The Shop => Tools => Topic started by: Dell on February 13, 2024, 10:42:02 AM
Title: Fitting a Multifix Aa
Post by: Dell on February 13, 2024, 10:42:02 AM
A bit of advice please, I have made a new post for the Multifix size Aa on my Myford and as I didn’t use the steady pin initially I thought I would do it as I have it apart, underneath are three equally spaced holes although I only need one but am not sure how to get one in the correct place in the compound if it’s slightly out the holder won’t be square to the headstock , I know the Multifix will tour but it could be possible to get the hole half a hole out so if anyone has a suggestion or has already done it would be much appreciated , hope that makes sense.
Dell
Title: Re: Fitting a Multifix Aa
Post by: philf on February 13, 2024, 11:59:28 AM
Dell
Dell,
Perhaps post a photo. I'm guessing the holes are blind.
I have the Dickson type toolpost on my lathe and it doesn't have a location dowel (nor does it need one). Because it's basically square I can easily set it with a square.
Post by: Dell on February 13, 2024, 12:30:48 PM
Here is a picture of the underside of the Multifix I only need to use one hole and the holes are blind.
Dell
Post by: philf on February 13, 2024, 01:22:27 PM
I'm guessing that the three holes would locate the body in different positions so e.g ideally you'd get one to position the tool to be square to the topslide and the others would give you a few degrees variation. I haven't been able to find a drawing with the hole positions online.
Post by: Dell on February 13, 2024, 01:48:26 PM
No I couldn’t find a drawing either , I only need to fix it square to the compound because it’s adjustable in 40 other positions without undoing the centre locknut.
Dell
Post by: smiffy on February 13, 2024, 02:03:38 PM
I have 3 of the larger AA size toolholders and they all have 2 holes at 180 degrees
Post by: philf on February 13, 2024, 05:57:40 PM
I'd just put a toolholder in and set it with a square.
Post by: Dell on February 14, 2024, 02:58:02 AM
That’s what I had done up until now but when I last used a knurling tool the whole lot moved hence wanting to add a single pin.
Dell
Post by: philf on February 14, 2024, 04:35:00 AM
Dell,
What sort of knurling tool are you using?
The clamp style knurling tool is far better for your lathe than the standard (one sided) type and isn't likely to move your tool post.
Post by: philf on February 14, 2024, 06:00:38 AM
Dell,
I've done a bit more Googling and have found sections through the toolpost and even a photo of a spare body. All show through holes! Have you taken the top cover off to have a look?
I know this is a bigger Multifix but clearly shows the holes at the top.
(https://listerengine.com/coppermine/albums/userpics/10017/normal_image_2024-02-14_200136293.png)
Post by: Dell on February 15, 2024, 04:26:11 AM
Dell,
It is a scissor type and the tool turned away from the headstock causing holder to turn.
Dell
PS I have got it setup in rear tool post now so shouldn’t be a problem now.
Post by: Dell on February 15, 2024, 04:32:23 AM
[\quote] I know this is a bigger Multifix but clearly shows the holes at the top.
[/quote]
Yes I have taken the top off and they are definitely blind holes , it seems the larger Multifix has through holes but not small ones.
I ended up turning a pointed stud inserting it in hole squaring holder and tapping with a soft hammer and it marked it just enough for me to centre punch and drill , all back together now.
Dell
Post by: philf on February 15, 2024, 08:40:54 AM
Dell,
Dell
I also use my clamp style knurling tool in the rear toolpost.
Post by: philf on February 15, 2024, 08:42:37 AM
Dell
Glad you've got it sorted!
Post by: John Rudd on February 15, 2024, 10:11:09 AM
I do that all the time, especially with parting and threading tools where it matters to be square on to the job…
Post by: Jo on February 21, 2024, 03:43:49 PM
My various Lathes have size AA, A and C Multifix toolsets.
I have never used the holes under the holder to lock the toolholder to the top slide. Can't see the point of locking them, just tighten up the nut on the centre pillar to the correct angle. I would much rather the tool/holder/post get knocked out of the way than have something else break  if it goes wrong :bugeye:
Jo
