The Shop => Tools => Topic started by: wheeltapper on December 18, 2012, 09:31:09 AM
Hi guys, a bit of help here please.
I just got a 3-4" micrometer on fleabay for £6 + p+p.
its a german make, FEINMESSZEUGFABRIK.
it looks to be in excellent condition, see pic
(http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/micrometer1_zpsf596731a.jpg)
however, when I test it using the 3" standard I'm half a thou out and I can't figure out how to adjust the darn thing.
the only adjustment I can see is to take up wear in the thread.
I googled adjustments and all I see is turning the barrel using the spanner in a hole in the barrel.
guess what, this hasn't got a hole.
on the inside of the barrel there s a collar with two holes,
(http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/micrometer_zpsc18e6345.jpg)
is this an adjustment or does it just hold the whole shooting match together, I don't want to mess with it until I know what I am doing.
has anybody got any ideas.
cheers
Roy.
There should be a hole in the barrel for the included spanner to fit into. The barrel can be turned independent of the spindle.
As I have already stated in the original post " the barrel has NOT got a hole in it"
Roy
cheers
Roy.
Roy,
I've never come across a micrometer without a hole for adjustment. (I have seen them without on seperate micrometer heads.)
If it hasn't got a hole you might stand a chance of removing the thimble from the spindle (usually the thimble is on a taper and is held to the spindle by the ratchet mechanism) and putting it back on in the right place.
There might be a clue to your problem in the name of the manufacturer:
To misquote Oliver Hardy it's another "Fein Mess" :lol:
Cheers.
The spanner supplied is for adjusting it so...
Is there a cover over the barrel adjusting hole (does the knurlled cap unscrew?)
HA I've sussed it :)
unscrewing the small knob on the end of the spindle reveals that the anvil rod( for want of a better name) is held in place with a tapered sleeve and with the taper loose the barrel with the calibrations rotates on the spindle.
(http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/micrometer2.jpg)
the spanner is just for adjusting the wear in the thread.
I hope this helps someone else with this make of mic.
Roy
I have a Starrett zero to one inch micrometer which uses the same method of adjustment adjustment.
Jim
