The Shop => Metal Stuff => Topic started by: doubleboost on July 01, 2012, 04:29:15 PM
Lads
I have been wanting to make a horizontal steam engine for some time now
As i have a cylinder pattern from my marine engine i decided to make the engine around this
It will be a fairly big affair with no bolts smaller than M6
A simple L shaped pattern is needed for the base
In the past i have used MDF as pattern material
The dust from sanding and machining this horrible material has made me feel poorly on more than one occasion
Rob Wilson donated some Birch ply wood and i had some bits of old Oak shelving (Popper wood)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_3831.jpg)
The basic shape glued together
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_3887.jpg)
Car body filler is used to blend curves
(http://i261.photobucket.com/albums/ii63/john970s0/P7010133.jpg)
All internal corners need a nice smooth fillet ,in the past i used car body filler (easy to apply but hard work to sand off)
I bought some fillet wax (bees wax) this is blended in to the corners with a ball bearing on a stick.
Much easier and faster than body filler.
(http://i261.photobucket.com/albums/ii63/john970s0/P7010139.jpg)
As you add more detail it starts to look something
The Grey bit will be hollow the rest is solid
(http://i261.photobucket.com/albums/ii63/john970s0/P7010146.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7010148.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7010147.jpg)
A coat of high build primer transforms the pattern
looking good john,what size flywheel you going to use ?
That is not going to be a small engine! Can't wait to see this one get built.
Is this going to be just a model or do you plan to power something with it?
well dun john
:bugeye: It's huge!! Nice work John.
The usual, beautiful pattern work John! :clap: :clap:
Clocked in. Watching quietly....... :thumbup:
That is one big mould for a home shop :bow:
What are you going to cast it with?
It is a fair size
I am trying to work out its volume
I can weigh it find out the SG of Oak then work out its volume
Putting it in to water to measure its displacement is not a good idea
The base will be cast in Aluminium
If you have a reasonable size offcut of the oak, shaped such that you can easily work out its volume, you could weigh both that and your pattern. Then, roughly speaking because of your birch ply and filler, the volumes of the pattern and the offcut will be in the same ratio as their weights.
I was thinking if i weigh the pattern find out the SG of Oak
The formula is
Volume = Weight /SG
Hi John,
According to my inherited 1941 Machinery's Handbook list of "Average SG of Woods (Dry)":
Weight per cubic
SG inch (pounds)
Live Oak: 1.15 0.042
Red Oak: 0.75 0.027
White Oak: 0.80 0.029
Hope this helps, though these figures are supposed to be for dry wood, so I'm not sure what "live oak" is.
If it's from Machinery's Handbook, they could well refer to N. American species ???
Not sure if they're the same as European Oaks.
Silky Oak is a eucalyptus .... IIRC .. :scratch:
Long time since I did any wood butchering
BC
BC
That's why I suggested weighing an offcut of the same wood, the volume of which could easily be calculated.
To add to the confusion, Selly Oak is where I spent 3 years at university in Birmingham. :)
Andy.
Had a bit google came up with this
SG of birch ply is 0.67
Pattern weighs 2.2 Kg
Formula is
Weight / SG = Volume
2.2 / 0.67 =1.474 Litres i assume
I can melt 3 litres so it should not be a problem :Doh: :Doh: :Doh: :Doh:
Problem is that 2.2/0.67 = 3.28 !
So
It is devided not multiplied
That looks like a better volume :lol: :lol:
:lol: :lol: ye need a bigger pot John :poke:
You mean like yours :D :D :D :D :D
By the time i get some risers and gates in there it will be a good 4 litres :doh: :doh: :doh:
BC
Andy.
Selly Oak ??? That's where Ariel bikes were made. :thumbup:
I had a 350 Red Hunter, a bloke up the road has a 1937 500 VH.
Did you make it ??? :lol: :lol:
I'm off .... :)
BC
You don't need to know the sg of oak. Now it's painted use Archimedes principle to find it's volume. Place a brim full container of water inside a dry bowl. Imerse the pattern so that the water displaced spills into the bowl. Measure the volume of the displaced water - simples !
Decided to modify the furnace and make a bigger crucible
The story in pictures
(http://i261.photobucket.com/albums/ii63/john970s0/P7080020.jpg)
Furnace extension ring
(http://i261.photobucket.com/albums/ii63/john970s0/P7080035-1.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7080034.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7080012.jpg[/IM
[IMG]http://i261.photobucket.com/albums/ii63/john970s0/P7090045.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7080032.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7090051.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7090049.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7090048.jpg)
And i was hoping the patten would come back pink :lol: :lol: :lol:
You seem to have a thing about me and pink :lol: :lol: :lol: :lol:
I would have thought silver would have been your colour :) :) :) :)
your missing a photo :poke:
Rob :coffee:
Will this one do
(http://i261.photobucket.com/albums/ii63/john970s0/P5230062.jpg)
:lol: :lol: :lol: dam fine lookin chap :thumbup:
is rob starting to mine his own ally now?
Great day out mate :beer: :beer:
Once you get your cupola furnace sorted we will be able to smelt our own metal :lol: :lol: :lol:
Would you buy anything off a twat in a yellow mac ?
