Gallery, Projects and General => Member Videos => Topic started by: Jim Dobson on October 16, 2020, 09:26:17 PM
Title: Putting some grip (stippling) on an aluminium drive pulley.
Post by: Jim Dobson on October 16, 2020, 09:26:17 PM
I've always wanted to work out a way to put some extra grip on a home made drive pulley to prevent or cut down on belt slippage. It would be nice to have the tooling that Wilesco use on their grooved pulleys. I had a Dremel saw accessory that the outer plastic shell broke and I thought what can I do with the saw blade. Rudimentary, but it worked well. I should be able to work out now a way to mount it so it doesn't need to be held, though its not as dangerous as that looks and being hand held allowed me to skew the saw blade at the various angles needed easily.
Title: Re: Putting some grip (stippling) on an aluminium drive pulley.
Post by: efrench on October 17, 2020, 06:11:22 PM
Perhaps using the correct geometry would work better.  Misumi's website shows a truncated V profile with 36 degree sides and the belt not touching the bottom.
