PM
Yes, there's some really interesting stuff on there.
Post by: Anzaniste on June 07, 2015, 02:43:08 AM
It's that the Musee des Arts et Metiers by any chance? My favourite museum👍
Post by: RobWilson on June 08, 2015, 01:12:10 PM
It sure is the   Musee des Arts et Metiers  Anzaniste   :thumbup: ,,,,,,,,,,, a cracking place to visit , joint third  on my top five of industrial /technology museum's .
Good question and hard to say , it looks like it was invented around the early to mid 1700s  by a French man working in the clock making industry . Rees's Manufacturing industry 1819 -20 makes no mention of the milling machine(rotary filing machine)  ,and there is also no mention of the milling machine in my 1833 copy of Manufactures in Metal  , so it looks like it was still in it infancy as a machine tool at that time  as lathes ,boring and other machinery are well documented .Although the milling machine was being developed by several engineers on two continents at around the same time .
The first  milling machine manufactured for sale was produced in the USA , designed by a Mr Frederick Webster Howe in 1848 for the Robbins and Lawrence Company ,Windsor,Vermont .
(http://i1066.photobucket.com/albums/u410/RobWilson100/P1080961_zpsthcokbef.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/P1080961_zpsthcokbef.jpg.html)
Joe if you reading this it is probably  down to Mr Frederick Webster Howe that you have weird threads on your rifle parts    :palm:   (still looking )  :coffee:
Post by: vtsteam on June 08, 2015, 01:32:37 PM
Windsor, Vermont is close by here. It's where the Precision Museum is. A very small town,  It looks like that mill had travel in only one direction. So I guess you had to reset the work on the carriage to cut a wider cut than the milling cutter. :coffee:
Post by: RobWilson on June 08, 2015, 01:42:24 PM
Hi Steve
It looks like there is some side to side adjustment looking at the long gear on the feed shaft .The back gearing would need resting after a Z adjustment.
 Aye I new it was close to you  :thumbup: its been interesting looking into the history of the mill .
Still looking at files  :)
Post by: vtsteam on June 08, 2015, 02:13:02 PM
Rob, I was wondering about that gear -- but couldn't see any ways for the carriage to slide on. But maybe it had a short set that are hidden by the slide.
Funny I just never expect to see anything about Vermont in engineering history, because that's all mostly gone now, and it seems a very rural state. Not like Connecticut or Massachusetts. I have to send away for everything. So it's a big surprise to see it even mentioned at all like that. Fun though!!
I found a little hobbyist lathe mentioned on Tony's lathe site that was also built nearbyin Wilmington,apparently: the Guilder:
http://www.lathes.co.uk/guilder/
It's kind of a cool little does-it-all mchine and accessories. Apparently originating in a little town very nearby. I had no idea Wilmington did anything except serve as a destination for skiers.
Post by: vtsteam on June 08, 2015, 02:26:18 PM
The files arrived. Thought you all might enjoy seing the packaging job it took to send two 14" files a small tube of bue for scraping, a small bottle of loctite, and some JBWeld, all located in the bottom of the picture!
Three boxes, four sets of expanded foam in bags, 5 foot long string of air filled pouches, bubble wrap, and more! The tube of Dykem blue arrived in its own box with 2 foam packs, It's about the size of your thumb.
The files? They stuck the two of them loose in one plastic bag, so they could rattle around against eachother the whole trip!  :lol: :lol: :lol:
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/FilesNStuff.jpg)
Post by: RobWilson on June 08, 2015, 02:27:07 PM
Hi Steve
There  are a few words about Vermont and machine tool making in " A history of technology vol 4 1750 -1850 "  , milling machine and the invention of the modern turret lathe all hail from your neck of the woods .   :bow:
I dont think its the best /most accurate of drawing of the milling machine , this is a more modern version by a few years ,front view , from Modern machine shop practices 1880 Rose Joshua , another yank that's worth a google  , bloody heavy book  :palm:
(http://i1066.photobucket.com/albums/u410/RobWilson100/P1080963_zpse8vyxzjh.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/P1080963_zpse8vyxzjh.jpg.html)
Nice wee lathe , would be nice if you could fined one  :dremel:
Post by: RobWilson on June 08, 2015, 02:39:56 PM
 :lol: :lol: :lol: thats a fair bit of packaging Steve  :lol: :lol:
Hows the files ?
