Gallery, Projects and General => The Design Shop => Topic started by: cedge on January 14, 2013, 09:37:25 PM
Not sure if this one has been posted before, but I'm giving it 100 bonus points for ingenuity. I'm also going to have to have one of my own. :bow:
Very nice I may have a go at one myself with a few differences.
That would also make a fantastic engine stand.
What an excellent idea...
off to eBay to find out how much bowling balls cost...
I have loads of brake discs
There have been a couple of less-sophisticated ones here on MadModder already:
http://madmodder.net/index.php/topic,852.msg5764.html#msg5764
http://madmodder.net/index.php/topic,6118.msg65747.html#msg65747
The Internet is a wonderful thing....
My scultpture textbook in art school had this basic design, as a woodcarving clamp. The bowling ball had a double ended lag screw on it; you just screwed on your hunk of wood and started carving. Instead of disc brakes, the model there had a stand made of 4 4x4 posts hinged at the corners of a 2x2 square of plywood with opposing members joined by threaded rods running through pivots halfway up. The bowling ball rested in notches cut in the ends of the 4x4 posts. Basically a big gripper-clamp for the bowling ball. Not nearly as quick to adjust, but then wood carving isn't a fast process.
How is he releasing the pressure off the jack? All the ones I've seen, The bleeder is a screw. :scratch:
A versatile bit of kit, I like it.
David
If you look at the other video of the build, he shows the jack from a motorcycle lift that has a quick release valve rather than the bleeder screw.
AHAAAaaaaaa!
