Gallery, Projects and General => Project Logs => Topic started by: sorveltaja on September 13, 2020, 05:41:45 PM
Title: Friction ball drive - for 'gear' reduction
Post by: sorveltaja on September 13, 2020, 05:41:45 PM
This is an attempt to find out, if it's possible to make a friction ball reducing drive, using printed parts and bearing balls.
The need for such thing emerged, when I was testing several vocoder settings, and noticed, that some of them have quite narrow 'sweet spot' -ranges.
I thought of buying multiturn potentiometers, but as they cost at least five times more, than ordinary pots, it was time to look for another options.
Concept is simple; to make the reduction system as small as possible, by using a 'planetary gear set' -configuration, where the centerpiece is 'sun', rotating balls are 'planets', and outer ring is, well, outer ring.
At first, I did some tests using printed gears to achieve the reduction. It kind of worked, but was rather clunky and rough in practice. So, on to the next option.
Idea for using the bearing balls, as 'planet gears', came from the pics found on the net, and also from a video on Youtube(thanks to Joules for pointing that out).
To start drawing, this was used as a reference:
A simplified cross-section, for calculating the reduction ratio. In this case, it's 17.66/6.34 +1 = ~3.78(assuming the formula is right one for that). The ball size is 8mm:
Variation of the above concept:
Bit of development:
And finally, the working model:
Being static(non rotating) part, the outer ring extends all the way to the bottom, where the M7 thread is, for the potentiometer.
I would have never expect that much friction between two smooth metal surfaces. Suitable tension is easy to find by testing with different size drills/metal rods.
Diameter of the drill in the above pic is 2.3mm, and balls 10mm. Outer diameter, and height are both about 25mm.
Calculated reduction ratio is 10.26, while in practice it's almost 11.
Some observations of the current concept so far:
+ smooth action, once both ball mating surfaces are smooth
+ no need for separate tension spring
+ instead of being conical, the middle part, 'sun', is a straight steel rod
+ printed outer ring is flexible enough to provide friction between moving parts, or then it could be machined out of hard rubber, like that used in hockey pucks(I think I'm going to try that one also).
+ can be attached straigth to the potentiometers thread
- exact reduction ratios might not be that easily achieved, but could be possible by tweaking the parts.
- not sure, how well the printed outer ring can stand the continuous tension
- outer ring ball mating surfaces, if printed, needs to be smoothened, by machining or by some kind of sanding fixture
Further things to do/add/test:
Pointer, that shows the actual position of the pot's wiper.
To secure, that the center metal rod stays in place. Perhaps by machining a tiny v-groove to the ball mating point. But we'll see.
To make scaled down versions, to see how small it can get, to be practical.
Title: Re: Friction ball drive - for 'gear' reduction
Post by: WeldingRod on September 13, 2020, 06:29:31 PM
Plastic, with its low elastic modulus, is your friend on the outer race!  The race is the spring!
Post by: sorveltaja on September 14, 2020, 11:48:11 AM
Yeah, didn't even think about it until I poked a drill bit in the center.
The smaller version works just like the bigger one:
It uses 4mm bearing balls, and 1mm drill. Outer diameter is 15mm and height is 17mm. There is no room for a grub screw, so the potentiometer shaft needs to be filed to have a flat surface to suit:
What comes to outer ring material, pla could be good enough, if there aren't heat waves or such high temperatures, that turn it into cheese.
Post by: pycoed on September 15, 2020, 04:48:24 AM
Are there pictures attached to this? If so I can't see them
Post by: PekkaNF on September 15, 2020, 07:58:43 AM
I can see the pictures. They are on external server. Maybe overzealous firewall or settings? Or big bad company enforced policy?
Post by: sorveltaja on September 15, 2020, 08:18:03 AM
I use Firefox, and tried with Opera also, and with both, I can see them. They are hosted in my local internet provider's server.
Post by: pycoed on September 15, 2020, 02:58:18 PM
 :scratch: :scratch: :scratch:
I can see them now! :scratch:
I'm on my laptop, but they weren't showing on my desktop this morning. Both running Ubuntu 20.04 & Chromium. Time for some investigations, I think...
