The Shop => Tools => Topic started by: 75Plus on February 03, 2010, 08:54:41 PM
Am I the only one that finds that the Asian chucks or chuck keys seem to wear rapidly. Every one I have started slipping when tightening or releasing in a short period of time. I have several Jacobs and other US made chucks that are still tight after over 50 years of use. :doh: :doh:
Joe,
The chuck supplied with my Chinese bench drill "stripped" internally during it`s first week of use...... ::)
Successfully replaced by a cheap 13mm chuck off Ebay. :thumbup:
My X2 type mill`s chuck "stripped" internally during it`s first month of use........ ::)
The Ebay chuck is now on the mill, and still giving full satisfaction! :clap:
I guess you can say Asian quality is variable.......
David, My problem is with the key. After a short period the key starts slipping on the teeth of the chuck. I think it has to do with the fit of the key to the chuck. I just don't know how to improve the fit.
you could try machining a small amount from the narrow end of the taper so it goes in the chuck teeth more.
Roy
Roy
Yes! I`ve done that too....
Also, always push the key towards the teeth, so it is held tight in engagement...... :thumbup:
Never had a problem with my own keys. Often had problems with communal keys, (at work)! ::)
I have six tail stock chucks for my lathe and some of the keys that came with them fit really sloppy so I tossed them and just use the ones that fit good. Perhaps you can find a good quality key at your local hardware store that will fit better. The keys that come with the chucks are poorly made.
Dale P.
