Gallery, Projects and General => How do I?? => Topic started by: 75Plus on April 08, 2010, 10:27:15 PM
Title: Rolling Sheet Metal Into Cylinders
Post by: 75Plus on April 08, 2010, 10:27:15 PM
I need a way to roll 1 1/4" wide strips of 20 ga., (.035") mild steel into cylinders ranging in size from 1" to 2 3/8" in 1/8" increments. The seams will be welded forming tubes.
I think I need a very small slip roll. Does anyone have plans or drawings for such a device?
Title: Re: Rolling Sheet Metal Into Cylinders
Post by: Joe d on April 08, 2010, 11:38:05 PM
75Plus
Don't know if this would fit your needs, Feb '66 Popular Mechanics here (http://books.google.com/books?id=8dMDAAAAMBAJ&pg=PA190&dq=Popular+Mechanics&lr=&as_brr=0&as_pt=MAGAZINES&source=gbs_toc_r&cad=1#v=onepage&q&f=false)
If you go for it, let us know how it works out.... I've been thinking about deciding to need one  :proj:
Cheers, Joe
Post by: mklotz on April 09, 2010, 11:25:50 AM
This is a possibility...
http://www.micromark.com/BENDING-MACHINE,7739.html
Post by: 75Plus on April 09, 2010, 02:13:37 PM
Thanks Marv,
That is a possibility. Their design is adaptable to modification to better suit my purposes. I am already collecting materials and thoughts how to use them. I will start a thread in "Project Logs"
Post by: Dean W on April 09, 2010, 11:09:30 PM
Joe, a number of the sizes you need are commercially available.  For instance, 1", 1.125", 1.25", 1.375" and 1.5" tube all in .035" wall are all common sizes in 4130.  This would be a LOT easier than trying to roll tube as small as one inch diameter.
Not trying to say you shouldn't do this as a project, but if you are making something for sale, like your other accessories, it would sure keep your time investment down.
Dean
Post by: 75Plus on April 10, 2010, 10:34:49 AM
I have tried locating a single source for all the sizes and was not successful. Also buying small quantities and paying cutting charges along with shipping costs can get to be expensive. Couple that with the space required to store the tubes until they are used up plus having to cut and true up each piece as they are needed makes "roll my own" seem like a better solution. It also gives me a project to work on.
Materials gathering goes on as does designing. More later.
