Home Base => Introductions => Topic started by: Depaugie on October 17, 2013, 02:16:53 AM
Hi all,
I've being looking in for awhile now, time to ask/answer some questions.
I work from home, a small ventilation business
I trained as a sheet metal worker many years ago, and have alllways had a longing to use/explore machine tools.
Over the years I've being into RC aircraft, (my brother and I supplying a local shop with model engine aluminum exhausts & manifolds)
Motor bikes although not lately, just don't have the time.
Finally managed to put up a workshop that doesn't leak or stumble when crossing the floor.
I have just acquired a French lathe that needs some info, what section do I post that in?
Have a Emco compact 10 & F2B mill, welders, hand folders, hand knife ect
I am also trying to get an industrial spot welder working on 220v supply and make arms & holders.
Too long now my Elliott M10 has being laying disassembled, it needs to be one again.
Also extend the workshop, it's just not big enough.
Thanks Paul
Welcome from the fringes of civilisation Paul. Workshops are never large enough.
Jim
Welcome aboard Paul
There is a definate rule regarding workshop sizing. You will always have stuff to fill 110% of the space you have :ddb:
Hi there, Paul, and welcome.
Hi all,
SNIP
SNIP
Thanks Paul
I'd put that in the 'Tools' section. But have you looked at Tony's machine tool archive on lathes.co.uk ?
Thanks for the welcomes guys,
Pete thanks I'll stick that in the tools section.
It's a De valliere H140 lathe.
And yes Tonys site was the first I tried.
It's pretty much the same as what's in the manual.
Hi and welcome!
What kind of French lathe? I live in France and am on a good French Machine and machining forum with lots of technical information.
Regards, Matthew.
Hi and welcome
Welcome to the forum I'm sure you will enjoy it.
Hi Paul , welcome to the forum , the ally sheet metal type stuff sound interesting , any chance of some photos ? Hope you enjoy the forum , cheers Mick.
Hi Micktoon
It's a long time ago since we made RC exhausts. Actually last time was the early 90's .
They were simply made from milled bar 16x10mm with 16 or 19mm x 1mm alum tube which was bent to approx 135deg flattened using a former to maintain the shape required, which was a flat oval.
The 'header' bar would have a recese milled to registar on to the exhaust port.
When cleaned up & assembled we used aluminium solder made by 'Camping Gaz', which is a brazing process as the temps required are near critical temps for aluminium.
Sorry I don't have any photos. I'll have a look and see if I can find any bits or units left over.
We called the exhausts 'Rip Speed' we sold/traded them into a local model shop, as well as making the usual range for 40's 60's ect we made one off specials for scale planes to conceal/replicate the outlets.
Hi Depaugie, and welcome to the forum! :wave:
