Gallery, Projects and General => How do I?? => Topic started by: NormanV on October 11, 2013, 09:11:29 AM
The spindle on my Loughborough lathe has started running tight and I need to remove it to check the taper roller bearings. I have removed the locking ring on the rear of the spindle and slackened off the grubscrews that hold the pulley in place. When I tapped on the rear end of the spindle it felt very solid. Before I do any damage, has anyone any experience with one of these lathes who could advise me?
Thanks, Norman
On my clausing it went tight when the slide gear siezed check the gear train :doh:
The Loughborough lathe does not have any gears, it is a plain lathe.
I have temporarily solved the problem by flooding the bearing with WD40 but I would still like to dismantle it to clean and apply some grease. That will teach me not to turn wood!
Norman
