The Shop => Tools => Topic started by: catceefer on January 19, 2015, 03:24:36 AM
Title: Compressed Air Propane Torches
Post by: catceefer on January 19, 2015, 03:24:36 AM
I am building a large copper dragon and up until now, I have managed with propane gas powering a MAPP torch. However, as the bulk is increasing, I need a more powerful torch to get the heat into the metal. Due to the size and shape of the work, it is not practical to surround it with fire bricks or the like.
I have read odd bits, here and there, about compresed air assisted toches and was wondering whether anyone has any experience of either using them, building one or converting a standard one to work in this way. Due to cost and space, I would rather avoid going down the bottled oxygen route and the cost of MAPP gas itself makes it prohibitive for the size of job. In addition to the MAPP torch, I have a Clarke torch: the cheap sort that are sold under various brands and come with three nozzles and an air compressor.
Any advice would be appreciated.
Thank you.
James.
Title: Re: Compressed Air Propane Torches
Post by: chipenter on January 19, 2015, 03:39:03 AM
Have a look for foundry sites for burners and ideas http://www.backyardmetalcasting.com/ .
Post by: hermetic on January 19, 2015, 07:59:25 AM
There is a type of torch used on brazing hearths which use compressed air/propane. Mine has a small rotary compressor under the brazing hearth. I also have another torch from a brazing hearth which I use portable with a gas bottle and an airline from my main compressor (nicknamed the blowlamp of doom!) you can braze quite easily with this, but your main problem will be as the dragon grows, the copper will conduct the heat away faster. Use a glassfibre or ceramic blanket to keep the heat in, and you shouldnt have a problem. if you do a google image search on "brazing hearth" you will see all types of air/propane set up. If you are soldering beware, as the blanket may keep enough heat in the job to melt completed joints.............not desirable!
Post by: vtsteam on January 19, 2015, 09:01:14 AM
catceefer I'd be very interested in what you find as well for a compressed air/propane brazing torch.
I did a thread here on an atmospheric torch but it required a hearth of sorts to contain enough heat for brazing. I'm sure you're already aware of Backyard metalcasting, as I am, but I haven't seen any specific information on constructing a torch that operates without a hearth, in free air, that concentrates heat to the degree required to braze locally on a large object.
There was a thread here on using an old oxy-acet torch, I believe, with compressed air and propane, but I don't recall seeing if it was attempted with brazing rod.
The big question is can the heat be focused adequately, not whether there is enough temperature in an air/propane flame, as some have claimed.
I think it probably can be done -- but that would be the design effort -- compacting the flame.
Post by: catceefer on January 20, 2015, 02:31:40 AM
Thank you for the replies. I shall have a look at the variouslinks and, if I succeed in making anything useful, I shall update this topic.
Regards,
James.
Post by: DMIOM on January 20, 2015, 03:23:15 AM
James,
If you're able, I think we'd be grateful if you could advise any results, both what works and what didn't, as it helps our collective learning, especially if you can say why it didn't work.
Post by: catceefer on January 21, 2015, 02:47:18 AM
Dave,
Certanly: once I get to experiment, I shall update this with my efforts, good ro therwise.
Regards,
James.
Post by: vtsteam on January 21, 2015, 09:12:18 AM
The Bullfinch Autotorch seems to be able to bronze braze even as an atmospheric burner
http://bullfinch-gas.co.uk/blowtorches/autotorch-brazing-sys
Unfortunately, I don't see that one available in the US. I'd love to get one of the burners to try out.
For compressed air/propane brazing there is also the Flamefast T4 torch -- also a UK product (you guys are brazing torch rich!)
http://flamefast.co.uk/heat-treatment-equipment/t2-t4-gas-torches/
Post by: vtsteam on January 21, 2015, 09:29:00 AM
Remarkable find,,,,,,Bullfinch actually has a video of their torch burner made of glass. There's an internal bullet shaped mixer. Acts as a convergent divergent nozzle I think:
Post by: Jasonb on January 21, 2015, 10:14:19 AM
The "Flamefast" brazing hearths come up for sale quite regularly and have a torch with them. They may need rejetting for bottled propane if they were being used on mains gas. Use to have a couple in the workshop at school and they certainly put out plenty of heat.
Post by: mcostello on January 21, 2015, 11:52:47 AM
Majorly cool picture.
Post by: catceefer on January 21, 2015, 03:07:41 PM
"For compressed air/propane brazing there is also the Flamefast T4 torch -- also a UK product (you guys are brazing torch rich!)"
