The Shop => Tools => Topic started by: Darren on December 04, 2008, 02:48:46 PM
OK, OK, not strictly a Harrison as you know it, but made by them all the same. Harrison made machines under the Union brand name until the 70's.
This is the Union L.1.A.S from around the 30's.
(http://www.lathes.co.uk/harrisonwood/img17.jpg)
This is my newly acquired example.....oh dear
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_9982.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_9985.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_9986.jpg)
Why did I take this home? Well firstly it was free, it came with a complete set of change wheels, dogplate, face plate, 3&4 jaw chuck, intermediate shaft with pulleys and a working motor. Basically it's all there, inc the end cover with thread cutting chart
At worst the change wheels can be used for dividing, and the slide maybe used as a milling slide on another lathe....
But wait, lets not abandon it just jet..............more to come I've been busy tonight...!!
Ok, first thing we need to know is just how bad is this rust...!!
It sure looks bad, those pic's are not exaggerating anything....lets have a look...
Using a rather large cobolt lathe tool as a scraper I carefully removed the surface muck....
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0002.jpg)
Surprisingly it was mostly a combination of grease, and lots of it, sawdust and a bit of rust...in fact this lathe was quite well greased up when stored by the look of it..
A little rust has got to the bed, but it's not that bad in reality...
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0004.jpg)
Armed with nothing more than this
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0006.jpg)
And a few of these, (Bogs would be happy at least)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0007.jpg)
You too could look like this...ahem...
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0016.jpg)
Not too bad so far, better than the first impression by far, wouldn't you agree...?
Then the next stage, I took a diamond hone, not the cheap plastic type with holes in, they flex far too much. But a metal backed solid type. Read that as very solid.
Mine is a "very, very fine" whatever that translates to?
About an hour later with very careful attn to detail regarding flatness and full bed length strokes we have this. keeping it flat was not too much of a problem as suction did the hard work. Lucky for me that this bed is flat.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0019.jpg)
Now then, how good is it so far? Well the carriage now glides from one end of the bed to the other with a simple flick of a finger, it just glides,
Unbelievable !!! Well I was shocked at just how smooth it glides....beautiful...
I'll do some more on this methinks... :D
Tool restorations are great to read. Is that a treadle powered lathe? I assume it is for wood? Please edumacate me :smart:
That mug is way too small, double the size at least.
In the first instance on any of the assembled bits, if you can, get an old washing up bowl (or even a new one) and soak the assemblies in diesel fuel. Doesn't need to cover them, just use a brush to get it onto the bits. Leave for at least a day. That should then free everything up, and you will do less damage getting them apart. Don't go too heavy getting the rust off mating moving parts, most of it will wear off when you get the thing turning.
I wouldn't expect too much from it in the accuracy stakes, but it would make a good roughing out machine.
Blimey Darren .............. you do like a challenge don't you ::) ........ From the second picture to the last ............. the difference is incredible :headbang:
Keep us updated ............... and ............. where do you find all the spare time :bugeye: .... if it's available in the supermarket can you post a link :D
CC
Hi Eric, yes it was a treadle lathe originally, but like a lot of them it was "converted" to leccy when it came about no doubt.
It's a metal lathe
Hi John, surprisingly everything it free, nothing was even tight. The bearings feel tight but spins just dandy.
Accuracy, yep not expecting too much, will have to wait and see.
But, but, but,
It's got a back gear and a 10.5" gap bed, wonder if it's up to making me a backplate...? Should be, shouldn't it?
Question is can I make one... :D
Darren
CC
I'll be honest I thought this lathe was a basket case. I wasn't even going to post about it.
But when I scraped the muck off the bedway my thoughts took a turn.
Ok, it's not much of a lathe. But I'm sure it'll find some use....maybe !!
I just fancied restoring it and see what gives...I mean, it's nearly 100 yrs old, well not far off, be a shame to scrap it now.
Darren
Did a little more tonight and it's looking a bit better all the time
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0103.jpg)
Tried shining a light through, didn't see much surprisingly. How accurate are these rules anyway, my 2ft one is deff not straight, different on both sides. This 12" one is better.
That's a 500W photo flood light I'm using. I know you can't see much in the pic, but there wasn't hardly a slither of light getting through.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0101.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0102.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0105.jpg)
Darren
Oh, I forgot,
Isn't cast iron nice to work with..can sorta "feel" what's going on.
Hope it machines just as well...
Darren,
You have a faceplate and a chuck for it.
If it can cut an 8TPI thread, then I see no reason for it not being able to make your cherished backplates.
As long as you can get it to cut accurately for a length of about 2" in the headstock area (that will be where all the wear is, if it has any).