Post by: vtsteam on June 08, 2015, 02:48:28 PM
Oh I see how they did it, Rob. I wonder what call they had for creating the turret lathe here? What were they making so much of that they needed something like that. I do recall seeing a demonstration at the Precision Museum of a part being made with one, now that you mention it. Must have been near ten years ago. I'll have to go back there and pay closer attention!
I love that little lathe. I was musing at one point of building one as a replica because it was made here and is so rare -- the photos are pretty good, and I think I could do it from them. Probably start that about when you start your file making machine....... :dremel:
Well better finish this lathe I'm on first! :whip:
Post by: RobWilson on June 08, 2015, 03:04:08 PM
Guns Steve ,,,,,,,,the production of guns I do believe is what the turret lathe  was used for . One day I WILL get over for a look see myself , also I fancy  a look at the Saugus Iron Works .
(http://i1066.photobucket.com/albums/u410/RobWilson100/P1080964_zps0tds00dr.jpg) (http://s1066.photobucket.com/user/RobWilson100/media/P1080964_zps0tds00dr.jpg.html)
Just had a better look at the lathe page and their is an impressive amount of attachments for it  :dremel:  , yerh it would make a cracking project .
Post by: vtsteam on June 08, 2015, 03:16:59 PM
Hows the files ?
Just as Jonny said. Not as good as they once were. Here's my old(?) -ca. 2001-  Nicholson double cut 14" flat bastard next to one of the new ones. The older one is 5/16" thick, the newer ones, 1/4".
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/file1.jpg)
Then they narrowed the profile about 1/8" toward the end to save a little more metal.
And they decided not to really double cut the file like the old one, but just lightly score a single cut file and call it a double cut, as you can see here. Who really needs two cuts after all?  :loco:
And by not cutting all the way to the end, they could save a little time, too.  :thumbup:
(I've had call to use the very tip of a file on special occasions, now it's not possible)
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/file2.jpg)
Ah, maximizing profits and product downsizing. ... all in all, things have changed since the good 'ol days-- even since 2001!  :lol:
Post by: philf on June 08, 2015, 04:02:59 PM
Steve,
Have a look at
He does the first cut and then files the tops off before doing the second cut.
I'm guessing that's so the file creates small filings - a bit like a roughing mill with staggered teeth.
Post by: awemawson on June 08, 2015, 05:05:51 PM
Steve, that quasi double cut file needs returning to the seller - it's not good enough - don't accept it.
Post by: vtsteam on June 08, 2015, 09:54:11 PM
Thanks Phil that was a great video :thumbup: I enjoyed seeing it. Quite a lot larger hammer than I imagined being used. It makes me want to try making a file by hand some day.
I think the files I bought haven't been reduced in one direction to improve the file. The older file from the same maker shows even cross cuts. I don't know why these newer ones are different.
Andrew, I've already used both files, trying them out before I took photos for here, and noticed the difference in cut. Guess I should have looked closely before with glasses on. They did cut okay, and I can use them. But just not what I thought would be exact replacements for my other one.
I'm thinking of writing to Nicholson, about these, and see what they have to say.  :beer:
Post by: awemawson on June 09, 2015, 02:31:38 AM
Steve it has to be a manufacturing defect, and more to the point an inspection defect, if there was any. Used or not send them back if only for the sake of the next buyer. When we accept poor standards they have a tendency to become the norm.
Post by: Arbalist on June 09, 2015, 05:00:25 AM
I'm with Andrew, they don't look very well made at all. I've seen a better cut on cheap files.
Post by: vtsteam on June 09, 2015, 10:27:24 AM
I've written a letter to Nicholson, who are part of Apex tool group, since they can explain whether this is a manufacturing defect or is due to some other cause/reason. I'm kind of curious now about these files. I'd like to hear what the manufacturer has to say. Could they be seconds? Or even counterfeit? Is it a new production quality? Or a true accidental manufacturing defect? The seller won't know, but the manufacturer will.