Now i realise why i like it hear :lol: :lol: :lol: :lol: :lol:
Nope just like dressing up in rubber :lol: :lol: :lol: jb3cx , i carried that lump of lead ore for friggin miles :Doh:
I it was mate ,,, next time i am taking a mobility scooter :lol: , then i can just zip around , no back breaking stooping :med:
Ist not a mac JS ,,,, is a very fetching one piece :lol: :lol: :lol:
jcb3x
http://madmodder.net/index.php?topic=3168.msg33953#msg33953
Enjoy
So me and Rob's having a conversation.
I sez to Rob, your a twat, you have always been a twat and will still be a twat in the future.
If you entered a twat competition you would come second.
So Rob says why wouldn't I win ?
I replied because you are a twat.
That would be because the OLDER more experienced twat would win :coffee:
Have you made the furnace from a BASS bear keg John ?.
I didn't know Rob was a trog :D
Nice work on the patern
Lads
Not cast that base yet
Lots of prep work first
Made up a set of crucible tongs today
Nothing special just 1 inch flat bar and a bit of welding
A good tip for bending flat bar is to cut the outside of the bend 2/3 of the way through bend it then a couple of weld beads and you are done
(http://i261.photobucket.com/albums/ii63/john970s0/P7150055.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7150056.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7150057.jpg)
:thumbup: i best get my finger out and make some rammers :palm:
Rob the trog :headbang:
Now that you mention it :beer: :beer: :beer:
Its posts like this that remind me why i joined this site, Great work and some great comics. :clap:
Nice lookin pattern there John, waiting now for the pour.
Lads
Bigger castings need bigger tools
Time for a man sized rammer
Will my lathe ever be the same :slaphead::slaphead:
(http://i261.photobucket.com/albums/ii63/john970s0/P7190061.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7190063.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7190064.jpg)
Hoping to get it cast this weekend :smiley-dancenana::smiley-dancenana:
:lol: :lol: :lol: :lol: :lol: :lol: pleased thats your lathe mate :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
So am i mate :drool: :drool: :drool:
I will be up all night cleaning it
The radius tool removes wood at a rapid rate :) :) :)
I am pleased i cut it "dry" :Doh: :Doh: :Doh:
Hi , John , I have had my lathe looking like that before , :bugeye: hassle to clean but at least it soaks up the oil leaks :thumbup:, canny bit wood turning mind John and nice pattern too. I am looking forward to seeing the casting. I have a Graduate woodturning lathe now and they are one hell of a lot easier to clean , quick brush off and its done :clap:. thing is you still have your mega rammer so alls well that ends well :D
Mick.
good job john
That looks a handy weapon you've made John! Looking forward to seeing it in action. :)
No probs with cleanup! Less than 10 mins, with brush/ shovel and vacuum........ :thumbup:
You should have been a woodworker :hammer: :lol:
Slander. I though that swearing was forbidden here, unless the sentence contains details of workshop or pattern. Does potato smasher qualifies?
Lads
After a eventfull morning i now have a base casting
(http://i261.photobucket.com/albums/ii63/john970s0/P7210006.jpg)
I was joined by Rob Wilson for the casting rituall
It is easier with 2 people (safer as well if something goes wrong) in this case i could not have lifted the flasks alone
The pictures tell the story
(http://i261.photobucket.com/albums/ii63/john970s0/P7210065.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210067.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210069.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210070.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210073.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210075.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210079.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210082.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210084.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210087.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210096.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210099.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210011.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/P7210015.jpg)
Thanks again Rob
:) :) :) well dum john dam fine work but i think you shud of cast a sper one up
Clearly shown, John! :thumbup:
Really nice, crisp casting. Well done, you two. :clap: :clap:
:jaw: Looks great. I didn't know the said would hold itself together quite like that for the hollow.
Fettled up well John :lol: :lol: :lol: :lol:
Aye , it was a good couple of hours ,bacon sarnnie was the best part :)
Real nice work a fine bit of casting. :clap: :clap: :clap: :clap: :clap:
You can now use that rammer at Christmas for cracking nuts :lol: :lol:
Look forward to the next step machining it all up :whip:
John and Rob
A fine bit of casting that was. Thanks for showing the pictures. Just like looking over your shoulder.
Cheers :beer: :beer:
The lads done good :thumbup:
Looks like all went well with the casting, very impresive :clap:, looking forward to seeing it being machined , The weather was spot on for the cast too , which is almost a miracle considering whats its been like lately.
Class job there !
Mick.
A nice clean casting John, And the hired help comes cheap for the price of a bacon sarny.
That Lad's anybody's, for the promise of a bacon sarnie.......... :lol: :lol:
Hi Rob & John
knowing that there are many of us out here who cannot do a casting line this, how much would you charge for one shipped to Australia.
with beautiful base castings like this I would suggest that you have the makings of a nice little business here.
Have fun and let us see more.
Bernard
Hi Bernard
Just speaking for myself ,I will never do any castings for anyone else ever again . :coffee:
i hope you and john ant had a falling out
:lol: :lol: :lol: no Bob .
Its just not worth the hassle for anyone else .
I have to agree with Rob on this
A couple of years ago Rob spent countless hours on a casting job
His time and effort (not to mention the cost of gas and bronze) were not appriciated
thats ok i must say rob is a bit shy on the bacan buttys thow :) :lol: :lol: :lol: :lol: :lol:
Lovely casting. Thanks for the photos.