Darren
Glad to see that you were in the right place at the right time. :clap: The difference between the before and after photos is amazing. :thumbup:
I will be watching to see the final outcome on restoring this lathe. Job well done to date.
Cheers :beer:
A little update on tonights work on this little lathe.
I lapped the saddle to the bed for an hour or so using some fine aluminium oxide powder mixed with WD40 oil. This allowed me to see where the high spots where and hopefully "knock" them off somewhat. "knock" doesn't really conjure the right image....it's taking hours and hours !!
You should be able to see darker sections/lines on the bed, this is where the paste has been doing it's job leaving a rougher finish than the diamond stone. It looks like a groove but I can assure you it's not. You can't feel it, it's just how the light catches the different finishes.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0112.jpg)
After I was satisfied that the lapping of the bedways was good enough I turned my attention towards the top cross slide.
Remember this???
Well it now looks like this and has too been lapped in, nice and smooth now.
Where did that brass protractor come from. Well it was there all the time, just hidden under all the muck !! Come up nice too.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0113.jpg)
From the other side
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0114.jpg)
And the front
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0115.jpg)
I found a major problem with the screw nut, it was fouling the inner tunnel causing two real problems. Firstly it was lifting the slide quite badly, second it made the slide progress with great notches. All it needed was some material removed and all became silky smooth.
This lathe does not appear to have had much use. I can't find much evidence of wear considering it's age. This is maybe why, as I assume it would have made quite a mess on facing work.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0116.jpg)
Onward we march then.......... :D
Darren,
I was going to say that the lathe doesn't look abused at all. Hardly any "Oops" marks on it. It'll be interesting to see this thing looks finished with a nice coat of paint on it.
Keep up the good work. :dremel: :thumbup:
TBH Bernd it looks hardly used, some very tiny nicks on the bed, just two and the saddle has been run into the chuck maybe once. Again a small mark that I could take out altogether.
All the lead screws etc show no signs of wear that I can tell. Even the screws/bolts holding it all together look as good as new, no rounded heads etc.
Big question is, how will it perform? :dremel:
So, a bit more work done tonight on the compound slide. I'm not too happy with the finish, I'll have another go sometime. The top is a biggish area to do by hand.
Started off looking like this...
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0119.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0124.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0125.jpg)
I lapped it etc as the other bits and stuck it back on...
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0129.jpg)
Now it's starting to look like something that can be used !!! :dremel:
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0128.jpg)
Paint, you want it painted...!!!
The original paint is mostly still sound, but looks terrible !! What a colour to use,
In fact what is the colour, black, dark grey, mud, it's hard to tell.
Yep would look nice painted, tidy up the hand wheels and stuff..
What colour sir? :whip:
Darren
Darren,
That's a fine job so far feller, well done ............. now you've sorted the cross slide it should be better than new :thumbup: ........... as for colour ......... that's up to you, for gawd's sake don't ask a question like that on a forum, you'll get suggestions from black , thro' red/white/blue to sky blue pink with yellow polka dots .......... all with supporting info as to why that choice is best :D :) :D ... but as to "painting it" ...... I'd be very tempted to have a chat with Rog02 cos' his Delta bandsaw came out a treat :thumbup:
Keep the updates coming please :beer:
CC
Darren
You know Darren after seeing how nice it looks when you get that crude off I'd say "clear" color would do it. :headbang: :D :D
I mean like a clear coat lacquer.
I rather like the thought of a white paint with red inners.
But for now I think it might be a good time to get it up and running, see what it can/can't do and go from there..... :dremel:
Nothing done today, been out with swmbo :D
I'm with you on that Darren ............ Bling can come later :headbang:
CC
Paint don't cut metal, the lathe does.
Bling is for others to admire, and you to keep polished.
Great job on it Darren.
Hi Darren,
Yes I know very late to this party.... I've been busy doing a whole lot of bugger all!
I just thought I'd say that looks very, very good.... Who would have thought that machine was under there? :bugeye: :jaw:
Top job, and good find me thinks :thumbup:
I'm now waiting for the results of the run up :dremel:
Ralph.
Thats a nice looking lathe!
That's OK ............... seeing as how you have such a good excuse (http://www.websmileys.com/sm/cartoon/177.gif)
CC
Thanks for all the support guys, much appreciated. So much I'm going to inflict you all with even more pictures :)
Turning my attention towards the drive set-up I have this to work with
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0132.jpg)
Seeing the need to strip it down and having to re-arainge the order of components I did just that.
Gave the monster 1.25" shaft a bit of a spin in the S&B whilst abusing it with some sanding paper, came up quite well.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0134.jpg)
Here are all the components in bits ready for a clean
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0138.jpg)
It all came apart quite easily once it'd taken some of the burs of the end of the shaft where it had been knocked.