Post by: vtsteam on June 09, 2015, 10:51:33 AM
A bit more investigation with camera (glasses would have helped earlier)......made in Mexico:
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/FileLogos.jpg)
Post by: vtsteam on June 09, 2015, 10:56:36 AM
And an even closer look, thanks to modern digital cameras and software programs to enlarge details:
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/Nichulsun.jpg)
Genuine Nichulsuns !   :lol: :lol: :lol: :lol: :lol:
Busted!  :wack:
Post by: Arbalist on June 09, 2015, 10:57:56 AM
I believe I've seen Bahco (Sweden) files with "made in Brazil" on them before.
Post by: vtsteam on June 09, 2015, 11:29:13 AM
Were they spelled BahcU?   :)
The files I have are counterfeit. The misspelling is intentional. The U's are shaped to look like O's that have not been fully imprinted. However the ends of the letters are crisply imprinted, not short strikes. So the U was intentional.
A deceptive technicality, as the seller Zoro tools sold them as genuine Nicholson (spelled with O's), and listed the genuine Nicholson part number in its ad.
Post by: Lew_Merrick_PE on June 09, 2015, 11:50:32 AM
Topic Drift Alert!
You do realize, do you not, that this is exactly what the World Trade Organization (WTO) has been working towards for three decades now?  The Atlantic and Pacific Trade Treaties will make it illegal for any country to reduce profits or enforce standards that reduce profits of the key international trading companies.  This whole thing began with the Reagan Administration's Maquilladora Treaty set and has been carefully evolved over the intervening years!
Here in the U.S. intellectual property rights are dependent upon a person's (or company's) net wealth!  If you do not make the net wealth cut-off, the $40,000+ you just spent on a patent, copyright, or trademark gives you a nice piece of paper to hang on your wall, but no legal right to defend it!  [Say, Thank you very much. to Sen. Orrin Hatch -- 1995.]
As Pete Seeger sang so well, When will we ever learn?
Post by: vtsteam on June 09, 2015, 11:57:46 AM
Lew I'm not intersted in the political debate here. I am interested in getting to the bottom of this particular sale and advertising issue, and preventing recurrence under normal counterfeit rules.
I just spoke with a representative of Zoro Tools who sold the product. She asked for a part number, and when I gave it to her told me "we received it direct from the manufacturer," which she said was "Cooper Tools".
I disagreed and then I asked her to account for the difference in spelling between Nichulsun and Nicholson in the actual files vs the Zoro Tools Advertisement on Ebay. She kept insisting these were received direct from "the manufacturer." When I asked which manufacturer again, she then said that Zoro Tools was a Subsidiary of Grainger, and that the files had actually come from Grainger, who got them "direct from the manufacturer."
She then suggested that her team look at the files and try to determine what the issue was. I gave her my name and number and asked for a call back.
Post by: Jonny on June 09, 2015, 12:01:01 PM
There were some good files stamped Brasil, it surprised me.
Its no defect its purely cost cutting.
Vallorbe look the same as they did 12 years ago, just don't last as long.
See anything old with Stubbs on, grab it.
Post by: vtsteam on June 09, 2015, 12:05:54 PM
I have no issue with parts made in other countries than this one, and agree that they certainly can be of highest quality. The issue here is a defective tool, possible advertising deception and counterfeit.
It would have been smarter of Zoro/Grainger to have taken the information seriously, and offered an immediate refund, and pulled the ads. Instead I was wished a nice day.
Post by: awemawson on June 09, 2015, 12:14:33 PM
Simple - report back / file a dispute, with paypal who will automatically refund you on counterfeit goods.
However if you look on the Nicholson site they do use horseshoes  in some of their emblems, so check first with them that they are 'true' counterfeits !
Post by: vtsteam on June 09, 2015, 12:19:45 PM
I do want to hear from the manufacturer first, Andrew.
I have never heard of a manufacturer purposely misspelling their name. That would defeat the whole purpose of a trademark.
Post by: vtsteam on June 09, 2015, 12:30:29 PM
Andrew do you mean that the U's are supposed to be read as horseshoe shaped O's? If true, then these could be genuine I suppose.
