The Breakroom => The Bookshelf => Topic started by: PTsideshow on August 19, 2008, 06:18:18 AM
Pipe Welding Techniques
By Griffin,Roden,Briggs
Delmar publishers
Trade Paperback
copyright ©1972
LCCCN#76-188807
http://www.delmarlearning.com/
(http://i35.photobucket.com/albums/d200/ptsideshow/assorted/welding%20books/Books0224.jpg)
A slim volume of basic pipe welding in 17 units. Since it was published a while ago The field of pipe welding has become more complicated and involved. But is does give the basics
From the applications of pipe welding,to running the various weld beads on the vertical and horizontal pipe. From single pass to multi and weave bead, to Standards and test of the time. To procedure aids for qualifying tests, overhead welds,vertical up and down.
Along with a little pipe fitting,branch connections and lateral pipe connections.
Has drawings, charts and B&W photos to go along with the units. Because of the age of the book. It is more geared to the home shop guy that is looking to build a work table or other pipe frame structures.
Since the publisher is a text/learning trades type they might have an updated version or something like it on their web site.
