Gallery, Projects and General => How do I?? => Topic started by: slowcoach on July 18, 2010, 02:33:21 PM
Hello, can anyone help, I have a single phase motor 240v AC 1/4hp that I want to use on my pillar drill. The problem I have is that its rotating in the wrong direction (anticlockwise) :scratch: and I was wondering if anyone on here as a solution to my problem? I have tried reversing the polarities but it still runs anticlockwise :bang:
Rob :thumbup:
IF the motor can be reversed there will be a wiring chart usually on the motor or inside the wiring box for the motor. If you don't see that you probably have a single direction motor. Turn it around and mount it on the other side of the belt if possible is your only option.
Dan
I was going to say flip it 180º. May be the same thing Dan suggested. :scratch:
take the ends off and swap them over so the shaft sticks out the other end
Stuart
If it has a capacitor it can be reversed by reversing the connections to the starter windings, it is a job for someone who can open it up and figure out how to do it.
Yep, same thing but you described it in a more elegant fashion. :D
does this help
Thank you, for all you excellent suggestions :thumbup: Mr Swift, I really must thank you for your wiring diagram that you posted, I followed it, and I'm pleased to say it worked a treat :headbang: Pillar drill now spinning in the correct direction :D I must admit, I was a bit nervous as I flicked the switch :zap:
Thanks again Guys
Rob :thumbup:
Hi Rob
happy to help when I can
I don't normally work on machines with mains powered motors but ,
as people like to see pictures
some vt machine's I have worked on in the 80's and 90's
ampex VPR2 and Sony BVC-10 ( the modded vpr1 looks the same )
Hi John,
Impressive, but way above me, I would'nt know where to start fixing something like that :bow: Thanks for showing :thumbup:
:offtopic:
If we're into piccys of tape libraries ...
This is one I used to work on ..
Although I think the AML/2 is obsolete now, huge thing ... handling robot not to be trifled with .. unless you like coming second .. posthumously ..
http://www.sunstarco.com/Tape%20Drives/ADIC/ADIC%20-%20AML_2.htm
Dave BC