I have some ideas on how to set all this up, inc having some method to enable loosening of the flat belt for changing speed purposes.
But if anyone can provide some pictures/drawings or ideas of how it's all arainged it sure would be helpful.
Darren
Darren,
Normally with a flat leather belting drive using a curved cone as you have, tension slackening isn't normally used. Just slip the belts across by hand. The leather belt finds its own centre on the top of the curved cone pullies. Just make sure the cones are perfectly in line and parallel to each other.
All you need to do is check that both sets of cones are a matched pair and the same size.
If you do want to put a tensioner on there, use the sliding feet of the layshaft as the tension agent, but you should find with a leather belt, even if it is slack it will still give a very positive drive.
You can easily double the range of speeds on the lathe by fitting a double pulley on the layshaft and motor, and tension the motor belt by sliding the motor on its mounting foot. But I wouldn't get the lathe running at any more than about 1500 RPM because it only has phos bronze bearings, and above that, they are liable to get rather hot.
Ah, that prob explains why my last S&B belt didn't last too long then? I have it fairly tight, the new one is not leather though.
Just to clarify a couple of points as it may help decisions, though really I would doubt it. The lathe cones don't seems to be curved like my S&B, they are flat. Sizes for both are 2,3 & 4". The lathe uses a combination of bronze bearing at the back and ball race at the front. So I guess still need to keep the speed down.
With a 400rpm layshaft speeds would be 800, 400, 200, with back gears 112, 56, & 28 rpm
Quite a nice range I would think?
I don't really need high speed from this machine as the S&B goes up to 3,000 rpm and I would use that mainly for small dia work, esp with the collets. Then there is the Mini Lathe.
Feel like a spoilt brat ere ::)
I have two motors with gearboxes on them. So thinking that I could do away with the layshaft and fix the 3 step pulley directly on the motor I investigated further.
One has a 15/1 ratio, so speeds would be 190, 95, 47, 26.6, 13.3, & a whopping 0.07 rpm. A bit slow methinks :smart:
t'other is on the donkey saw, 28O rpm giving 560, 280, 140, 78.4, 39.2 & 19.6 rpm. Apart from the top being a bit low at 560 that's not too bad is it.
I could almost live with that.
Comments anyone?
Darren
Thinking things over how about this basic idea.
Shorter belt req', mount on steel plate, wood for mock testing. Mount roughly as shown in the picture, both layshaft and motor have adjustment in feet for tension and alignment.The red line relates to a pivot point with the bias position to drop the layshaft under gravitational forces onto simple bolt/nut. The bolt being fitted vertically from the table lower section for the board to rest upon thereby adjusting belt tension.
All to be sited under the table with the lathe above.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0141copy.jpg)
Darren .......... that's pretty much how the Underdrive system works on my Boxford Lathe ............ and there are thousands of them out there working fine ........ so the system is tried and tested, OK there are a few extra pulley's so variable speed is an option but ......... you can always add that later. I'm sure there is a wealth of info on't interweb, but ...... if you want a couple of photo's just shout up :wave:
CC
Thanks, I think I'm pretty much sorted, but a pic never hurts does it, just in case :wave:
Darren
Thanks Darren :wack:
Now I am on the lookout for an old lathe to restore. Not like I have enough projects and ideas to sort through :)
J/K around of course. Between you and Rog restoring old machines to better than new... I got the itch!
Eric,
Having restored a couple myself, and used the resulting lathes to their full potential, it is a heartwarming feeling to know you have brought a bit of old iron back to life. Most probably to a better condition than when it was new.
But the machine destined for restoration must be feasible to do. The expense of bed regrinds and white metal bearing replacement can soon make a restored lathe cost a lot more than a new one.
I was lucky with the Atlas because I managed to find a place in the States that supplied good second hand parts very cheaply, and the Myford ML2/3 restoration, I was able to machine broken off cast iron parts in steel and bolt them on, and turn up new bronze head bearings.
I think Darren has dropped in lucky here, and got away with very little more than elbow grease, that could have easily turned into a much bigger and more expensive project.
Do a little homework first (unless of course it is the bargain of a lifetime) and choose your project well, and you will get all the rewards that come with a good restoration.
John's right Eric,
I know the original pictures made my lathe look beyond repair due to rust. But what looked like a horrendous amount of rust damage on the lathe was really a little rust in a lot of grease and dirt.
My second stroke of luck was the fact that this lathe has seen hardly any use at all, mostly evident in lack of damage or wear to be found anywhere.
Like John says, all I've really done is clean it up and lap it in a bit.