I have just contacted the makers of this torch. They recommended a different model, but at £324.00 +VAT, I regret that it is out of my price range. I shall keep an eye out for a second furnace or similar, as suggested, or try making something.
Regards,
James.
Post by: vtsteam on January 21, 2015, 03:28:36 PM
I'll take a shot at doing the convergent-divergent nozzle in my atmospheric torch when I finish this pipe and bolt engine. It's got me curious.  :beer:
Post by: vtsteam on January 21, 2015, 05:15:33 PM
Also catceefer, it looks like the Bullfinch torches are much less expensive, though they are atmospheric, instead of compressed air.
Post by: vtsteam on January 21, 2015, 10:16:56 PM
Let's not forget Ironman's compressed air-propane torch conversion, also:
Post by: catceefer on January 22, 2015, 03:27:30 AM
Vtsteam,
Thank you for the video. That is the thing that first set me off thinking about the conversion in the first place. I seemed to recall seeing something, somewhere, a while back when looking into different types of torches, but could not find it again. It looks just what I want and I can even get hold of an old oxy-acetylene torch with which to experiment.
I shall look at it in detail this evening.
Regards,
James.
Post by: Will_D on January 22, 2015, 05:55:10 AM
Just make sure to fit flash-back arresters/non return valves to both lines! You dont want air in your propane or propane in your compressor!
Post by: vtsteam on January 22, 2015, 02:13:19 PM
That's true, Will. And true of oxy-acet, oxy-prop, too. Unless flashback arrestors are built into the torch itself.
I have them at the regulators and the torch.
I found Ironman's full thread on his propane torch:
http://madmodder.net/index.php/topic,9208
Post by: vtsteam on January 22, 2015, 02:26:11 PM
In the video, Ironman shows an early trial with just a conventional oxy-acet welding tip, and the flame blows out. This actually also happens with oxy-propane, not just propane and compressed air.
Oxy-propane tips have a recessed orifice. they need what I would call a flame holder beyond the orifice. I was successful in modifying a #2 Victor oxy-acet weldng tip to burn oxy-propane by adding a counterssunk end in the tip. That's what I use for small parts brazing now -- I used it extensively on the Pipe and Bolt engine.
So I'm wondering if Ironman might have had better luck if he had countersunk the welding tip. By adding the larger shroud he got the same effect, I think.  But it's a large flame. I might be interested in a smaller flame than that, and I do wonder if my modified oxy-propane tip might stay lit with compressed air, instead of blowing out, as ironman's did in the video.
Post by: Manxmodder on January 22, 2015, 03:16:52 PM
Well this is developing into a very interesting and potentially fruitful thread indeed.
I say this because amongst the recent haul of machinery and equipment acquired by a mate and myself there are several oxy-acetylene torches of various sizes,and an oxy-propane cutting torch.
The likelihood of either of us investing large sums in oxy or acetylene cylinders is next to nil . We both use propane torches and have large cylinders of that gas,so if this thread enables us to modify the oxy-acetylene kit to propane-compressed air for brazing,then it's going to be smiles all round......OZ.
Post by: catceefer on January 22, 2015, 03:55:43 PM
I did have a go at doing this last year, but without any success, but I can see why now. I borrowed an old oxy-acetylene torch and tried it with propane and compressed air, but unsuccessfully. Either the flame went out with the air turned on or was it large, flaring and cold orange with just the gas. I did try enlarging the jet, but to no avail. I did not try shrouds of any sort or countersinking the jet.
I shall be getting the torch back again shortly, so shall have another go, this time with a bit more structure to my efforts. I need a large, hot flame, not just a hot one. The atmospheric torch that I normally use brazes perfectly well, as long as the piece is small enough. The dragon in the attached picture is at the limit of current rig.
Regards,
James.
Post by: Manxmodder on January 22, 2015, 04:56:56 PM
WOW! I like your Dragon very much,James. :clap: :clap:.....OZ.
Post by: vtsteam on January 22, 2015, 06:01:51 PM
Hey, Cool catceefer!! :thumbup: :beer:
Post by: dsquire on January 22, 2015, 06:41:28 PM
James
Now you are geting our attention. I can see a lot of back yard treasures turning into front yard art pieces. Well done.  :D  :D
Post by: catceefer on May 04, 2015, 12:55:33 PM
Just a quick update: I have obtained an oxy-acetylene torch, bought a length of fat tube, found and drilled some scrap steel and cobbled together a large burner. On just propane, it puts out a large amount of heat, but with a scarily diffuse, large and unusable flame. I now need to try and hook up the oxygen pipe to the compressor and try again.
