Gallery, Projects and General => How do I?? => Topic started by: Bourne Bill on February 27, 2009, 03:58:24 PM
Title: treadmill
Post by: Bourne Bill on February 27, 2009, 03:58:24 PM
I just scored a treadmill and its in working condition. I was thinking of using it as a motor on my Jet mill, but being only 3/4 H.P. 8 amps,I dont think its powerful enough. Any Ideas on what else I could use it for?
Title: Re: treadmill
Post by: Darren on February 27, 2009, 04:06:58 PM
What type of Jet mill, if this one then yes I suppose it is a little on the small side. But I suspect you mean a smaller one  :scratch: got a pic or link.
http://www.jaskela.com/html/img-pages/jet_mill.html (http://www.jaskela.com/html/img-pages/jet_mill.html)
Welcome to the forum BTW,
Post by: sbwhart on February 27, 2009, 05:24:10 PM
Hi Bill
As Darren said a photo would be helpfull   :worthless:
If you do a search on the forum ther's a couple in threads that can help you with this.
I take it the treadmill is the type you get at gym.
Could you use the motor to make a post grinder for your lathe ?. Or a buffer.
Have fun
Post by: John Hill on February 27, 2009, 05:30:15 PM
A 3/4 HP motor that takes 8amps?  Sounds like a low voltage (80 volts or so)  DC motor?  If thats what it is and it is a permanent magnet type you have the makings of a good wind turbine generator!
An easy test, short the wires together and see if it is hard to turn with your fingers, if so it is likely to make an effective low voltage generator and might be a candidate for EBay if you dont have a need for it.
Post by: Brass_Machine on February 27, 2009, 06:06:20 PM
Hey Bill!
1st Welcome to the collective  :borg:
2nd I really don't have an answer for you... these guys might!
3rd I got rid of the duplicate posts. Hope you don't mind... easier to follow the thread if there is only one.
Post by: Darren on February 27, 2009, 06:08:08 PM
Yes you could do that, but tread mills come with a motor controller and you have a great source for a variable speed controlled machine.
It's likely to be a DC permanent magnet motor with high torque.
Don't let 3/4hp fool you, many lathes run on 1/2hp and even 1/3 hp My industrial Smart and Brown only uses 3/4hp on low speed and that has plenty of power.
Post by: bogstandard on February 27, 2009, 06:34:58 PM
I replied to one of the deleted posts, and basically said what Darren suggested.
That size of motor would be perfect for a medium sized lathe, about 5" centre height, and having variable speed makes it really desireable for such a use.
Post by: Brass_Machine on February 27, 2009, 07:39:35 PM
Sorry about that John... I thought I had moved your post.
Post by: John Hill on February 27, 2009, 07:59:54 PM
 :bang: Duh!  I got distracted by "what else can I use it for?"
Must confess though the tought of using the treadmill electronics for a variable speed drive did not enter my tiny mind! :doh:
Post by: Darren on February 27, 2009, 08:42:32 PM
That's Ok John, we all do that at times, or even most of it  :ddb:
That's why we are all here, the collective works as one  :borg:
Post by: sbwhart on February 28, 2009, 01:42:01 AM
Thanks Guys I'm a bit dim  :scratch: when it comes to electrics I didn't know there were permament magnet motors you learn all the time on this forum  :borg:
Post by: Bourne Bill on February 28, 2009, 11:36:27 PM
I forgot to mention that the variable speed works via a split pulley like a snowmobile clutch.
Post by: bogstandard on March 01, 2009, 04:35:49 AM
Aha!, mechanical variable speed, that will take a little more thought.
Post by: Darren on March 01, 2009, 06:24:57 AM
Ah, not so simple then, most do it electrically from what I've read....shame... :scratch:
Post by: Bourne Bill on March 19, 2009, 01:36:09 PM
I ll find another one. The town dump where I live has them in the swap shack quite frequently. I get a lot of nice square tubing there, from discarded exercise machines.
