The Shop => Metal Stuff => Topic started by: bry1975 on July 14, 2011, 04:37:38 PM
Chaps,
Nickel Silver so is it generally softer than 316L SS?
TIA
Bry
Yes, a lot softer. Known as an engraving material for cheaper jewelery. Mainly a copper/nickel alloy.
Look up "German Silver" on a google search for more info.
Thanks Dean,
I'm hoping the 2mm rod ordered has got enough stiffness for the non marking tool I'm making.
Bry
Brass works great for non marking tools, Bry. You might already have some of that laying around?
Dean
Biggest worry is the pin diameter can't be over 2mm diameter and will be 4-5mm long supported like a cantilever, so looking for a high stiffness/young's modulus metal probably go for nickel silver or phosphor bronze 5% hard.
I'm more theory than practical with design so will be interesting if the tool works satisfactory. :(
