The Shop => Tools => Topic started by: Meldonmech on March 30, 2015, 03:04:08 PM
Hi Guys
I have had half a dozen plastic and steel ratchet camps for quite a while now. They were originally bought when I was building the conservatory. They were never top quality but were available when I was in desperate need. Recently one expired, so I removed five retaining screws and opened it up, and found the plastic ratchet lever/ handle had lost it's nib.
I made a hard wood replacement to see if that would work and it did, quite well, so decided to cast some in aluminium.
I made some patterns, and on a recent sunny day when converting scrap into ingots decided to make some moulds for the handles. A couple of handles where cast.
The surplus metal was sawn off, then the castings were fettled on the belt sander.
The handles were then drilled, and finished filed to final shape, with corners removed for comfort, and given a trial fit. The ratchet worked well so the cover was replaced, job done. Only five more to go.
Thanks I have one or two similar.
Mind you a mate paid big bucks for top line clamps when he stored them near a summer lit window the sun destroyed the plastic handle next time he used them they wouldn't work.
No replacement parts available told go out buy new ones.
:thumbup: nicely done David , cracking fix :clap: :clap:
:thumbup: :clap: :beer:
