The Breakroom => The Water Cooler => Topic started by: doubleboost on October 07, 2012, 05:31:54 PM
Lads
A friend of my Dad passed away a good few years ago
He was in to model boat building as is my Dad
Today his wife called in to see my Father bringing with her his hobby tools and models
I got all the electric drills sanders ect (no metal working tools)
I did find this one item that interests me , it is made to a very high quality about 4 inch diamiter
Has any one any idea what it was made for it must be quiet old
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4384.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4383.jpg)
(http://i261.photobucket.com/albums/ii63/john970s0/IMG_4382.jpg)
mmmdon't no just a gess can it be sum sort of molding patern
What krv3000 said or maybe an advertising/sample piece.
br
It is not a pattern
Intersting though
Let's say that it was 'irish' begorrah.
Could it be a template for a mold :coffee:
Let's get closer and say 'Belfast'
It's a pastry mold, for making decorative pasty cups.
well no mater wot it is dont live it liying a rawnd the wife my think its to go on the wood burner on a nuther note haw is the no smoking gowing and i will be poping up to see you all being well this sat
Oh dear- the IQ test :doh:
Read what is given.
Machetts is- and Google says- it's a shop. Google says Machett shop is in Belfast
Google says its a music shop.
Oh dear. Oh dear. And it still exists.
It is not a pattern
Intersting though
Why not a pattern, it looks like one!
Read what is given.
Fergus,
You mis-spelled your search word. It is Machfitt which when Googled takes you to Machfitt Flooring and other locations.
My guess for the use would be a paper weight as it appears to have been handled quite a bit.
Ah well, I got to Machett Music and it
is probably 'Machine Fitting Shop'
So it looks like a mould for a gear.
What a shame to find it so boring :doh:
No-one has explained the word "slot" yet.
Machfitt Shop Slot?
Slot Machfitt Shop?
Shop Slot Machfitt?
Googling returns nothing useful; Machfitt flooring as already mentioned (doesn't explain shot; or shop particularly well).
There's no sign of Machfitt in either the Domesday book or 1911 census (or earlier). Could Machfitt be German, i.e. this was something that came over during or after WW1 or 2? Again, google is unhelpful.
If it were not stamped, I would have suggested it was an engineer's exercise, judging by the lines drawn on the teeth; I would definitely think it was handmade, but as to its purpose or maker, it would seem the required information is not yet online...
Apologies- Ade!
See my boring correction.
N
Apologies- Ade!
N
You must have been typing at the same time I was...
Hmm - Slot[ting] Mach[ine] Fitt[ing] Shop? Tenuous.... it reminds me of one those Backronyms you see so often these days.
PS: If it were a mould, wouldn't it need to split at the widest point to facilitate its removal?
There is a misplaced "." between "MACH" and "FITT", as if whoever stamped the letters found he hadn't left quite enough room when he got to the end. Accordingly, perhaps it should begin with FITT, and be read as FITT.SHOP.SLOT.MACH.
FITT: must be an abbreviation = Fitting, Fitters ?
SHOP: probably a full word, rather than an abbreviation.
SLOT: might be a full word, but more likely an abbreviation for something like "Slotting"
MACH: probably an abbreviation for Machine or Machinery.
Not that this adds much illumination.
Andy.
A pattern for a gear for the repair of a slotting machine (slotter) that was located in the fitting shop? That explains the lack of a part number and a manufacturer's name.
This item is very intreging
It is not a pattern for casting (the angles are all wrong for that)
It is held together by a wood screw i will take it apart and report back :drool: :drool: :drool:
I was actually going through a routine of checking back history- I was wrong but the principle applies.
I assume that your father's friend worked locally ie on the Tyne somewhere. Your Dad would know this. There are still some of us who have 'survived' and still are 'with it' to work it out.
For a start, it is going to be a biggish firm to have a separate
machine shop for slotters. I was thinking of Vickers intially but thought more of Churchill Gears that were at Blaydon. It sort of ties in with the type face used on wood which I have on some of my stuff from the 40's and 50's.
Regards
Norman