Post by: RobWilson on June 09, 2015, 12:44:52 PM
Looks and smells like a knock off to me Steve ,,,,,,,,,,,,, thats is a really BAD strike for a Nicholson tool , no matter were it was manufactured .
The horse shoe theory ,yes may be of their  farrier's  range of rasps ,,,,,,,,,,,,,,but on an engineers/mechanics file  :coffee:
Post by: vtsteam on June 09, 2015, 12:57:02 PM
Well Rob, sometimes graphic designers can make logos very strange, so I may be eating crow shortly!
Here's what I compared it to on my original file. Notice the O is a closed O.
(http://i786.photobucket.com/albums/yy150/vtsr/vtsr/Shop/olderfilelogo.jpg)
Post by: S. Heslop on June 09, 2015, 01:00:31 PM
Here's something vaguely interesting. Was grinding the teeth off these files and noticed one was a Nicholson. Then there's a cheap Sunderland knockoff impostor.
(http://iforce.co.nz/i/btop53iv.itb.jpg)
(http://iforce.co.nz/i/ns0055f1.k2h.jpg)
This Nicholson doesn't have teeth all the way to the top.
Post by: awemawson on June 09, 2015, 01:08:46 PM
Yes that was my thought, but perhaps it's someone's  joke, the horseshoes being an oblique reference to the transport of the cowboy who made them  :lol:
Post by: RobWilson on June 09, 2015, 01:14:29 PM
Hi Steve I did notice the closed 'O'  ,  the strike on your new files was done in two parts by the look of it , the Nichulsun  one , and the Mexico and the two crossed  hot-dogs the other .
Hi Simon ,,,,,,,,,,, that not a cheep knock off file  :poke:
Post by: vtsteam on June 09, 2015, 01:24:50 PM
I see Simon's files have a closed O also.
Who knows? I'm starting to get tired of trying to figure it out.  :bang:
One thing is certain -- these aren't the Nicholson files I expected. Poorly cut, thinner, spelled wrong (or stylishly -- take your pick) they're a disappointment.
Post by: vtsteam on June 09, 2015, 01:42:52 PM
Crossed hot dogs!!  :lol: :lol: :lol: :lol: :lol: :lol:
Post by: S. Heslop on June 09, 2015, 01:44:27 PM
Just poking fun at Sunderland~
It looks like it would've been a mighty file back when it was new. But by the time I got it it looked like someone was using it to file concrete, and as a pry par since the top was snapped off. I'm hoping i'll be able to do a decent job turning it into a rasp, because I like the logo and the thought that they used to make files in this area. It's easy to forget the North East used to be an industrial powerhouse.
Post by: Manxmodder on June 09, 2015, 03:13:31 PM
Bloody cheapskate counterfeit crooks!!  They boil my blood,I tell you  :wack:  :bang:
I think the deception may go further than the rearranged 'Nicholson' design logo. I'm wondering whereabouts in China is there a place called Mexico.
I'd be holding nothing back when expressing my dissatisfaction to the supplier,Steve.
......OZ.
Post by: vtsteam on June 09, 2015, 03:16:55 PM
Oz there's a Mexico, Maine, too!  :lol:
But we just have to find out what the heck this is: genuine quality reduction, or fake quality reduction.....
Post by: tom osselton on June 09, 2015, 05:15:54 PM
What you have there is a double cut Chiwaawaa!
Post by: rowbare on June 10, 2015, 04:01:21 PM
That part isn't a defect or cheaping out, they are two different styles of files (mill vs lathe perhaps?). I recently helped a friend sort out a couple of tons of NOS Stubs files at his shop and some are cut to the end, others not. While we North Americans aren't all that familiar with the Stubs brand, our friends across the pond know them well.
bob
Post by: vtsteam on June 10, 2015, 04:39:55 PM
No, they are both Nicholson 14" double cut flat bastard files.
Post by: Jonny on June 10, 2015, 04:41:52 PM
Not an imposter its a totally different NE company set up well over 115 years ago up Tyne and Wear.
Post by: vtsteam on June 11, 2015, 09:03:10 AM
Yes, those files aren't the subject here.
