The Shop => Tools => Topic started by: SPiN Racing on February 06, 2009, 06:19:43 PM
Wanted to thank the guys here... I HAVE been listening.
Today I picked up a set of Parallels!!!
http://www.wttool.com/product-exec/product_id/17584/nm/10_Pair_Thin_Style_Parallel_Set_WT_Import_ (http://www.wttool.com/product-exec/product_id/17584/nm/10_Pair_Thin_Style_Parallel_Set_WT_Import_)
Yes I joined the bronze age, and got modern!
No more taking scraps of steel and hoping they are parallel when putting them under things in the vise!
I also got a couple of MT2 Tapers for the projects in the works.
One is MT2 To JT6... I figure that is stout enough I may use it for my Tapping endeavors. Since it was $3.00 US.
(They dont have a pic for it)
I also got a MT2-5/8-16 arbor... that I may end up using in the Peck Drill.
http://www.wttool.com/product-exec/product_id/37033/nm/Threaded_Drill_Chuck_Arbor_WT_Import_ (http://www.wttool.com/product-exec/product_id/37033/nm/Threaded_Drill_Chuck_Arbor_WT_Import_)
OH and a Mag base for the Camera Mount!
:proj:
Once again.. thank you for all the tutorials.. it truly helps.
Two main tools to get so I can increase base functionality... Machinist Squares, and one of those dial indicators with the J curve tip....
I have a Starret square.. but its more of a carpenter one in that it slides.. and is I think 16". Has a bubble level as well.