More luck than skill...more to come soon, a mig followed me home today..... :)
What? A Russian jet. :jaw: Wow. :D :D :D
P.S. Sorry I couldn't resist that. :hammer: :wack:
Darren,
Just a question.
You started off by machining up little upstands for glass valves.
Over the last couple of months, you have been gathering together copious amounts of engineering machinery.
Have you rented out a factory somewhere to set up your own business, or have you caught the model engineering bug, and squeezing it all in a garden shed?
Ah yes but Brend, it never overtook me, hows that for driving :D
John, just replacing what I once had, but been missing in my life for a while. I've always had the bug to mod.... :headbang:
Bit of a squeeze here too....I've got a lot on my plate here, bought a new place 12mths ago and renovating it as I go along, it's a big job. A garage is also on the cards. Nearly got one wall built. Going slow though :(
Wait until you see the ground cart needed to start it ::)
Decided to have a look at the front head bearing tonight. It feels in great condition and turns freely.
Once the front cover was removed it was nice to see the bearing packed with grease and had not been run dry. Was equally as nice not to see the area full of rust.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0147.jpg)
It looks old but has not hardened, all the same I decided to replace it. I had no desire to remove the bearing for fear of causing any possible damage. Besides, there was no reason to take it out. On top of the bearing housing is a grease cup for adding lube. For those that may not know the idea is quite simple. you pack the cup with grease and thread it back onto the housing. Only a couple of threads mind you. Over time you tighten it up by a couple of turns every so often. This forces grease right into the bearing itself. When fully tightened down you undo the cap and remove it, fill it with more grease and start the process again. It's quite an effective method.
In my case for this time around, I filled it several times, thereby forcing the old grease out and totally renewing it. I used Lithium Molly grease here as it was all I had to hand. Good enough for car CV joints it'll be great in this application.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0151.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0154.jpg)
Here's a picture of part of the leadscrew dog clutch. This is forced in and out of the mating part to start/stop the leadscrew from turning whilst leaving the lathe itself running if desired.
Whilst quite a crude and brutal method, it's great for threading as there is no need for a thread dial indicator. You will always engage in the correct position with one of these.
But a point to note is the total lack of wear. It's mating part not shown here is in the same condition.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0146.jpg)
I would have done a bit more today but I've been playing with this. Well I had to test it didn't I..!!
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Restoration/IMG_0142.jpg)
Alas I have no mask, need some wire and it needs a new tip as it's missing. But it seems to work fine and it's had a new gun fitted....hurray..I'll have fun with this :D
Tonight I decided to have another look at the Union lathe.
old-biker-uk, (Mark who makes those fascinating coins) was kind enough to offer me a motor mount with built in belt tensioner facilities.
Very generous of you Mark and extremely helpful to the cause. :thumbup:
The bronze bearings look to be in good condition and accept a 3/4" (19mm) pulley shaft. Here I've fitted a steel bar in my initial sort out of what I'm going to do with this lot.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1453.jpg)
I need to fit these two pulleys on the shaft, neither has the right sized bore....of course not, why would they....more excuses to turn on the lathe :ddb: :ddb: :ddb:
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1455.jpg)
For the 3 step cone pulley I decided to make a sleeve, uh, only got a drive shaft to make it from :lol: :lol: :lol:
But, I'm not going to drill or tap it this time, just reduce the outer diameter and bore it.
Learning from my past mistakes I'm using the abrasive cut-off saw this time around, the bandsaw blades last a wee bit longer this way :dremel:
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1457.jpg)
Turned the outer diameter to a little over sized to be finished later.
Here I'm drilling the center out to 19mm to fit the shaft.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1461.jpg)
Incidentally this is the first time for me to try my new keyless chuck. If you are still using a keyed chuck, do yourself a favour, throw it in the bin and get one of these. They are brill to use, no straining to get it tight enough, it self tightens under the drilling pressure, all you need to do is nip it up by hand first. Very quick to use esp as you don't have to hunt for the key first :scratch:
The drilling with a 19mm bit is only possible after doing Bog's tailstock arbour mod along with me fitting the flat car fan belt. Totally transformed this lathe.... :ddb:
Boring out the 6" pulley to 19mm
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1462.jpg)
This is the sleeve on the shaft, I will weld this together tomorrow, hence the chamfers for the weld bead. When that is done I will turn the sleeve to it's final diameter so that it's true to the shaft.
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1466.jpg)
A few shots of the mock set-up
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1468.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1469.jpg)
(http://i401.photobucket.com/albums/pp92/thebodger/Lathe%20Work/Union/Union%20Motor%20Setup/IMG_1471.jpg)
That lathes coming on a treat Darren your making good use of that motor mount I think you'll soon have a runner.
