Gallery, Projects and General => Project Logs => Topic started by: PhiberOptix on September 09, 2009, 11:48:12 AM
This is the stage I was at Last night, basic stuff just milled out a large portion and a quick lick with a fly cutter
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0500.jpg)
todays efforts
milled a slot in the side and center drilled, pilot drilled, and 8mm drilled and couter sunk the holes
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0502.jpg)
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0503.jpg)
milled a slot thru the base
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0504.jpg)
then 5mm slot for running guides for the back jaw
this is as far as i got
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0506.jpg)
Looking good there. :headbang:
That's a bit of a chicken and egg situation I suppose - helps if you've got a machine vice in order to make a machine vice. :scratch:
That is starting to look very nice. Very professional looking. Keep up the build log!
That's looking good, I'd be very interested to see the next stages... :thumbup:
Good going on that vice Andy :clap:
:beer:, Arnold
Nice 1! Looks like you have :proj:
I had one of those sort of vices many moons ago when I had a little sherline milling machine. The vice was brilliant! The machine was really accurate to give it its due but a just for small things! Didn't have a quill feed either which limited it a bit!
Nick
turning the chamfer on the mushroom ring now need to drill it and part it off
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0513.jpg)
Fly cut finish on back of rear jaw ready for drilling for locking mechanism
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0514.jpg)
vice and parts for locking mechanism so far
(needs a longer caphead the biggest i have it too short)
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0518.jpg)
once I get a longer caphead tomorrow i can give the vice a final fly cut
also thinking of making some alternative jaws in brass and stainless to fix to the existing ones
Looks great, I found my vice very accurate and possible to get a high clamping force. good design as it's always pulling the jaw down as well.
Interesting project. Is that aluminum you are working on?
Yes its Aluminium (Aircraft grade) It is to be used for Aluminum only until I make some Brass and Stainless Jaws for her
I may even have her anodised
regards
Just wondering, how are you going to clamp it down to the table?
Is there spesific english language term for that kind of machine vice? I'm willing to build one(two, maybe three) small(er) versions for special purposes.
I'm not lol, its going sideways in the vice it was made in
but...
I guess you can put longer pins thu the side holes and clamp down on them
or mill clamping slots in the ends & sides
I have seen blocks with pegs in the side just for clamping these down
but mines going in another vice so you adapt/mod your to you needs
regards
I have only ever know them as a machinist's vice I am unaware of any specific name
I'm sure it probably has one I just dont know it, maybe someone could enlighten us
First ones on here
http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
I use a 1" one all the time for holding small stuff in my larger vices.
I've seen them called tool makers vices before, think they are all ground, high precision things though.
Andy, nice project you have started there. I am been kicking around building one also probably this fall when things slow down a bit. keep up posted with your build..:)
The starts of a small vice been fly cut
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0524.jpg)
sorry go carried away and forgot to take pics
All done except the polishing
BIg brother and the little one
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0526.jpg)
and after a quick polish the baby of the two vices vice looks like this
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0537.jpg)
I do like your vices :lol:
Esp the dinky one as I could do with one of those. I have some bars of cast steel I may have a go with......on top of all the other things I want to do of course....... :doh:
Is there some kind of T-piece, where tightening screw goes?
I have seen that kind of vices only on pictures(http://emoticons4u.com/crazy/1261.gif).
There is a plan on
http://www.projectsinmetal.com/free-metalworking-project-plans-toolmakers-screwless-vise-mill/
Hope this works / helps
Gerhard
yes there is a 'T' piece
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0538.jpg)
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0540.jpg)
(http://i628.photobucket.com/albums/uu7/phiberoptix/000_0539.jpg)
All I used was a slice of round stock drilled and taped to match the locking cap head
and an off center hole thu the side for the locking pin (in this case a 1mm wire)
also there is a slot milled in the underside of the jaw to locate the slice into
to stop it rotating whilst putting the pin thu
There are plans for this vice but i did not use any
Hope this helps
The same method was used in her bigger sister
Thanks for the replies! They helped me to understand the mechanism :beer:.
Good going Andy :clap: :clap:
And to think you groaned about Tiny being small :lol: - come to think of it, have you found a compressor yet ?
:beer: Arnold
:beer: Arnold
Hi Arnold
Small is an understatement - drilling sidways tru a 1/16th wire with a #57 drill bit and then make a pin to go into that hole - god did I need zoom eyeballs for that :lol: had to resort to making a jig in the end.
No havent found one low enough (3-5 psi) I thought about canned air too but rejected that idea when I saw the cost so now going with the 'Build a boiler'
and run her off steam and hopefully the elbow engine too, so so many projects ;)