UPDATE TO UPDATE. Just hooked the torch up to the compressor and tried again: success! It has a nice, bright blue flame, totally controllable and, if the roar is anything to go by, very powerful. I need to tidy the burner up a bit, mainly because the jet is in at a slight angle and the flame is not central to the shroud, but otherwise, it is ready.
Once it is finalised, I shall post some pictures and, if possible a video of it in use.
Regards,
James.
Post by: catceefer on May 08, 2015, 04:13:21 PM
For anyone interested, here is a picture and video of my compressed air - propane torch. I followed the dimensions given by "Ironman", although the jet is not set as far back in the throat. I need to sort out some new hoses and a connector to the compressor as it leaks badly, but I am really pleased with the overall result.
Thank you for the help.
Regards,
James.
Post by: vtsteam on May 08, 2015, 04:42:18 PM
James, seems the video is private.....?
Were you able to braze with it?
Post by: catceefer on May 09, 2015, 04:03:19 AM
The video should be public now. I have not tried brazing with it yet, mainly because the airline leaks too much to keep running for more a minute of so, but I shall try over the weekend and update this post.
James.
UPDATE
I have now. tried the torch out in practice and it brazes well. I tested it on the head of the dragon, on which my other torches only just work after a very long time heating. This new one achieves a better result within a very short period. The flame is a bit wild and I will play to see whether I can make it more focused. I may bend a sleeve up to go over the tube so that I can slide it up and down and vary the effective length.
Regards,
James.
Post by: Orange Alpine on August 11, 2015, 07:21:00 PM
I tried using a standard propane torch burner.  Covered the air holes with tape and taped it onto the torch handle for a quick and dirty test.  It gives a very nice controllable and hot flame.  Not finicky at all.
As a test, I heated a slug of steel, 7/8" diameter, 1" long with a 3/8" hole running lengthwise.  Using about 10 psi of propane and air, it rather quickly uniformally heated to a (almost) bright red.  Appears to be on a par with the Bullfinch torch.
I also tried using a rosebud burner.  Not as "nice", probably due to design differences, but considerably hotter.
It worked well enough that I'm going to make a proper adaptor and use them as my everyday source of intense heat.
Post by: Orange Alpine on August 11, 2015, 07:28:49 PM
Forgot to mention that I removed the orifice from the burners.
Post by: vtsteam on August 11, 2015, 10:50:38 PM
Not quite sure what you're describing, Orange, any pics?
Post by: Orange Alpine on August 12, 2015, 09:56:55 PM
Yes, I have pics, but for some reason the 'puter is not recognizing the camera card.
The burners/nozzles are old Turner propane torch items.  The kind that screwed onto a short, bent tube that screwed into the valve body.  I have found that the more  modern nozzles that are integrated into the tube will not work at all.   At least the Craftsman I have will not.  Also, it seems the nozzles work best when taped directly to the acetylene torch handpiece.  I bored a #5 welding tip out to .111" and screwed the nozzles onto it.  It worked and I took some pics (that I can't get out of the camers), but I'd swear the results were inferior.  More finicky and could not be pushed as hard.  More testing is in order.
Here is a link to an image of the type of propane torch I used.
(http://thumbs3.ebaystatic.com/d/l225/m/mCp-YkMQHu8QmW_nXI8yZXw.jpg)
(reduced image link size and embedded..vts)
Post by: SwarfnStuff on August 13, 2015, 02:02:24 AM
WOW,  :bugeye: that would have to be the longest link I've ever seen. It worked though and good to see what you used.
Post by: Orange Alpine on August 13, 2015, 12:04:00 PM
Found a card reader that works!
Here is the torch in it's native habitat:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1233_zpskkrlito1.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1233_zpskkrlito1.jpg.html)
Nozzle modified and ready to go:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1239_zpspmdyqijz.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1239_zpspmdyqijz.jpg.html)
Going at full tilt:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1245_zpsgvkmhdpo.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1245_zpsgvkmhdpo.jpg.html)
Another nozzle, slightly different design, same size.  This one seems to work the best:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1247_zpsm0si8vd0.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1247_zpsm0si8vd0.jpg.html)
Rosebud:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1243_zps0xwjnxht.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1243_zps0xwjnxht.jpg.html)
New design Craftsman integrated burner.  A real lose for this application:
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1248_zpsglhzlfqt.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1248_zpsglhzlfqt.jpg.html)
Did some more testing.  Connected the nozzle to the Turner pipe, then taped to the torch handle.  This gives .190" delivery pipe intead of the .111" of the welding tip.  Then taped the nozzle directly to the acetylene torch and handle.  I am convinced the direct connection gave a hotter, more controllable torch.  I think it is due to slower gas velocity.  Taping directly to the torch handle produces a small chamber, causing the gas velocity to drop, allowing more  mix to get into the burner without blowing out the flame.  But maybe not.