Post by: sorveltaja on September 18, 2020, 09:46:44 PM
As the concept works with printed parts, how about machining the outer race using other material:
I chose the hockey puck -rubber, because it's somewhat flexible, easy to machine, and cheap. When inserting the bearing balls, it needs to budge just a bit.
On the other hand, the 'carrier', that transmits the ball's rotation to the potentiometer shaft, will still be a printed one. Besides, it's not a part of the 'tension network'(consisting center metal rod, balls, and the outer race), and should retain its shape in use.
The balls seem to need at least some kind of groove in the outer race, to keep them in their rotating orbit. As I don't have too many boring tools, I'm thinking of using a 4mm ball end milling bit to machine the groove for the 8mm balls:
Most(if not all) of the pots, that I've used in recent projects, have M7 x 1 threading, so that size tap is also needed, if one chooses to machine the outer race.
In the end, the center metal rod, 'sun', might not need any kind of groove in it, as the tension itself is enough to keep it in the place. In fact, when testing with printed parts, I had to pry it out.
Post by: Onetrack on February 02, 2022, 04:18:15 AM
I can't see any pictures either. Have tried Chrome and Edge, but no luck.
quote author=pycoed link=topic=13213.msg158733#msg158733 date=1600159704]
[/quote]
Post by: JHovel on February 03, 2022, 08:28:48 AM
Great work!
A standard ball bearing works like that too. Just find a tight one and wash the grease out, so the balls roll instead of skidding.
Post by: vtsteam on February 03, 2022, 10:06:14 AM
Yes very interesting -- didn't see this one until now for some reason. Great work sorveltaja as usual, great ideas and really well executed.
(To those not able to see pix, it's your overly protective browser's or security add-on's fault -- unnecessarily blocking the origin of those pix which is located in Finland : www.elisanet.fi . If you have access to your settings, just change them to allow that domain.)
Post by: Sea.dog on February 03, 2022, 11:56:16 AM
I can't even see any indication that there are any images. Strange, because I used to be able to see them.
Post by: vtsteam on February 03, 2022, 01:32:47 PM
See if you can set your browser to view "insecure" web content.
The problem is that Google and Firefox both decided a few years ago that normal http links are "dangerous" and thence forward all websites viewable in their browsers must have a security certificate and tag everything as https. This killed massive amounts of photos, links etc. across the internet. They remain, but they simply aren't viewable because your browser refuses to do so. That's what's happening here.
You can change that in a setting on most Mozilla based browsers (like Firefox) to allow http, or so called "insecure" links. Then you can continue to see all of the content generated traditionally on the web for the last couple of decades.
BTW, there is nothing wrong with http for just viewing information on the net. Frankly unless you're banking or purchasing something at a website, https and so called "security" certificates aren't needed, nor if actually present do they absolutely guarantee actual "security" anyway.
But it sure hurt small websites and forums to block their long standing content, and increase their costs by forcing them to purchase and maintain security certificates. Certificates are available from, not surprisingly, the biggest browser enterprise of all, which through one of its subsidiaries also provides popular videos to supercede all that old uncontrolled and unmonetizable web content, which it now blocks.
Anyway, long explanation. It's usually changeable in a browser setting.
Post by: sorveltaja on February 03, 2022, 03:53:49 PM
That browser issue is odd, or perhaps not. One way could be to test something like Waterfox portable, which doesn't need to be installed, and if the images show up, maybe use it as a "backup browser" for such situations. Another way could be Tor-browser. From what I understand, it should circumvent at least some of the 'limits' that most popular (updated) browsers seem to have.
I have a bad habit of using an old version of Firefox. Generally the web pages show and work like they should, but if not, I have also more up-to-date browsers installed.
As for the project itself, I actually haven't needed such a multiturn pot since the vocoder project. But who knows, maybe in some of the future projects. It's funny how one forgets completely all the details about past projects, when time goes by, such as how to calculate the (approximate as it's gearless) ratio of the sun/planet/ring like in this project. In fact, I had to look it out some time ago, and yeah, I came here to check how I did it.
