Home Base => Introductions => Topic started by: jgroom on September 08, 2009, 11:57:01 AM
Hi all! I'm pretty much interested in anything mechanical. I've started several steam and IC models, I'm restoring a 1 1/2hp Fuller & Johnson pump engine, and I'm trying desperately to talk myself out of starting a Locost http://www.locostusa.com/ (http://www.locostusa.com/)! ::) Current project is rebuilding garage/shop for climate control, and maybe some organization. :bugeye:
Thanks
P.S. Not to worry, I already have :proj:
First, A big welcome to the colective Jeff. :borg:
Glad you've already caught :proj: that's great.
I like the car. I think you should do one and post the build here on Madmodder. :ddb: :nrocks:
If need be the group will give you a couple of :poke: :poke: and if you don't your going to get a few of these. :wack: :hammer: :wack: :hammer:
Welcome aboard the cube Jeff :borg:
Ok you've got :proj: but don't forget we like to see pics of your projects :worthless:
Have fun
Hi there Jeff, welcome aboard the cube :borg:
Dont forget the pics of what you've done / are doing cos :worthless: :lol:
Tim
Hiya Jeff!
Yup... I am a member over at LocostUSA (http://www.locostusa.com/) too. Make sure you get the book(s).
Jeff, welcome to the
ward err collective. I like the car, what is the power source? :beer:
Looking forward to your inputs, you should fit in nicely here. :mmr:
Cliff
I built one about 10 years ago, brilliant ...... :thumbup:
But an awful lot of work even if it was mostly enjoyable.... :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel:
Thanks all!
Brass_Machine - I've got the books, that's half the problem! :doh:
usn ret - I'm thinking a 1.6 Miata motor & trans. I have a '93 Miata and just love the way it revs!
Darren - :bow:
Thanks again!!!!
Me, too. I have a '94 that is awaiting an MP64 supercharger. Where are you located?
Hi rleete! I'm in Bennington, just north of Salina. Just had to say the s-word.... :thumbup:
Thanks
Thanks all!
Darren - :bow:
Thanks again!!!!
They have a book for the Miata conversion to the locost right? I have been working on the locost frame in CAD to make it into a reverse trike....