Post by: Orange Alpine on August 13, 2015, 09:58:36 PM
I think this is going to be my final effort.  It is the nozzle that performed best, mounted on a #5 welding tip.  The nut is a 5/16" tubing flare nut soldered on the tip.  It had to be drilled out about .040" to fit the tip.  The 5/16" flare fittings are 1/2" - 20, so I turned and threaded the Turner nozzle to match.  It all worked out good. I will probably modify the rosebud nozzle so I'll have a "big" and "little" source of heat.
The nozzle is being pushed to its limit in this photo.
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1249_zps8ykjdhnq.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1249_zps8ykjdhnq.jpg.html)
Post by: vtsteam on August 14, 2015, 10:36:37 AM
Bill, thanks for the photos. Still trying to figure out what you have. Please correct if I'm wrong anywhere here:
1.) You are using a welding torch body, and using compressed air and propane (what regulator pressures?) into that body.
2.) You are using a #5 welding tip (what brand type) to which you soldered a 5/16" long brass flare nut (drilled .040").
3.) You used a jet orifice from a Turner atmospheric propane torch, and bored (turned?) that and threaded to fit the flare threads.
4.) You taped over the atmospheric air orifices in the original torch flare.
You have something called a rosebud -- not sure if that's a different torch flare and orifice, or an actual welding rosebud for the torch body?
ps. Bill, I hope you're using torch body and tank flashback arrestors if you're experimenting like this. Too slow a flame speed along the chain of various parts can produce ignition there and or flashback. Not trying to discourage you, just makng sure you're playing it safe. Also tape isn't a good idea.
Post by: Orange Alpine on August 14, 2015, 09:23:39 PM
vtsteam
1.  Correct.  Pressures do not seem to be critical.  Currently using 8psi propane and about 20 psi air.
2.  The wleding tip size is immaterial.  I gave the tip # in an attempt to further identify the set up.  The tip has been cutoff and the thing is used as a method to connect the Turner nozzle to the acetylene torch.  The 5/16" flare nut was drilled oversize about .040".  From .320" to 359" to fit over the welding tip.  Also about 1/8" was removed from the threaded portion of the flare nut.
3.  All oricies are removed from the Turner torch.  The base of the torch is solid brass and has plenty of "meat" to be turned and threaded 1/2"- 20.
4.  Correct.
The rosebud is an outsized propane torch that I pick up from a bargain table several years ago.  It is designed and made exactly like the smaller Turner burners.  That is all I know about it.  I removed the orifice.
I am using tank flashback arrestors.  Was not aware there are similar items for use at the torch.  I agree tape is not a good idea, but I thought it was good enough for a trial run.  The nozzles run so cool under the test conditions (no heat blowback) the tape never even got soft.  But I'm going make some sleeves (maybe out of copper plumbing fittings?) and solder them on.
A couple more pictures.  First includes the rosebud to give you an idea of its size.
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1252_zpsttchdb7n.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1252_zpsttchdb7n.jpg.html)
(http://i357.photobucket.com/albums/oo17/Orangealpine/IMG_1250_zps8amevlig.jpg) (http://s357.photobucket.com/user/Orangealpine/media/IMG_1250_zps8amevlig.jpg.html)
Post by: vtsteam on August 14, 2015, 10:13:57 PM
Thanks Bill, that clears it up for me.
Have you tried brazing anything yet w/brass filler rod? I ask, because that's the grail for me on an air/propane torch. If it can brass braze parts readily in open air, that would be a reason to make one.
Post by: Orange Alpine on August 14, 2015, 10:54:55 PM
No, I have yet to do anything worthwhile with the torch.  I have reported on almost everything I have done with it.  This idea came to me suddenly and I sort of squezed it in between other activities.
I have a fairly long and sad history with brazing, so it's not likely to happen anytime soon.  I find it strange as I am proficient with solder.  Maybe the more diffuse heat will be of benefit.
If you have propane nozzles of this configuration, give it a try.  You can lash up a test rig in pretty short order and you don't have to destroy anything.
