Well......
Had another go, with geometry set (99p Wilkinsons), squared paper, cardboard cut outs, imagination etc.... :smart:
Managed to prove one thing. I've totally lost any trigonometrical ability. Despite using it almost daily while working for a living! :palm:
Sooo....... After all that waste of time, decided to build a conventional crank assembly! ::)
Drilled the deck 5mm, and threw away 6off assorted/ useless, new, tin coated countersink bits. Before finding my old rose bit, from the 1960's. :bang:
Consequently, not a lot of progress made, in a lot of (precious) time........ :bang:
(http://i110.photobucket.com/albums/n95/Dayjo/P1010304.jpg)
The column's rather high at the mo. Better to shorten by an inch, than to extend.
The bearing sleeve, through the column, is 1/2" dia brass, and will have a pair of ballraces.
The discs are 2" dia. The thicker one will be the boss of the 5 or 6" dia flywheel.
No progress possible over the weekend.
But hope have the time, to come up with a means of holding a dozen balsa wood discs securely to an oscillating 4mm piece of silver steel........
Hope your gob's better now, Dave....... :thumbup:
Wow, that is great! Have you considered using rice cakes for the displacer? (Still trying to find a possible use for a rice cake).Having just stumbled on this build, after missing for a while with work from a storm and cleanup, I found this from the start to be just my sort of thing: looking around and getting smacked in the head with an idea which jumps off the shelf and strikes me between the eyes. I haven't finished going through the build because this quote was too perfect to waste, but I've been looking to build a stirling and even have a kit I bought and haven't started, but twenty years ago or so, I got a sample actuator which is pyrex glass tube with a graphite piston, meant to operate some gizmo or door or something, and I've never got around to using it. The rice cake sounds like the perfect start of a displacer and about the right size to go with the actuator.
If you're just going to use the pan ..
Can I have the omelette ???
BC
Bc, stop egging him on, cant u see he's still shell shocked.. :palm:
BC
When I get this thing finished, and running...... You can have the omelette, no problem! :thumbup:
While we are on about lapping ... or not ... anyway I'll poke my nose in ..
Ages ago I used this stuff in the making of very thin sections of fossils ... before sticking to microscope slides ..
http://www.ceriumoxide.co.uk/
It is a very fine polishing mineral. I have some ... err .. somewhere :doh:
Not from the supplier above though.
Anyone used it for pistons/bores etc ??
BC
Very nice indeed :thumbup: :thumbup: :thumbup:
It is amazing the stainless kitchen ware you can pick up for little money
True John ... but one thing troubles me ...
This 'stainless steel dog' stuff ...
Funny place, Chesterfield ...
Bent spires, stainless steel dogs ...
Hmmmmmmm ....
BC
There's nowt wrong here. :thumbup:
But, we do have funny neighbours. Them over the fence, who cause all the problems....... ::)
Would you like to have to live next door to you?
:D
(http://i110.photobucket.com/albums/n95/Dayjo/P1010660.jpg)
That was cleaver Dave:-it didn't come out as a dogs dinner :D.
When you hand the board vertical what was it clamped to, from the pic it looked like you were using sky hooks :scratch:
Nicely shown as usual
Have you upgraded to 2 candlepower ? :coffee:
TWO candles! :bugeye: Steady on!
...... Incidentally, look what I found in my local supermarket! :D
(http://i110.photobucket.com/albums/n95/Dayjo/P1010791.jpg)
David D.
Honestly David, I know its great that you've found a carrying container for your beautiful new engine, and that you're an extremely modest man ("a bit pleased"), but I'm sure the engine is worth well more that £3 even with that new carrying barrel thrown in.
Dave M. :beer:
Please, if any of us sees David eyeing up an oildrum, just talk to him about anything but Stirlings, lead him gently home, and put him to bed until he calms down....
Maybe better not to lead him home past the Gasworks.
The sight of a Gasometer could well push him further over the edge ..
BC
AndyMaybe better not to lead him home past the Gasworks.
BC
:D :lol: :lol: :lol: :D
Nice one Fellas! :thumbup:
But........... I'm just beginning to form a plan, for the big hot cap.......... :Doh:
:smart:
