Gallery, Projects and General => How to's => Topic started by: krv3000 on October 28, 2012, 06:51:46 PM
hi all this is a haw to on making a lense for a dti my way this dti belongs to john bubelboost i piced this up from his on saterday in all the dti is in good order it just needed a new lense the furst thing i did was to brush the dile to remove as much of the loos muck as posibel then i kleend the lens with coten buds and spit DO NOT USE ANY KEMIKEL CLENERS EVEN SOPY WATER CAN REMOVE THE PRINT the next thing wat to make the lense i used acrilik for this i needed sumthing to form the dome for the lense this was dun by the use of a spray can and a mini jam jar i warmd up the plastick till it became soft then plast it over the end of the spray can then with the jam jar prest on to the plastick once formd i rufely cut the shape out then cuverd bothe fases with tape then started to shape the new lens to fit i removed the besel from the dti as to ade the fiting of the lense to do this i had to remove the retaning ring at the back of the clock to do this ther is a noch cut out of the besel on the back wher you put a pin in and lift out the clip once all was dun refited the besel and gave the new lense a polish right pics
Bob
I am lost for words
Thanks mate
That clock was given to me by a retired machinist
I promised him i would look after it
just wat till you see the box its gowing in
Wonderful, and so well shown. Thanks
Very impressed with the home brew crystal :)
New watch crystals are available; they're not too expensive, but may need some adjustment to fit a DTI
e.g.
http://www.ebay.co.uk/itm/Replacement-Acrylic-Domed-Watch-Glass-Crystal-27-8mm-32-4mm-/140862946012?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&var=&hash=item20cc15fadc
http://www.ebay.co.uk/itm/36-5MM-to-45MM-D-TYPE-FLAT-BASE-DOMED-TOP-REPLACEMENT-WATCH-GLASS-CRYSTAL-C34-/310457507150?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&var=&hash=item4848b59d4e
Bob.
It seems, some people can do magic! :bugeye:
Well done. :clap: :clap: :thumbup:
I made some by cutting a flat disc slightly bigger than the bezel hole, and pressing them in at the centre to force them into a dome shape.
clever twat , nice job Bob :clap: :clap: :clap:
thanks all for the coments
After 4 years of use the 1" DI I use on my mini lathe has developed a cracked crystal ( don't know how that could possibly happen, lol) this is just what I needed. :thumbup: :thumbup: :thumbup:
Thanks for posting.
Jim
Good one Bob :bow: :thumbup: :clap:
Thanks Bob,I have a dti with a cracked crystal too. And now that you have shown me how to repair it, I will do so.
Jim
Nice repair.
I was given a intrepid test indicator a few years ago. It was missing the lense. I did not have any plastic stock, so I took a small plastic box for the donor material and turn the disc to size and then use a very small amount of glue to keep it fixed. I sure wish I had seen your lense bending technique before that was a very slick idea. It make it look original. Mine looks like it been repaired. :doh:
Take for posting!
Wouldnt have thought about doing that Bob. Well done looks great. :beer: have to look at mine now and have a go myself, how thick was the acrylic?
hi all the acryic is 1.5mm thick
:bugeye: It looks like new, or better. Amazing talent :thumbup:
Nice job bob.i think i have a few that need new lenses in them.i will rake them out for you.and drop them off at the weekend.i was going to chuck them out.but i guess you can make good use of them,got some other junk for you as well,went to the skipsto dump some rubbish,and came back with more than i went with,it all look like it has been made by an apprentice as test projects,center
gauge.tool makers vice,machining jacks,ect.just surface rust on them
peter
hi peter that will be brill it will be good to see you a gane
krv3000
For some reason I missed this one. Now that I have found it I can't pass by without saying how clever you are to fix it up better than new at little cost. You always seem to come up with a way to fix something that most of us would pass by. Thanks for sharing that with us.
Cheers :beer:
Don has also just brought this to my attention.
Just amazing - I never even considered a replacement crystal could be hand made!!! :drool: :clap:
Lads
I had a visit from Bob today (krv3000)
He brought my DTI back complete with its new face :beer: :beer: :beer:
The repair on the clock is first class
But more than that , He has made a nice fitted case for it :bugeye: :bugeye: :bugeye: :bugeye:
This is something i will always treasure
Thanks Mate
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4568.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4570.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4572.jpg)
Cracking job Bob :clap: :clap: :clap: :clap:
wonder if i have out bust I can give to Bob to fix John :med:
Aaawww..... John! :bugeye:
That dti and box assembly is gorgeous! :thumbup:
Blummin, WELL DONE Bob! :clap: :clap:
Nice one Bob! That is fab.
I`ve got a draw full of stuff I`ve broke over the last 4 years .... :beer: lol, Nice one Bob and bet you are well chuffed John!
thanks all for the coments im glad you like it john and rob you no if thers out you wont fixing juts let me no i enjoy seeing once condemd tools up and working a gane and not left on a shelf to go rusty if any of the members that have old dti.s or the like that they dont wont you can send them to me
Bob, how did you get the DTI writing on the plywood box?
Looks good,
Rich
ooo that wood be teling no WH smiths do them ther transfer letering all you do is rub the leter on by the use of a pencel then you can varnish over the top you can use car lacer but this is best sprade on in light cotes leev etch cote to dry well befor aplaying a nuther cote
Thanks for the 'how to' Bob,
I'd been quoted £36 for a new glass which i thought was really good since that also included shipping the dti to and from America but i then saw your post and thought i'd try your method first...It worked a treat....Although it took a few attempts to make a piece without it getting to hot then making tiny bubbles in it..your instructions were excellent....
Thankyou, your cleverness... :bow: :bow: :thumbup: :mmr: :headbang:
(http://i1101.photobucket.com/albums/g440/burky123/steadyeddie023.jpg)
...Mike...
hi im glad you got the job dun it looks like new
I do like to see a bit of ingenuity, a nice DTI brought back to life with skill and an odd bit of plastic. Nice box.
Well Done David
