Gallery, Projects and General => How do I?? => Topic started by: Alphawolf45 on April 25, 2009, 09:23:40 AM
Title: Make rings for outboard boat motor
Post by: Alphawolf45 on April 25, 2009, 09:23:40 AM
  I have a few 70ish year old outboard boat motors that I am having fun rebuilding.... Today will draw/CAD pump impeller and use cnc mill to make that for me... Lot of bad parts on these motors and each a challenge and an education to repair or make replacement part..Considerable fun to take a rusted and busted old motor and get it running again.. I am merely weeks into this type play but I think I will be fooling with old boat motors for a good long while..Might have found my niche..
But I got this one old engine that had piston rusted up inside the cylinder.. I got it out but now need new rings for it.. I emailed OTTO to get new rings and he hasnt got back to me.. But I am pondering , I would prefer to make set of rings myself because the hobby is making stuff, not buying things.... Is there an explanation somewhere handy that somebody can point me at , I want to see how good rings are made in small workshop....
  Hey seriously..Old boat motors let me cast aluminum parts, weld aluminum, fool with carburation and ignition.. I sitting here now wondering about building a small diecasting machine.. Might would ocasionally enjoy building diesets for making impellers and carb parts...... There lots of possibilities for keeping the enthusiasm going in the home workshop............Ohhhhh, I drug in an UGLY old aluminum boat and am half finished putting a boat trailer together..I plan to run these old motors on the lake :ddb:..
Title: Re: Make rings for outboard boat motor
Post by: Brass_Machine on April 25, 2009, 10:03:26 AM
When I was doing some research before... I found the following:
Very Technical (http://www.sylvestris.btinternet.co.uk/rings/rings.htm) link
Model engine news (http://www.modelenginenews.org/techniques/piston_rings.html) article
Now I have made any yet, so I can't tell you if they are accurate.
How about an RC boat with a scale outboard motor?
Post by: Alphawolf45 on April 25, 2009, 12:42:31 PM
Thanks Eric that will do nicely..As for small model outboard engines, not for me thankyou...I like fullsized parts that I can see..
Post by: sbwhart on April 25, 2009, 01:51:59 PM
Latest issue of Model Engineer have just had an article on making cast iron rings.
Good Luck
